Stuck Tacoma's-Lets see 'Em
Discussion in 'Off-Roading & Trails' started by Rollinn, Sep 22, 2009.
  1. May 24, 2012 at 11:02 PM
    #1241
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    ^ haha awesome.
  2. May 24, 2012 at 11:07 PM
    #1242
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    aaaaaannnnndd the drop
  3. May 24, 2012 at 11:09 PM
    #1243
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    EDIT: HAHAHA Nice Adam! Didn't even realize we posted both of our stuck pictures from the same trail at about the same time (2 minutes apart)!
    completed one of my goals for moab...get stuck and need to be winched/towed out
    I tried to go around this sand berm but it became too sharp and steep. by the time i decided to cut out and go up i was going straight out and just started digging my tires in and hopping about every time i stepped on it. My bumper was also 3" from the wall behind it so i really couldn't go any where so I had to call adam to bust out his winch.
    aww yeeaa!
  4. May 24, 2012 at 11:15 PM
    #1244
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm just glad the winch works!
  5. May 24, 2012 at 11:17 PM
    #1245
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    wish i woulda found that out about my cb before moab:(
  6. May 24, 2012 at 11:19 PM
    #1246
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    that it has down syndrome
  7. May 24, 2012 at 11:23 PM
    #1247
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    wasn't the only thing with downs thats for sure
  8. May 24, 2012 at 11:26 PM
    #1248
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm sorry . :( this may help you
  9. May 25, 2012 at 12:10 AM
    #1249
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    This was a looong time ago! Completely stock!! Wanted to play in mud=wanted to learn how to use the winch!!
  10. May 25, 2012 at 12:13 AM
    #1250
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    do you have a hidden winch mount?
  11. May 26, 2012 at 3:02 PM
    #1251
    stangkeip10
    stangkeip10 Well-Known Member
    Cincinnati
    '10 Magnet Gray 4x4 Access Cab SR5
    BHLM, Black OR TRD wheels, BFG Mud terrains, yellow wire mod, 5100s @ 2.5, toytec tsb aal
    following no mods into a mud hole, no lockers on mine though
    and.. the mess
  12. Jun 15, 2012 at 9:59 AM
    #1252
    J88logue
    J88logue NorthWest Member
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    Was going about 15mph up a snow trail and i crabbed the left shoulder just as it dropped. My front tire fell two feet into a tree well. I dug the snow down to the branches underneath and had one of the yotas behind me pull me out.
  13. Jun 17, 2012 at 4:30 PM
    #1253
    nucktaco
    nucktaco Well-Known Member
    Scott
    south surrey, bc
    08 Double Cab TRD Sport
    satoshi mod, sliders, tinted tails/3rd brake, 3" lift,
    this happened yesterday on the britannia creek fsr near squamish bc. i attempted to cross this washout at 330pm yesterday. ended up leaving the truck at 1130pm and came back this morning with my hilift and had it out in 10 mins. trans crossmember is twisted and the frame seems to be kinked where it meets the trans crossmember.
    this will be the last time i leave the house with no recovery equipment and im gona wire the winch up tonite. :D
  14. Jun 17, 2012 at 4:43 PM
    #1254
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I wasn't actually "stuck" as I could have backed down, but I wasn't able to make it up on my own. My wheel base was a bit longer than the 4runners I was with so i got high centered on my slider and frame and since I don't have a locker I wasn't able to push myself up. So it took 2 4runners and a winch to drag me up over this ledge.
  15. Jun 18, 2012 at 5:43 AM
    #1255
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Bash it back with a BFH and grab some skids. ATO skids would of stopped that from happening to the cross-member. My cross-member is also tweaked from before I got skids... getting the bolts out to install the skids was a PITA, but once on that is unlikely to happen again.
  16. Jun 20, 2012 at 10:30 AM
    #1256
    RoyR
    RoyR Well-Known Member
    San Diego, CA
    Billies, TSB
    I didn't see any pics of this great idea....:)
  17. Jun 20, 2012 at 12:36 PM
    #1257
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    HA! Best idea for Salton Sea is.... Stay the fuck away from it !!!
    Thats my boy Greg paying the price , along with 4 or 5 others that were stuck in that stinking, frame eating corrosive shit hole...:eek::D
  18. Jun 29, 2012 at 7:32 PM
    #1258
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
  19. Jun 29, 2012 at 7:38 PM
    #1259
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  20. Jun 29, 2012 at 7:39 PM
    #1260
    anthony250f
    Anthony
    San Diego, CA
