Stupid Question Here - Front Tags
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cossi, Jun 3, 2009.
  1. Jun 3, 2009 at 9:07 AM
    Cossi
    Cossi [OP] TacoTacoTaco
    I have no clue.
    Going to put my front license tag on my new Tacoma. Called the dealer and they said you just screw directly into the front bumper. Which if that is right, then fine. But it seems to me that it would be really easy to strip the bumper, round the holes, whatever. Not to mention it doesn't seem that stable either. How did you folks mount your front tags?
  2. Jun 3, 2009 at 9:08 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Dealer attached mine just like you were told. Seems fine.
  3. Jun 3, 2009 at 9:11 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    that is how you do it. There are two indentations on the front bumper where you are supposed to install it. Just don't turn the screws too tight.
  4. Jun 3, 2009 at 9:25 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Ya they just screw them in, but I don't like that idea, deforms the plastic.
    I think if I had to do it I would drill them out, just to make it a little meater, then follow the above posts.
  5. Jun 3, 2009 at 9:54 AM
    LEEP
    LEEP Well-Known Member
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    dont put front plate on
  6. Jun 3, 2009 at 9:58 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    no front plate on mine, I uhhh... 'it fell off' :)
  7. Jun 3, 2009 at 10:08 AM
    Viking88
    Viking88 Devil's Advocate
    Budd Lake NJ
    2009 TRD Sport DC 4X4
    I asked my dealer for a bracket for the front plate, told me there is none. I don't like the idea since the bottom of the front plate vibrates directly on the paint of the bumper, I bent out the plate a little bit to hopefully prevent that from happening. Its a cheesy setup.
  8. Jun 3, 2009 at 10:10 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Mine ripped off. It pulled the nuts through the bumper. It was only attached at the top so I am not sure whether it happened offroading (how) or if some rouge wind caught t the wrong way
  9. Jun 3, 2009 at 1:11 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Or move to arizona and throw the front plate away.
    Also yea, that back one is cheesy as hell.
  10. Jun 3, 2009 at 1:21 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    YUCKO! No front license plate required in North Carolina....reason enough for all of ya'll to move here!!!!!
  11. Jun 3, 2009 at 4:14 PM
    spp
    spp OC, Kalifornia
    OC California
    Just be aware that some Law Enforcement in SoCal are using this to pull over vehicles to check for DUI's.
    My LBPD Swat buddy told me this after I was venting about being pulled over in Venice in our New Camry which had no plates since they hadn't arrived yet.
    I had taken off the dealer frame on the rear and the front didn't get drilled.
    I removed the temporary paper tag inside the windsheild to take some pictures and had it in the glovebox.
    Passed an enforcement team with a newbie and HER training officer and they jumped behind me and lit me up.
    Not speeding just two old folks out for a drive along the coast.
    Dropped the front windows as they were tinted and didn't want to get popped for that.
    Plates had been generated in the system even though I had not received them so she wrote me a fix it ticket.
    Pissed me off but I kept my mouth shut incase they had seen the windows when we passed them.
    Glad I hadn't stopped for lunch and maybe one margarita or I would have been doing the line dance.
  12. Jun 3, 2009 at 4:26 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Meh. Californication needs revenue. Bet they pull you over if you are 5 mph over the limit now. Move to NC, find America again.
  13. Jun 3, 2009 at 4:54 PM
    dogsmember
    dogsmember FIIGMO
    Halifax Nova Scotia
    2009 Tacoma A/C Package
    Come on up to Nova Scotia Canada. No front plate required although if you are old it appears that you have to put the name of your pet on a cheesy plate and mount it
  14. Jun 3, 2009 at 5:06 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Meh, you couldn't see it thru the daily fog and mist in Scotia anyways. and it just collects dead smacked black flies. F**K Black Flies!!!!! THEY EAT HUMAN FLESH!!!!!!
  15. Jun 4, 2009 at 4:33 PM
    spp
    spp OC, Kalifornia
    OC California
    My wife's family hails from around Ashville I think.
    Being heavy into cycling though it is hard to beat OC Kalifornia even with it's faults.
    I prefer to stay and fight rather than abandon my home since 1963.
  16. Jun 4, 2009 at 4:46 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Good for you! Fight the KOOKYS and TAX MONGERERS!!!!
  17. Jun 4, 2009 at 5:34 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    mount it to your skid plate, if you have one.
  18. Jun 4, 2009 at 5:39 PM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I second this. Obviously it depends on your location, but even in Missouri it is a "requirement" to have a front plate on. There are plenty of vehicles driving around with no front plate. Mine is under the drivers seat.
    When I bought the truck, I told the dealer that the deal was off if anyone puts a front plate on it before I had a chance to accept delivery. I dont want holes in my bumper for a license plate, it looks dump in my opinion.
    I've seen situations where people have a front hitch on their truck, and they fab up a front plate bracket that uses the hitch. A bit of work if you dont have a front hitch on yet though.
  19. Jun 5, 2009 at 5:15 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    x1000
