Stupid 4WD question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaw154, Sep 30, 2010.
  1. Oct 13, 2010 at 9:11 PM
    #41
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    It's not a good idea to run on dry (or even wet) pavement for extended periods of time, but for the few miles/minutes Toyota recommends each month, it's more than fine. These vehicles are so much tougher than people think. My 1986 4Runner with part time 4wd would wind up from time to time on pavement or hardpack or even when the snow was a dry packed powder, but I never broke a thing, and my Tacoma doesn't come close to winding up as much ever.
  2. Oct 13, 2010 at 9:54 PM
    #42
    everleet
    everleet Well-Known Member
    NY
    07 SR5 TRD Off Road
    thanks to everyone for now making me paranoid of 4wh. what about snowy, paved roads?
  3. Oct 13, 2010 at 10:00 PM
    #43
    JanBoothius
    JanBoothius Well-Known Member
    Jan (Pronounced Yon)
    Upstate New York
    2015 TRD OR DCSB 6 speed
    Heavy stuff big tires drives like hell
    If the road has snow on it, you are fine in 4wd (high or low) on pavement.
    On dry pavement (or rainy-but-still-grippy-pavement) that you should be in 2wd, and nothing else.
  4. Oct 14, 2010 at 6:46 AM
    #44
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    im sorry u are absolutely giving him miss information. you can not use 4x4 on DRY pavement. in order for 4x4 to operate safely the wheels need to be able to slip some. and it can not on dry pavement.
    Just curious why would u need to put it in 4wd on pavement anyway???
  5. Oct 14, 2010 at 7:01 AM
    #45
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
  6. Oct 14, 2010 at 7:08 AM
    #46
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    Same here, I have used my 4x4 on pavement, but not 4lo. I would say to stay away from running your 4x4 on dry roads. I have never had to engage on dry pavement but on wet I have and snow of coarse. JOE>
  7. Oct 14, 2010 at 9:53 AM
    #47
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    You'd probably actually be better off putting it in 4lo than 4hi on dry pavement. The much higher torque would equate to more wheel slippage than drive line binding.
    Either way, that's like saying shooting soda into your brain via a syringe is a better alternative to shooting draino into it.
  8. May 1, 2011 at 6:07 PM
    #48
    Goober
    Goober Earthlings are fun to watch!
    Utah - Why just have only one?
    '11 TRD Off-Planet AccessCab
    From Toyotas Website "4WD can be part-time (low traction conditions only) or full-time (may be used on dry roads)."
  9. May 1, 2011 at 7:40 PM
    #49
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    The owner's manual does not, to my knowledge, have any warning that using 4wd on dry pavement may cause damage. In addition, it recommends using 4wd once a month with no notice that you shouldn't do it on dry pavement.
    I'm not saying using 4x4 on dry pavement is a good idea, just pointing out that those who say "read the manual" are not supporting their argument that it's a bad idea.
  10. May 1, 2011 at 8:01 PM
    #50
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    I was just about to post the same exact thing! i.e., "Don't use 4wd on dry pavement unless your name is aswerty and you are trying to get to 105 in 12 seconds" :p
  11. May 1, 2011 at 8:34 PM
    #51
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    Everyone should just put their truck in 4H on pavement, while stopped turn the wheel to full lock(left or right, your choice)... and nail the gas!
    Edit: I claim no responsibility for any damages that do or do not occur as a result of proving that running 4wd on
    pavement will not damage your truck.
    luk8272 likes this.
  12. May 1, 2011 at 9:40 PM
    #52
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    I can't believe there is still discussion on this haha.
    You know when you lock your diff and turn, the one tire slips and chirps? That is because the wheels need to spin at different speeds, but can't.
    The EXACT same thing happens front to back. It is just a big fat chain engaging the front wheels. There can be no discussion on this. You are putting massive strain on your transfer case using 4wd anywhere the tires have a good grip and are unable to slip. Many people have smashed their cases right open doing this.
    Anyone's crappy anecdotal evidence of this saying they do it and it's ok just haven't broken their truck yet. It is only a matter of time and turning enough with enough tire grip.
    This is the final answer: DON'T DO IT. If you want to do it a bit going straight to keep stuff lubed, so be it, but NEVER turn.
    This is simple physics guys, something has to give. There is no front to back differential. It will slip at the tires, or your tcase will explode.
    http://rubicon-trail.com/4WD101/driveline-bind.html
    Please any of you stupid enough to keep doing this, just keep quiet about it. Some poor guy is going to listen to you as if you know the first thing about mechanics, and wreck his own truck.
  13. May 1, 2011 at 10:49 PM
    #53
    DevL
    DevL Well-Known Member
    Lol at blowing up the transfer case... u joint wear... sure. Over a year on the Tacoma with 4x4 in the wet... will give annual updates .
  14. May 1, 2011 at 11:13 PM
    #54
    DevL
    Remember the slick rock in moab stickier than concrete... that's why noone runs 4 wheel drive on moab slickrock... I love the internet theory guys that have never seen it happen in real life. Can you post me another link to refute my years of experience to the contrary?
  15. May 1, 2011 at 11:23 PM
    #55
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Agreed
  16. May 2, 2011 at 12:39 AM
    #56
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    You been to Moab?
    :rolleyes:
    and yes chances are your transfer case won't catastrophically fail but it's quite possible. Something has got to give, and in most cases its going to be your tires slipping, especially on these "wet" surfaces.
  17. May 2, 2011 at 4:49 AM
    #57
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    X2. If you think 4WD on dry surfaces wont hurt your truck, then feel free to be our guest and do this ^ and please, record it! :D
  18. May 2, 2011 at 5:14 AM
    #58
    52419
    52419 Well-Known Member
    someplace
    03 tacoma lifted 6in on 35s
    fabtech 6in lift, 35.12.50.16s,on mt classics
    im sorry but if you nedd 4wd to get threw a little rain .......................... come on nowdo you belong in a taco or a prius ?
  19. May 2, 2011 at 7:14 AM
    #59
    anethema
    J
    Dawson Creek,BC
    DevL just check out the link in my post. Has pictures of what happens to a transfer case if the tires can't slip.
    Agreed, usually the tires slip, but like you said, much more stress on the driveline, incl ujoint wear, spline wear, chain stretch, etc. But if your tires are too sticky, your transfer case fails. How exactly do you think it works when the front has to spin faster than the rear? Where do you believe the give happens?
  20. May 2, 2011 at 8:13 AM
    #60
    Goober
    I just discovered this in my manual about using 4WD once a month and noticed the manual doesn't say "Don't drive on dry pavement". I'm not a newbie to 4WD vehicles, this is my sixth, two of which were AWD. I checked TW to see if anything was posted on the subject and found this thread. The only reason I resurrected this thread was because no one bothered to check the Toyota website for an answer. Which does say "Don't drive on dry pavement". I don't see why there's any arguement when Toyota say's don't do it.
    I never did that with my Chevy's, although my wife went on a cross country horse race driving support for a friend when the Chevy was new and forgot she had it in 4WD one morning and drove for 2hrs pulling her horse trailer on dry pavement before realizing it. I was a bit pissed when she told me but nothin' ever broke and we had that truck for 15yrs. The 90's Chevy models had the front geared slightly higher than the rear. States that in the manual. For me the requirement for 4WD once a month just means "honey, I need to go 4 wheelin', bye".
