Stuck Tacoma's-Lets see 'Em
Discussion in 'Off-Roading & Trails' started by Rollinn, Sep 22, 2009.
  1. Feb 24, 2015 at 8:39 PM
    #1701
    Greenbergler
    Greenbergler Well-Known Member
    Corey
    Orange County, CA
    2017 trd sport DCLB 4x4
    So no more power mirrors?
  2. Feb 24, 2015 at 8:53 PM
    #1702
    PBR Streetgang
    PBR Streetgang Well-Known Member
    Andrew
    Medford, OR
    2013 AC 4x4 TRD
    Icon stage 4 kit, Deaver J66 leaf springs, Firestone ride-rite airbags, Warn 9.5 XPS winch
    My Warn 9.5 is permanently mounted on the front but I really like the versatility of being able to winch forwards or backwards so I might do something similar to your setup.
    I had to winch my truck around 180 degrees for this recovery, a rear winch option would have been much easier.
    Navydoc714 and Walogo like this.
  3. Feb 24, 2015 at 8:56 PM
    #1703
    Pigpen
    Dan
    Northwest Montana
    Never had them - base model
  4. Feb 25, 2015 at 6:27 AM
    #1704
    Pigpen
    Dan
    Northwest Montana
  5. Feb 25, 2015 at 9:43 AM
    #1705
    skygear
    skygear                    
    People criticized me for wanting a rear Winch. Still in the works for me.
  6. Feb 25, 2015 at 9:45 AM
    #1706
    Large
    Large Red
    I can't really see a downfall of a rear winch other than poor R&D would limit your ground clearance in the back. When I have my rear HC built I want to see if Tyler can make a winch mount where the spare tire used to be.
  7. Feb 25, 2015 at 9:49 AM
    #1707
    skygear
    skygear                    
    in my design, i have it slightly off center so i can still have a tow hitch. Eying the electronic clutch winches too.
  8. Feb 25, 2015 at 9:50 AM
    #1708
    Large
    Large Red
    Good call
  9. Feb 25, 2015 at 10:05 AM
    #1709
    skygear
    skygear                    
    In reality, on a HCRB or any Bumper. As long as the Tow hitch was in the center, lower in the HCRB. There would be enough room above it to mount a Fairlead. Given that the Winch was mounted in the spare tire area or similarly behind the bumper. having a liner of sorts to protect the line in a slack line situation from the hitch carrier.
  10. Feb 25, 2015 at 7:25 PM
    #1710
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    My friend has a winch through his roof :eek:
    So he can get back on his tires after a tip over....YouTube....Waikane, Oahu
  11. Feb 25, 2015 at 8:02 PM
    #1711
    Pigpen
    Dan
    Northwest Montana
    You Tube search didn't give any results
  12. Feb 25, 2015 at 8:49 PM
    #1712
    tx novice
    Ron
    OAHU
    Sorry...
    Just..... Waikane 4x4
    I dont know if theres video of him using the roof winch, but it shows the silly places they drive in.
  13. Feb 25, 2015 at 9:21 PM
    #1713
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    This.
    When I flat deck mine I plan on moving the rear winch up a bit. Otherwise I've had more needs for a rear winch than a high clearance bumper. More sink holes around here than steep inclines or declines.
  14. Feb 26, 2015 at 6:55 AM
    #1714
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Looks like the factory brake and reverse lights are useless
  15. Feb 26, 2015 at 8:33 AM
    #1715
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    Got a question for all you snow drivers. Does it help to air down like driving in the sand? Never driven in the snow
  16. Feb 26, 2015 at 8:35 AM
    #1716
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    Yes it does, I run a slightly lower pressure in the winter all the time. I have been able to drive up icy climbs without trouble then the next truck with 45 psi tires never got up.
  17. Feb 26, 2015 at 8:51 AM
    #1717
    whahahajr
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Thanks
  18. Feb 26, 2015 at 10:57 AM
    #1718
    ImplicitlyAlberta
    David
    edmonton
    :D if you tail gate me during the day it can be disastrous.
    Where the hole is for the high lift jack on both sides I put red led brake/ signal lights. When I first made the swing out my tire were much smaller and there wasn't much of an issue. Anyhow the lights will be gone when I flat deck it this summer if all goes well.
  19. Mar 8, 2015 at 7:29 PM
    #1719
    nightrider1992
    nightrider1992 Well-Known Member
    Omaha
    Finally recovered the vehicle just before dark, but had to leave it there due to blown tire bead and ripped out brake line. It's SAS'd on 37s so it buried deep.
  20. Mar 9, 2015 at 11:18 AM
    #1720
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Going back here at the end of the month, i think i may take another stab at this obstacle.
    Man I'm jonesing to wheel!!!
