Stupid oil change related question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jjmead1, Mar 10, 2023.
  1. Mar 10, 2023 at 5:04 PM
    jjmead1
    jjmead1 [OP] Active Member
    2009 Tacoma access cab TRD
    There has to be a part to buy that threads into the oil filter area that prevents the spill from getting everywhere. I am referring to the excess that leaks from the filter upon removal. The catch basin spill doohickey.
  2. Mar 10, 2023 at 5:09 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm guessing you got the 2.7 engine.
  3. Mar 10, 2023 at 5:20 PM
    jjmead1
    Sorry, 4.0 V6
  4. Mar 10, 2023 at 5:22 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    There’s a drain nipple on the bottom. Stick a piece of tubing on it and run it down out the bottom of the truck or set a bottle under it to catch the oil.
    Geeves77, LOLLY, TOMB and 3 others like this.
  5. Mar 10, 2023 at 5:28 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    This
    I just cut a quart bottle in half and hold it under the spout while changing the the filter and clean the drain catch with some brake cleaner when done, it all drains nicely in the catch bottle and no mess.
    If you prefer it to drain out the bottom just get you a few feet of 3/8 in hose, a hose clamp, and a few zip ties and route it to a location of your choice under the truck
  6. Mar 10, 2023 at 5:34 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    right. It's not threaded. I just use a water bottle.
    topoutman and Dm93 like this.
  7. Mar 10, 2023 at 5:39 PM
    Jasskillman
    Jasskillman Well-Known Member
    SoCal
    2013 DCSB
    Agree about the drain on the back, there’s a little black cover that needs to be pulled off. Mine was never removed so the drain was kind of gunked up first time using it. I needed to poke a thin plastic piece down the hole the first timing using it to clear it out. I put a water bottle on the drain outlet and let it catch it, there’s not a lot that comes out. I have all the tubing to route it to the catch bucket but haven’t had the urgency to route it yet.
  8. Mar 10, 2023 at 6:11 PM
    pyrite4t3
    pyrite4t3 Well-Known Member
    12 TRD OR AC
    I use a section of .5' tubing (I.D) approximately 3' long. Fits the nipple and will perfectly extend through the hole in stock off road 'skid plate'.
    Never had a problem, or a single drip.
    jjmead1[OP] and essjay like this.
  9. Mar 10, 2023 at 6:13 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Same, although I route it down and around the skid plate. I also have a hose coming out of the Fumoto valve on the pan. Super clean and easy.
    jjmead1[OP] likes this.
  10. Mar 10, 2023 at 6:15 PM
    jjmead1
    thank you all
  11. Mar 10, 2023 at 6:16 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Ditto works perfectly.
    TOMB
  12. Mar 10, 2023 at 6:44 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I just use a empty plastic water bottle and jam it between the belt under the nipple on the housing ezpz
    jbrnigan likes this.
  13. Mar 10, 2023 at 7:13 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Even with the plug on the base plate removed, oil can spill out. To avoid that, rotate the oil filter slowly. Stop when oil starts draining out and proceed slowly when it stops.
  14. Mar 10, 2023 at 7:42 PM
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    I had mine done recently at the shop because my 2007 2.7L was in there for some other things. Next time I may change the oil myself. A couple of videos I watched included a new washer for the drain plug. Are the washers specifically made for oil pans? On my former Subarus I'd reuse the them, and they were just metal. The washers I saw for the Tacoma oil pans in the videos had I believe a rubber portion on the gasket, 14mm I believe. I'd like to buy some to have on hand.
  15. Mar 10, 2023 at 8:27 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    the 4.0L v6 is probably the cleanest oil change out of any vehicle I have ever had the pleasure doing.
    Heres how to do it in 15 EASY steps (with a few key bolded steps)
    1. Buy 6 pack of BOTTLED beer on your way home
    2. Pop the hood to let truck cool upon arriving home
    3. Crack a beer from what you just bought and sip on it while the truck cools off and unwind from the day over the next 15-30min (if you are a fast drinker crack a second or third if its light beer)
    4. Crack another beer to start the process of work for the upcoming oil change
    5. Gather tools
    6. Place drain pan under engine and remove drain plug to start draining engine oil
    7. Place a now empty long neck under oil filter housing with the drain nipple in the mouth of the long neck,
    The long neck (due to its length and rigidity) wedges perfectly between rad hose and serpentine belt.:wink::wink:
    8. Undo oil filter enough so oil starts draining out and into used/empty beer bottle
    9. Crack another beer to start the process of finishing the oil change
    10. Spin off filter completely and clean mating surface, spin on new filter of your choice
    11. REMOVE beer bottle from below oil filter
    12. Replace drain plug on oil pan
    13. Fill with 5ish qts of whatever 5w-30 of your choice
    14. Replace oil fill cap
    15. Crack a final celebratory beer because there are no drips, spills or leaks while running after your successful oil change.
  16. Mar 11, 2023 at 5:02 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Put an empty water bottle under it.
    Problem solved. It's not complicated
  17. Mar 11, 2023 at 5:15 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    5/16 ID fuel line and a hose clamp... cap off end when done.
  18. Mar 11, 2023 at 5:23 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Those are crush washers and you are supposed to change them on every oil change... On every vehicle no matter the make or model. You also don't have to specifically use the Toyota ones. I use bare aluminum crush washers from Amazon and they work fine.
  19. Mar 11, 2023 at 5:46 AM
    Stelcom66
    2007 2.7L 5MT 4WD
    Crush washers - ok thanks. I'll definitely change mine if I do it myself.
  20. Mar 11, 2023 at 6:58 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    I used a tube my first few changes but it really doesn't drip all that much oil so I ultimately went to a method where I just put a few paper towels into a doubled plastic grocery bag stuffed under that nipple. Let it drain, screw on the new filter, then pop the rubber cap back on before you remove the bag.
