Stupid question about entune oem head unit
Discussion in 'Audio & Video' started by ratcityrain, Aug 10, 2015.
  1. Aug 10, 2015 at 12:23 PM
    ratcityrain
    ratcityrain [OP] Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    I added some loc's to my head unit so I can install a amp. All that is good and well, but Friday night was the first time since I got the truck that I had to drive at night and I noticed that the side buttons on the oem unit didn't light up. Are they supposed to? It is the buttons that say Home, audio, track forward and so on. I am wondering if I didn't wire up the illumination wires when I was wiring up the loc and the bests wire harnesses.
  2. Aug 10, 2015 at 12:24 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    educate me?
    what is a loc?
  3. Aug 10, 2015 at 12:26 PM
    ratcityrain
    Seattle, WA
    line out converter - it's so you can use the factory front or rear speaker wires to convert to rca's to add an amp and use the oem head unit
  4. Aug 10, 2015 at 12:27 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    ah, thanks..............I like learning shit
    ratcityrain[OP] likes this.
  5. Sep 14, 2015 at 4:34 PM
    wattsedona
    wattsedona Member
    Adam
    2015 Tacoma Off Road package. Double Cab
    None....yet
    I am about to install this weekend. I am going the route of keeping stock head unit. Which means I will be using the Line Output Converter, 2 Questions....
    1. Did you get a wire harness, or splice behind the head unit? If you spliced, What speakers did you connect to?
    2. Did you figure out what was the problem with your lighting issue?
    Thank you
  6. Sep 14, 2015 at 4:48 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    In short. No.
  7. Sep 20, 2015 at 10:12 AM
    ratcityrain
    Seattle, WA
    I used harnesses as I did not want to cut or splice any wires
    As for the lighting, no ideas yet. I confirmed 100% that the illumination wire is connected and working properly so i'm thinking the side buttons were never intended to light up or i have a bad head unit
