Stupid question about sport LSD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757yotas, Nov 9, 2017.
  1. Nov 9, 2017 at 7:20 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    i have a 07 sport with what is suppose to be a mechanical LSD. Is it something that has to be in 4L to use like the lockers or can i just be say in 2H and it will engage when it wants or needs to?
  2. Nov 9, 2017 at 7:23 PM
    Bishop84
    Bishop84 Well-Known Member
    Clutch packs in the rear that engage under low traction conditions, all times.
    The clutch packs can wear over time loosing the effectiveness. But yours more than likely works. A gravel road will tell all.
    It's only refered to "mechanical" LSD because the later models got simulated LSD via brake modulating.
    757yotas[OP] likes this.
  3. Nov 9, 2017 at 7:24 PM
    757yotas
    Virginia
    2007 TRD Sport
    Ok sweet, ill have to try it tmo on some snow and see if both tires try to grab before I switch to 4wd.
  4. Nov 10, 2017 at 9:23 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    can the mechanical LDS be adjusted?
  5. Nov 10, 2017 at 9:40 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    Not to my knowledge. If the clutch packs in it are worn, rebuilding/replacing it is about the only recourse.
    I'm sure there's rebuild kits are out there, somewhere. I was able to source one for the factory LSD in my Jeep's rear axle.
    bluezzy[QUOTED] likes this.
