stupid question but how to mount mag light..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mickyd9990, Dec 29, 2010.
  1. Dec 29, 2010 at 10:29 AM
    mickyd9990
    mickyd9990 [OP] Well-Known Member
    marc
    ri
    07 tacoma off road
    im going to put it on the side of the drivers seat..
    i searched through a ton of threads and it does not show how people mount them.. thise screws they come with dont seem like they will hold.. prob just pill them right out with the light.. i figured rivets would be he best option but i dont have any... any one use anything else with good luck??
  2. Dec 29, 2010 at 10:51 AM
    Black Sheep
    Black Sheep Well-Known Member
    Jeff
    Pittsburgh, PA
    2011 Black Dbl Cab TRD T/X Pro
    6" Pro Comp Suspension lift with Pro Comp leveling kit, Bilstein 5100's, Full leather interior with seat heaters, Go Rhino step bars, Sony XNV-770BT Head Unit with NAV, DVD, XM and Blutooth, Tonopro toneau cover, Tinted windows, Black mesh grille, Projector headlights with HID lows, HID fogs, Crystal Eyes rear LED taillights, Weathertech mats front and rear
    I just mounted mine over the weekend. I used the screws that came with the mag light clip package. They tightened down pretty tight. If you do not trust them, try some small bolts. You can get you hand in under the seat to tighten the nuts.
  3. Dec 29, 2010 at 10:53 AM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    i marked and drilled four small holes with a dremmel for the mounts-- then put in different screws than the ones that came with it, along with nuts on the back, and some 3m double side tape for good measure-- that thing is not going anywhere!!!
  4. Dec 29, 2010 at 1:05 PM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    Do a search. There's a really good thread on this subject with great ideas.
    RZ Rob
  5. Dec 29, 2010 at 1:22 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    Have you tried mounting it from behind? :anonymous:
  6. Dec 29, 2010 at 1:26 PM
    SilverTacoZack
    SilverTacoZack Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    This advice might also work for your girlfriend.
  7. Dec 29, 2010 at 1:28 PM
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    :ohsnap:
  8. Dec 29, 2010 at 1:38 PM
    OffroadToy
    If you think rivets would do the job Home Depot has a good selection of rivets and hand operated rivet puller.
    edit...if your useing the rivets on plastic I'd advise useing some thin metal as a backing plate...the rivet could pull right through the plastic otherwise.
  9. Dec 29, 2010 at 2:01 PM
    mickyd9990
    marc
    ri
    07 tacoma off road
    thats the only way to mount it.. comfortable, tight and wet..... um the girl.. :burnrubber:
    i just used the screws for the light.. if they ever pull through inn just get some small nut/bold washers for it
  10. Dec 29, 2010 at 2:12 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    i didnt feel like getting any holes in the plastic, so i just put mine on the drivers seat floor
  11. Dec 29, 2010 at 6:45 PM
    darktaco
    darktaco Active Member
    N.E. , Pa...U.S.A.
    08/Sport
    scangauge/c.b.-cobra 29/ BO chrome badges/Demello bolt on sliders/rcbs 4x4 led mod/rear tsb / relocated trailer plug to plate light hole/ Toytec U.L.K./L.R. UCA's/AFE-pro-dry air filter/LEDS -plate,dome,map lites /rear diff breather/ImMrYo's mirror lift/redline hood lift,
    I slide my 4 cell mag between the seat and console . The head sticks out about 4 inches . Enough to pull out easily.
    I also thought small and did this for quick access . Or when I don't need a club/light !
  12. Dec 29, 2010 at 7:04 PM
    Coloradomx24
    Coloradomx24 Well-Known Member
    Colorado
    2015 Dbl Cab L/B Sport
    WOW :rimshot:
    I just used the screws that came in the mag light package. It seems really sturdy and if they rip out I will just switch over to a 6MM bolt with a nut on the back side.
  13. Dec 29, 2010 at 7:16 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I used the screws that come with the mounts. Mine has worked fine for at least a year. Just dont get too rough with it and it seems to hold just fine. :)
  14. Dec 30, 2010 at 11:05 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    I also used the screws that came with the mounts. After 1 1/2 years they are still holding great.
    I figured if they didn't hold, I could always go with bolts later on, but this way I start with the smallest holes possible in the plastic.
