Stump removal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Signatureinc, Jun 25, 2022.
  1. Jun 25, 2022 at 4:18 PM
    Signatureinc
    Signatureinc [OP] Well-Known Member
    Doug
    Flat Land, Ontario
    2019 TRD OR Access Cab
    Hey you guys,
    Would you guys ever pull out 4-6” tree stumps/trees with your rigs with a chain around the hitch
  2. Jun 25, 2022 at 4:24 PM
    gfk
    gfk Well-Known Member
    I paid a stump grinding service $250 to come grind up a few larger stumps as well as a few smaller ones. One of the best ways I have just "spent the money instead of trying to do it myself." The guy had it done in 30 mins. I think the answer to your question is that it would depend on the root system for said stump and how extensive it could be.
    ConantTaco, Shades_Of_Red and Chew like this.
  3. Jun 25, 2022 at 4:26 PM
    slowpoke16taco
    slowpoke16taco Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
    Be sure to record it for us :goingcrazy:
  4. Jun 25, 2022 at 4:32 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Not a chance!
  5. Jun 25, 2022 at 4:36 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Don't use a nylon strap that stretches...
    That's why there are logging chains.
    JGO, Tnc and Otterstuff like this.
  6. Jun 25, 2022 at 4:38 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    $250 for multiple stumps being ground up is a great deal, Ive rented the larger home depot stump grinder for one day and it was around $150 and took a few hard hours, I like doing yard work but paying an extra $100 for someone else to do it would defiantly be worth it for me.
    As long as you cut most of the large roots I would be ok using the tacoma to pull out a 6 inch stump.
    Signatureinc[OP] likes this.
  7. Jun 25, 2022 at 4:44 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I used my old pickup to pull one. But, I dug down to cut the majority of roots, used a chain, one wheel/tire to leverage the stump upwards, and another 3/4 the way to the stump from the truck with the chain run through it to hold the chain down if it slipped or the stump popped out quickly. Worked fine for me.
  8. Jun 25, 2022 at 4:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, but I dug around the roots first and cut the ones up close I could get to.
    And they were NO larger than probably 6”.
    I’d say it was 50% dig and cut. 50% pull.
    And absolutely don’t use the ball.
    Take the ball off, or use a pull hook.
    The ball can become a cannon.
    JGO and Signatureinc[OP] like this.
  9. Jun 25, 2022 at 4:55 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Never use the ball hitch for this. Also use chains not a rope or recovery strap. Use a makeshift weighted line damper to prevent flyback. Also dig around the stump and use a water hose around the roots to expose and free the roots from the dirt surrounding them with the water. And actually you should use the front of the truck and reverse it. Reverse is a super low gear and it's how recovery of vehicles are supposed to be done.
  10. Jun 25, 2022 at 5:07 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    We used to do it using come-alongs (cable ratchets), digging and cutting as many roots as possible. Never took any damage.
    JGO, TnShooter and Signatureinc[OP] like this.
  11. Jun 25, 2022 at 5:09 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
  12. Jun 25, 2022 at 5:23 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    That's what they make back hoes for.
  13. Jun 25, 2022 at 5:23 PM
    joeyv141
    New Jersey
    Using a come alongside is a good idea, still dig and cut as many roots as possible.
  14. Jun 25, 2022 at 5:29 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Hell fuckin no. /thread
    Edit: with pulley systems and change of direction pulls, yes. But get smart about it first.
  15. Jun 25, 2022 at 5:32 PM
    stevesnj
    Actually looking back at the size just use a HiKift or farm jack with a chain and use a 4x4 post to span the width of the root and pop it up that way. For some reason I was thinking bigger as I'm used to pulling out 10" plus stumps with a truck when I worked for a tree service,. If you have a HiLift
    https://youtu.be/uZ0eNIuuo6g?t=54
    JDKred, CodeSeven, JGO and 1 other person like this.
  16. Jun 25, 2022 at 5:33 PM
    Bob1971
    Bob1971 Well-Known Member
    Tim
    KY
    White 2020 Trd OR
    Bed cover, step bars, SCS SR8 wheels
    Nope too much work. I bought a chemical that will make it rot over the winter. Drill holes in the stump and pour the powder in and be patient. I was mowing around one this spring and my deck caught it and the stump crumbled. Fairly easy work.
  17. Jun 25, 2022 at 5:37 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The Asshats that ran a stump grinder here last Summer managed to get into the propane line, thankfully they didnt blow up my house.
  18. Jun 25, 2022 at 5:38 PM
    bush rat
    bush rat Well-Known Member
    BC
    2022 6MT Access Cab
    if you will be pulling try to leave the stump longer (3ft+) to gain leverage.
    ps-loved the video taking out the back windows.
  19. Jun 25, 2022 at 5:50 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Amateurs.
    Place an old tire around stump. Fill tire with diesel/gas mixture. Set on fire. No more stump.
    dnlskier, joeyv141, Chew and 3 others like this.
  20. Jun 25, 2022 at 5:52 PM
    HIallday
    HIallday Well-Known Member
    Hilo
    2019 TRD OR
    We need pictures of said stumps!
    :worthless:
    JDKred likes this.
