Studder(near stall)when accelerating from a stop?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheOtherGuy, Jul 25, 2010.
  1. Jul 25, 2010 at 11:54 AM
    TheOtherGuy
    TheOtherGuy [OP] Well-Known Member
    Cajun Country
    05 Access 4x4
    2005 4x4 53,000 mi automatic V6
    My truck has developed a studder recently. It happens when I try to accelerate from a stop. It feels and sounds like the truck is about to stall for about 1 second or less then it begins to operate normally after that.
    Has anyone else had this issue? Do you have any ideas as to what could be causing this?
    I have already tried running some fuel injector cleaner in the gas.
  2. Jul 25, 2010 at 12:07 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    sounds like it may be a clogged fuel filter.
    you could also try bringing it to an auto parts store(sometimes they have a scanner that they will let you use).
  3. Jul 25, 2010 at 12:10 PM
    Griztaco
    Griztaco Well-Known Member
    ID
    TRD
    Could be some water in the gas tank or gas lines, try adding some fuel additive that is specifically made to get rid of the water.
  4. Jul 25, 2010 at 12:36 PM
    rhodehard09
    tampa, fl
    x2 yeah good call now that our gas has so much ethanol in it, it will absorb water more quikly. has your truck been sitting for a while?
  5. Jul 25, 2010 at 12:50 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Agreed...sounds like a fue/air mixture problem and/or a lean misfire. You may be approaching time for new plugs too?! I think the stock plugs last 100k mi (at least on my 4-cyl), but I changed them around 60k anyway. Gives a good opportunity to "read" the plug and see how your engine's running.
  6. Jul 25, 2010 at 12:58 PM
    TheOtherGuy
    Cajun Country
    05 Access 4x4
    No the truck has not been sitting.
    I'll check into the fuel filter and the additives.
    I just checked my maintenance history and it looks like the previous owner had the spark plugs changed at the dealer at around 35000mi. So these plugs only have about 180000mi on them.
  7. Jul 25, 2010 at 12:59 PM
    rhodehard09
    tampa, fl
  8. Jul 25, 2010 at 1:03 PM
    TheOtherGuy
    Cajun Country
    05 Access 4x4
    I just read up on the fuel filter and found out that it is inside the gas tank and difficult and expensive to replace. I really hope that isn't the issue.
  9. Jul 25, 2010 at 1:10 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    What gas are you using? Try using quality gas like QT or Chevron 91 for a tank and see if it starts to clean up.
    Also, i4 or v6? Even if they did change the plugs, that doesn't mean they're good now. I'd inspect them myself (very easy to do just need a few hours and the tools if you've never done it before). Plugs are dirt cheap (like 16 bucks after tax I think?).
    Also check your air intake filter... make sure it's not dirty. Start with the basics then go for more...
  10. Jul 25, 2010 at 1:36 PM
    TheOtherGuy
    Cajun Country
    05 Access 4x4
    Thanks for the advice everyone. I have a couple of things to try now. Hopefully one of these things or all of them combined can fix my problem.
  11. Jun 25, 2012 at 1:31 PM
    TheOtherGuy
    Cajun Country
    05 Access 4x4
    Just a follow up to my original post. I think I just got some bad gas somewhere because the problem went away on its own after refueling.
