Stumped by trailer wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Biggerdog, Jul 1, 2019.
  1. Jul 1, 2019 at 5:36 AM
    Biggerdog
    Biggerdog [OP] New Member
    Pop-up camper wiring (7 pin) works perfectly on my son-in-law's Dodge Ram. Nothing lights up on my other son-in-law's 2008 Tacoma OR my nephew's Tacoma. I did notice that the Ram and trailer needed to be hooked up to complete proper ground. Could this be a clue to Tacoma issue and how do I fix?
  2. Jul 1, 2019 at 5:39 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Check the fuses for the tow package in the fuse block under the hood. Also look at the tacoma's plugs if they are corroded badly then could not be getting a good connection. Make sure the plug is all the way in seems simple but seen that before.
  3. Jul 2, 2019 at 5:03 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    If ram had to be actually hooked to the ball to get lights on then the 7 pin probably has a bad ground pin as noted above so clean the 7 pin plug connectors (fine sand paper or 3M pad cut to fit in on a screwdriver blade or such). Use a multimeter to verify a good ground and check the other connectors for hot - need the correct pinout.
    Tacosail likes this.
  4. Jul 2, 2019 at 6:32 PM
    KickAss
    KickAss Well-Known Member
    Chuck
    Florida
    2015 Limited 4x4 DCLB
    Big body sittin on chrome
    you need to be hooked to the ball, grounds the connection, then you should be fine
  5. Jul 2, 2019 at 6:37 PM
    Muddinfun
    Muddinfun Well-Known Member
    ^ Bad advice. You should NEVER rely on the ball for a ground connection.
  6. Jul 2, 2019 at 10:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This ^^^^^^^^^^
    That is what the wire is for in the harness. If the trailer is wired this way it is wrong.
    Muddinfun[QUOTED] likes this.
  7. Jul 3, 2019 at 2:00 PM
    KickAss
    Chuck
    Florida
    yes that's correct the circuit between the truck and trailer needs to be grounded. The battery is grounded to the truck, so to complete the circuit, the trailer needs to either be hitched to the truck or grounded through the plug to the truck. I agree that that's not the correct way to solve the problem but if it does for some oh well.
  8. Jul 3, 2019 at 2:06 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    As others have said, check the ground wire on the trailer side. Most likely it is corrosion at the plug, but could also be the ground wire connection at the trailer frame.
  9. Jul 3, 2019 at 3:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Where is the WHITE wire connected to on the camper side of the harness?
    Also, do you you have access to a test light?
