Stupid Noob Question #344: Matching Tire Width to Rim Width
Discussion in 'Wheels & Tires' started by 28ØØ3, Jun 16, 2009.
  1. Jun 16, 2009 at 5:49 AM
    28ØØ3
    28ØØ3 [OP] Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
  2. Jun 16, 2009 at 5:59 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    ok if i understand what your saying
    you want to use a 17x9 rim with a 265/70t17 tire
    NO dont do it
    its not safe
  3. Jun 16, 2009 at 7:15 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
  4. Jun 16, 2009 at 7:41 AM
    usctacoma
    usctacoma Be a thinker, not a stinker
    Columbia, South Carolina
    05 PreRunner SR5 Doublecab
    Tint, Black Badges, Firestone Destination 265-70-17s, Weathertech Floor Liners, Sockmonkey decals, Flowmaster 40, Defiant light bar, 4 5" PIAA 540s, BHLM, 5100s @ .85, eibach springs, 1/4" Toytec spacer, 2" Toytec AAL, painted grill, UWS tool box
    Im running 265/70/17 with 17x9 rims and I don't have any problems. I didn't even look at what the manufactuer said what size rims it would fit. Shouldn't all 265/70/17 tires be the same size?
  5. Jun 16, 2009 at 8:14 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What tire pressure are you running at?
    Did you do a 'chalk test'?
  6. Jun 16, 2009 at 8:21 AM
    Janster
    Jandy
    Lancaster, PA
    Most of your rim widths are going to be slightly smaller than the tire width.
    For instance - most 1st gen tacomas run with 7" wide rims and have 31"x10.5" tires.
    15x9" rim is a bit on the large side.
    I run 15x8" on my Jeep and I have 35x12.50" tires on them at 30psi.
    A 17x8" would be ideal to run all sorts of different tire combinations. You gotta have the proper backspacing also.
  7. Jun 16, 2009 at 8:44 AM
    usctacoma
    to be honest, i have no idea, but i should probably check huh?
  8. Jun 16, 2009 at 9:23 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    What tires do you have? Maybe your 265/70/17 tires are made to fit a 9" wide rim? Some are, some only go to 8.5".
    This is a great question too. It seem slike 17x9 are really popular, but tires such as the BFG TA/KO and KM 2 say the recommended rim width is 7"-8.5" for a 17" tire.
  9. Jun 16, 2009 at 9:29 AM
    usctacoma
    I have Firestone Destination ATs
  10. Jun 16, 2009 at 9:39 AM
    David Tarantino
    N.J.
    08 tacoma
    guys iam just saying i have been doing tires/wheels for 30pl yrs
    damn thats a long time :D i feel old now :eek:
    anyway how i feel is yes it can be done
    just dont feel thats its safe :D
  11. Jun 16, 2009 at 9:50 AM
    STLTaco09
    Those have a 7"-8" rim width recommendation. Interesting.
    Why do you feel it is unsafe? I'm not disagreeing with you, I just want your thoughts behind this. Obviously the manufacturer put those recommendations there for a reason, just like the speed rating. But what risks are you running if you run a 9" wide rim on a tire that recommends an 8" or 8.5" max rim width?
  12. Jun 16, 2009 at 10:10 AM
    David Tarantino
    N.J.
    08 tacoma
    it is possible that the tire can come off the wheel
    now iam not saying that it will happen but it can
    and iam sure that there are sum out there doing it and
    nothing has happened i hope it never does
    but you need to go to a bigger tire to get more with
    for the tire to mount on the wheel
    :D
  13. Jun 16, 2009 at 3:05 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    So if I'm looking at 18x9 rims to go with some 275/70/18's that say will take up to a 9" rim I'm fine right? Just as long as I follow the tire manufacturer's spec's?
  14. Jun 16, 2009 at 3:23 PM
    Janster
    Jandy
    Lancaster, PA
    I'm just throwing a wild guess at this.... this is gonna be hard to explain what I'm thinking here.
    This might have a lot to do with how the tire 'seats' itself on the bead of the rim at a certain tire pressure.
    A rim that's too wide for the tire can affect the overall tire pressure you run to ensure proper tread wear on the street. That pressure might not be enough to keep the tire in the bead of the wheel.
    If you make an aggressive turn - could cause the tire to 'roll over' and off the bead perhaps. ????
    Scroll down to "rim width range"
    http://www.tirerack.com/tires/tiretech/tirespecskey.jsp
  15. Jun 16, 2009 at 3:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This is what I was thinking as welll
  16. Jun 16, 2009 at 3:39 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I'm with David on this one. A 9 inch rim, paired with a 265/70R17 tire is just not a good match. It is unlikely that it would ever happen, although, you take the risk of having your tire's bead becoming un-seated, especially in off road situations with low tire pressure and rocks pushing on the side wall.
  17. Jun 16, 2009 at 4:40 PM
    STLTaco09
    There are plenty of 265/70/17 tires that have a rim width range of up to 9". Revo A/T, Destination A/T, Nitto TG to name a few. If the manufacturer has 9" in the acceptable range, then I see no problem with it at all. It's the implications of running a rim wider (1/2" in this case) that I'm curious about.
    Searching for 275/65/17 and 275/70/17 tires reveals acceptable rim widths of up to 9.5". I saw a few posts on TN about someone running a 275/70/17 MTR with stock wheels and suspension without issue. Has anyone seen or heard of this size working?
  18. Jun 16, 2009 at 4:49 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    I started a thread on this yesterday, it seems that not too many people have this size. I guess I'll check out TN to see if I can find some info. Do you have to be a member? The last thing I need is to get addicted to another forum:D. If I find anything I'll post it in the thread I started so this one stays on topic.
  19. Jun 17, 2009 at 2:28 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I'm running 265/70/17 on 17x9's with a tire that specifies it is approved for a 9" rim width, so how is that not safe?
    BTW it is the Nitto TG
    http://www.nittotire.com/#index.tire.terragrappler.sizes
    P265/70R17 113S 200-400 13.6 31.57 10.79 7.0-(8.0)-9.0 2535@35658
  20. Jun 17, 2009 at 2:28 AM
    AFButters
    AFButters Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    Oh snap you just got Fox'd
