Stud length?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chablo, Sep 25, 2019.
  1. Sep 25, 2019 at 12:27 PM
    Chablo
    Chablo [OP] Well-Known Member
    North Central, FL
    2017 Tacoma TRD Sport RWD V6 DCSB
    Just put a lift and a set of vision nemesis 17x9 -12 on my 17 TRD sport rwd. The stud length makes me a bit nervous. Anyone running this wheel setup? Any problems? Can the studs be changed to longer studs?
  2. Sep 25, 2019 at 12:34 PM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Check to see if Gorilla brand offers ET lug nuts for your wheel. ET stands for extended threads
    Chablo[OP] likes this.
  3. Sep 25, 2019 at 12:38 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I'm 5'11".
    TAC1, hiPSI, beergeek and 5 others like this.
  4. Sep 25, 2019 at 12:39 PM
    Trucknorris
    Trucknorris Well-Known Member
    2017 sr5 double cab 4x4
    Several
    Yes i did it factory studs are too short for some aftermarket wheels
  5. Sep 25, 2019 at 1:07 PM
    swissrallyman
    swissrallyman Well-Known Member
  6. Sep 25, 2019 at 1:09 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    You can get extended thread lug nuts that reach deeper in the hole for extra thread grabbing. OR you can swap out the taco studs for Camry(?) studs which are a fair bit longer.
    Dang, beat me to it.
    juandirt and StayinStock[QUOTED] like this.
  7. Sep 25, 2019 at 1:54 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Have to be careful with the ET lug nuts. They will only work if the wheels that have holes large enough to accommodate the ET portion of the nut.
    Found out the hard way they wouldn't work on my Venomrex wheels.
    I ended up swapping studs.
    Gunshot-6A[QUOTED] likes this.
  8. Sep 25, 2019 at 2:21 PM
    Chablo
    North Central, FL
    jmneill likes this.
