Stumped - 12V LEDs install
Discussion in 'Lighting' started by BassMaster06, Dec 6, 2010.
  1. Dec 6, 2010 at 6:09 PM
    BassMaster06
    BassMaster06 [OP] Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    Alright, I've installed bed lights on a switch successfully so I figured I'd try my luck with a set of LED's to put inside the cab. I bought a set of blue LEDs very similar to the picture above at Advance Auto. I got home and opened up the package and checked out the wires.
    I'm no electrician, but there is a small black wire coming from the module. At the end of it, it is cut with even smaller black wire and red wire inside. I stripped the two ends of these 2 wires and revealed the actual wire itself, which was 3 or 4 strands of "hair" like wire. STUMPED. How do I power these safely??? I figured somebody could help me out, I searched for a little bit but couldn't come up w/ anything similar to this. Thanks
  2. Dec 6, 2010 at 6:46 PM
    BassMaster06
    Dan
    South Carolina
    Man you've been helpin me out a lot lately...haha. What gauge of wire should I use? And do I need a resistor for these?
  3. Dec 6, 2010 at 6:56 PM
    BassMaster06
    Dan
    South Carolina
    alright thanks man, and again i appreciate the help....i'll give it a try!
  4. Dec 6, 2010 at 7:47 PM
    BassMaster06
    Dan
    South Carolina
    Out of curiosity, Why are the wires so small?!? It's alright to solder these tiny wires to 18 Ga wire? Idk, I tried to wire these up the other night, and it blew the 10A inline fuse up close to the battery...Im trying to figure out why, and I figured it was because I was connecting large wires to tiny wires. What would cause the inline fuse to blow? Maybe I wired it up wrong on the switch? Wrong size of inline fuse (10A)? Maybe a combination of mistakes?
    Here is a diagram of how I wired them up.
  5. Dec 7, 2010 at 5:34 AM
    BassMaster06
    Dan
    South Carolina
    Its an oznium illuminated switch, and I may have had it wired up wrong because i just guessed when i did it (dumb) cuz I didn't have a diagram. I found the switch diagram on the oznium website so I should be good to go there. I don't have a meter to check it. Is a 10A fuse alright to use as the inline fuse?? Or should I go higher or lower? Thanks for bearing with me and my poor knowledge on electrical stuff.
  6. Dec 8, 2010 at 10:52 AM
    BassMaster06
    Dan
    South Carolina
    anybody? Trying to wire up 2 - 6 LED glow pads (12V). Using 18 Ga wire....What size inline fuze?
  7. Dec 13, 2011 at 10:51 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    Looks correct to me. Although I am no electrician lol. My guess is maybe one of the wires inside where you stripped could possibly be touching, causing it to short. I had a problem similiar with a trailer I built. It kept blowing the fuse for my trucks running lights.
    pissed me off...
    If not then maybe the power wire could be touching a grounded piece of metal somewhere. I don't know much about diodes and resistors and all the mumbo jumbo.
