Studs Cutting Slots in Drums
Discussion in '1st Gen. Tacomas (1995-2004)' started by kevinwf, Sep 13, 2025 at 11:25 AM.
  1. Sep 13, 2025 at 5:52 PM
    notrouble
    notrouble Well-Known Member
    western Washington
    2004 single cab 2wd
    The thought running through my head is that they installed some wheels with a smaller hub bore than the rear axles. So they tightened down the lug nuts, but not against the brake drum. Cast aluminum wheels are pretty rigid, so it seemed tight and centered on the studs good enough to drive OK. The problem was that the brake drum wasn't being held secure so every time the brakes were used the studs cut a little into the drum.
  2. Sep 14, 2025 at 9:54 AM
    kevinwf
    kevinwf [OP] Member
    Kevin
    1999 Tacoma XtraCab 3.4L TRD
    I had the same thought and examined each one. Clean threads not sign of damage to the studs at all.
  3. Sep 14, 2025 at 9:56 AM
    kevinwf
    kevinwf [OP] Member
    Kevin
    I had the same thought and examined each one. Clean threads not sign of damage to the studs at all. Maybe all the studs were replaced and for some reason they just decided to keep the drums.
  4. Sep 14, 2025 at 9:57 AM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    No one will ever know except the previous owner.
    ControlCar, ZColorado and kevinwf[OP] like this.
