STUCK WITH BRAKE DRUM OFF HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by diverdriver64, Oct 27, 2014.
  1. Oct 29, 2014 at 6:32 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    That looks like a fairly conventional setup...I have new rear shoes on order and I thought for my 60k maintenance, I would pull the drums for the first time. I also like inspecting with replacement parts handy. FYI Wagner Thermoquiet from Rock Auto.
    Howard
  2. Oct 29, 2014 at 1:14 PM
    diverdriver64
    diverdriver64 [OP] Well-Known Member
    Kodiak Alaska
    05 Tacoma 4.0 V6 6Spd manual
    I got the truck into the shop. The parts will be in tomorrow. I hate to spend he $ but I was in over my head. I am confident I could remove the drums and clean and lube the brakes now, but after seeing them, I'll leave them for another year. As for my front brakes, I need to replace the caliper on the driver's side as the pistons are pretty rusted and aren't moving very freely.
  3. Oct 29, 2014 at 2:53 PM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Good call.
  4. Oct 29, 2014 at 3:07 PM
    diverdriver64
    Kodiak Alaska
    Good to know : ) Thanks for the heads up
  5. Oct 29, 2014 at 3:24 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Glad to see you didn't drive it. I almost shit when I saw the adjuster yoke end and both springs not on. :eek:
    That's an easy fix for the pros though, I can't imagine they'll drain your wallet for that fix. :)
    BTW, that big chunk of metal is the drum balance weight.... IIRC
  6. Oct 29, 2014 at 3:50 PM
    diverdriver64
    Kodiak Alaska
    I guess that's the difference between you guys that file IFR and us guys that run around underneath ;) She made it to the shop ok (Kodiak is a small town with pretty slow speed limits so I figured it wouldn't be too catastrophic). Do I need to somehow re-attach that balance weight? I can't figure out how it was even holding on in the first place.
  7. Oct 29, 2014 at 6:04 PM
    BamaToy1997
    Bill
    Navarre, FL
    Those weights are spot-welded on. To be honest I have seen them come off and never cause any issues.
  8. Oct 29, 2014 at 7:11 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    Drum brakes are not that difficult to work on after you've done it once. When I first did a brake job on drums, I did as a previous poster said, take off one side at a time, and compare your work with the other side. I have what I call the "brake pliers" that you use to remove & replace the springs. That tool is over 40 years old, and I thought I'd never use it again until I bought my truck.
