Studs Cutting Slots in Drums
Discussion in '1st Gen. Tacomas (1995-2004)' started by kevinwf, Sep 13, 2025 at 11:25 AM.
  1. Sep 13, 2025 at 11:25 AM
    kevinwf
    kevinwf [OP] Member
    Kevin
    1999 Tacoma XtraCab 3.4L TRD
    I have a 1999 Tacoma TRD DLX that I was attempting to pinpoint some bearing noise on this morning. When I took the rear wheels off I discovered that the studs are cutting slots into the drums.
    Could this be due to improperly fitted wheels preventing the lug nuts from properly clamping the drum to the hub? The truck, which is new to me, has 16" Toyota rims off another vehicle.
    Or could the incorrect drums be installed?
    Other ideas for the cause of this wear?
    Once I figure out the cause and remedie, I assume it would be ideal to replace the studs, drums (of course) and lug nuts. Anything else?
  2. Sep 13, 2025 at 11:32 AM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Never have seen “slotted” drums before
    But
    Think tht is your problem
    at the top off each slot, the end of the slot has been wallered out by movement of each wheel stud
    get some correct drums
    t0p_d0g likes this.
  3. Sep 13, 2025 at 11:40 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Loose bolts looks like it's been doing the for awhile.
    ControlCar and ZColorado like this.
  4. Sep 13, 2025 at 11:41 AM
    kevinwf
    kevinwf [OP] Member
    Kevin
    I haven't ever seen slotted drums before either and assumed it must be wear.
    ControlCar[QUOTED] likes this.
  5. Sep 13, 2025 at 11:45 AM
    Red_03Taco
    Red_03Taco @ the Taco Shop
    Jerad
    Yavapai County, AZ
    2003 Tacoma Xtra Cab 4WD
    Eaton E-locker (rear), Alcan Leafs, Toytec 2.0s (rear), Icon 2.5s (front)
    How do the shoes look under the drums? I'd probably add new shoes and potentially new brake hardware to your list of items to replace
    t0p_d0g likes this.
  6. Sep 13, 2025 at 11:52 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Thats a VERY clear sign of loose lug nuts, also could be a bad hub to wheel interface too.
    Toyota wheels are typically hub centric, meaning the hub, not the lug nuts is what centers the wheel together.
    Those slots are clearly indicating the wheel was not tight against the drum. It looks like old damage though. New damage would leave bright metal showing.
    The clamping force of the lug nuts does most of the work, not the side load on the lug studs.
    BabyBilly likes this.
  7. Sep 13, 2025 at 12:21 PM
    ControlCar
    Steven
    Sugar Land TX
    Look closely at any of the slots
    One side is larger bc of movement
    Other side is perfect curve from machining, also can see dirt/debris
    Only making slot larger on one side
    agree with Zcolorado
    Both wrong drums and loose lugs are contributing to the problem
    ZColorado likes this.
  8. Sep 13, 2025 at 12:27 PM
    ZColorado
    13 DCSB OR 6MT
    These aren't the wrong drums.
    There is no bright metal in the stud slots, this is an old problem.
    ControlCar likes this.
  9. Sep 13, 2025 at 12:31 PM
    ControlCar
    Steven
    Sugar Land TX
    I’m using wrong adjective sorry
    Modified Drums?
    100% way in the past
  10. Sep 13, 2025 at 12:41 PM
    kevinwf
    kevinwf [OP] Member
    Kevin
    I'll be replacing the brake shoes and hardware. I have a leaking axle seal on the driver's side and the passenger side pads are heavily glazed.
    Red_03Taco[QUOTED] likes this.
  11. Sep 13, 2025 at 12:43 PM
    kevinwf
    kevinwf [OP] Member
    Kevin
    Meaning in the past someone didn't tighten the lug nuts properly? On both rear tires? And this lead to the damage?
    So, I should replace the drums and make sure to torque the lug nuts correctly and everything should be fine.
    ZColorado[QUOTED] and ControlCar like this.
  12. Sep 13, 2025 at 2:39 PM
    ZColorado
    13 DCSB OR 6MT
    Correct on all points here. Except only loose lug nuts on the side with the slots.
  13. Sep 13, 2025 at 2:46 PM
    BLT2GO
    BLT2GO Well-Known Member
    2011 White Tacoma TRD TX
    Just a thought but are you using the correct lug nuts for the wheels? Maybe that is what was preventing the wheel from clamping the drum correctly.
  14. Sep 13, 2025 at 3:14 PM
    kevinwf
    kevinwf [OP] Member
    Kevin
    Both rear drums show the same slots.
  15. Sep 13, 2025 at 3:15 PM
    kevinwf
    kevinwf [OP] Member
    Kevin
    I am not sure. Just using the lug nuts that came on the truck. They appear to be lig nuts for hub centered wheels, meaning the nuts themselves do not have a taper to them.
  16. Sep 13, 2025 at 4:12 PM
    ZColorado
    13 DCSB OR 6MT
    those wheels are fine, I bet the PO used the wrong wheels at one point and never got the wheel against the drum. It takes a LONG game to get that much damage. Like you would be listening to loud clanking every time you break for a week.
    I believe those alloy wheels need these
  17. Sep 13, 2025 at 4:21 PM
    kevinwf
    kevinwf [OP] Member
    Kevin
    Those nuts looks pretty much identical to the ones I have currently. I'm beging to think the damage happened and the OP just decided to run the worn drums anyway.
    BLT2GO and ZColorado[QUOTED] like this.
  18. Sep 13, 2025 at 4:39 PM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Just replace both drums, brake shoes with new hardware tbs. It might be a good idea to get new lug nuts also. JMHO
    Who knows when it happened or how just correct it. You just never know what you will run across with a used purchase.
  19. Sep 13, 2025 at 4:42 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    If the drum moved that much, the studs/threads in the contact area should be shaved down. Got any pictures of the studs?
  20. Sep 13, 2025 at 4:57 PM
    Red_03Taco
    Jerad
    Yavapai County, AZ
    Good point. It almost seems that driving it long enough to waller out those holes into slots would be enough to break off one or more of the studs
