Stuck woodruff key
Discussion in '1st Gen. Tacomas (1995-2004)' started by b.a., Apr 28, 2025 at 7:18 PM.
  1. Apr 28, 2025 at 7:18 PM
    b.a.
    b.a. [OP] Member
    Saturday
    1997 4wd 2.7l tacoma
    Hey yall, im doing a kind of nightmare repair, having to redo my head gasket and timing kit job myself because the person who repaired it cranked the harmonic balancer on without fitting the key into the slot, cracked the balancer, mushed the key a little and pushed it back.
    Anyway, trying to get the key out of the slot, ive tried hammering a punch, chisel, using wire cutters and vice grip wrenches, even tried to start drilling for a screw extractor bit but it was too scary in terms of sliding off and scratching the crankshaft.
    Im not sure how much force is ok to use w the mallet, or how much heat would be ok.
    If yall have any advice i could really use it.
  2. Apr 28, 2025 at 7:46 PM
    02hilux
    Planet: EARTH
    I would put a small piece of wood under the shaft and use a c-clamp. Applying pressure to the raised half moon to see off it will break loose.
    ControlCar likes this.
  3. Apr 28, 2025 at 7:56 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I find that getting them to rock or slide in the groove helps get them loose.
    Grind a flat, then take a punch and peck it backwards.
    You want to get it to pivot and rock. Once it starts moving, you got it.
    Me.....I'd likely take a heavy duty flat blade or chisel and trying sticking it between the gear and key and prying it out.
    But you don't want to mar up the crank snout either. So I can't say you should do that.
    Care needs to be take if you do that.....
    Grinding a flat is my best advice.
  4. Apr 28, 2025 at 7:57 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    I know you can’t but engine/front clip in the freezer…..
    but I would try cold not heat
    Cold will contract metal not expand
    brake cleaner comes out cold
    Maybe a Coleman stove small green propane tank
    A sacrificial ice pack to wrap around the area?
    After getting the metal colder, Hilux wood/c clamp idea looks good
  5. Apr 28, 2025 at 7:57 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Usually you can catch the edge of them with a good sharp chisel like this and knock them up out of the keyway.
    ControlCar and TnShooter like this.
  6. Apr 28, 2025 at 8:04 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If they aren't too tight that works but if they are stuck you typically just end up flaring it out more and making things tighter.
    If you can get it a position where you can hook it with a chisel you can usually pop them out with minimal damage to the key unless they are really stuck.
  7. Apr 28, 2025 at 8:07 PM
    TnShooter
    Deogee
    STOCK
    This is the internet. :rofl:
    Me? I'm pounding a flat blade screwdriver down in the "gap" and prying.
    But, again. This is the internet.
    Next post would be, "I fucked up my crank following your advice".
    So, I played it safe. :thumbsup:
    rish57, ControlCar and Dm93[QUOTED] like this.
  8. Apr 29, 2025 at 2:47 AM
    Black97v6MT
    Black97v6MT 364k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    27+ years of livin' Gen1 TacoLife...
    U think using some freeze-shock action would do it
    how about this product? i have used this in the past for a seized fuel line 'coz ya don't want heat that up lmao
    leid, Moonrman and ControlCar[QUOTED] like this.
  9. Apr 29, 2025 at 4:52 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    What dm93 said,
    Get rid of the mallet & use a real ball pean metal hammer, metal framing hammer, etc....
    You using a mallet may be your main issue.
    Hammer down on the back of it so it raises the front, then angle the chisell on the front of the crank & start slamming...
    Hit it like a man!!!!:D:muscleflexing:
  10. Apr 29, 2025 at 3:35 PM
    ControlCar
    Steven
    Sugar Land TX
    never heard of
    Thanks for tip!!!!!!!!!!!!!
    Black97v6MT[QUOTED] and Moonrman like this.
  11. Apr 29, 2025 at 4:27 PM
    ControlCar
    Steven
    Sugar Land TX
    BA…..
    Great thing about here you get a plethora of ideas…….and can combine them to use in your solution
    that freeze spray AND precision tapping on W key
    use a spring loaded center punch on either end of the flat portion of W key
    Hit the bottom of crank (w key on top) with freeze spray
    Then precision tap both ends of w key where you center punched
    (Like a rocking horse)
    think that’s the ticket
  12. Apr 29, 2025 at 7:21 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    When you all buy a new HB....take a file and take the forward sharp edges off the keyway
    you wont hurt the damn thing at all
    This happens a lot with Toyotas.........I would even polish and lube the crank before mounting
  13. Apr 30, 2025 at 9:09 AM
    b.a.
    b.a. [OP] Member
    Saturday
    Thank you all!!!! I got it !!!! Now to set the timing ‍
