stud and lug nut both spinning.... HELP
Discussion in 'Wheels & Tires' started by blacksheff405, Jan 16, 2012.
  1. Jan 16, 2012 at 11:29 PM
    blacksheff405
    blacksheff405 [OP] no one ever pays me in gum
    caleb
    north carolina, concord
    02 dbl v6 12' lift on 38's
    lift kit (12'), super swampers 38's, brush gard, kc's , sub, amps, high end audio equipment
    ok so I was trying to rotate the tires when on one of my wheels I came across to like this on the same wheel. well for the last idk 3-4 hours i've been drilling the piss out of them trying to break the nut off so far ive been through about 5 bits and only have one off and the second one just refuses to come off i don't know if i'm just doing something wrong or is there another way to get it off i'm tired and got to finish it tonight and I NEED HELP!!!:help::pccoffee::frusty:
  2. Jan 16, 2012 at 11:32 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    take a mototool (dremel) and cut a slit along the lug nut parallel to the lug. it should relieve the pressure on the nut. An air chisel would be easier if you have air tools
  3. Jan 16, 2012 at 11:35 PM
    blacksheff405
    caleb
    well the problem is everyone else is asleep and i'm using my dads tools i thought about using a dremel to cut like one side off and then just pryinging the rest of it off you think that will work?
  4. Jan 17, 2012 at 12:01 AM
    Yoytoda
    Roland
    completely stock
    thats kinda what i meant. even if you only cut one side it will relieve pressure and you can spray with pb blaster or wd40 and let it soak a while. cut two slits 180 from each other and pop the halves off with a screw driver...
  5. Jan 17, 2012 at 2:20 AM
    blacksheff405
    caleb
    thanks for the advice man i finally got it off after almost 5 hours. ha ha.
    man eventually i just beat the piss out of it with a hammer and it broke off FINALLY!!
    i was about to go:goingcrazy::goingcrazy:
  6. Jan 17, 2012 at 5:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I was going to say, as a last resort a BFH works :D or a big breaker bar to snap off the studs.
  7. Jan 17, 2012 at 7:51 AM
    blacksheff405
    caleb
    well i kept using a tire iron at first and then it got to the point i bent the damb nut so much there was nothing to hold on to anymore.. but thanks again for the help guys i was up till 330 getting that tire off and had to be up to go to class today at 9.
