stupid question. How do I tell what gear my AT is in while in D?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PEIyota, May 26, 2017.
  1. May 26, 2017 at 4:56 PM
    PEIyota
    PEIyota [OP] Well-Known Member
    Jeff
    Prince Edward Island, Canada
    2017 MGM TRD Off-Road DCSB
    TRD Pro Grille, OEM Bed Mat, TRD Shift Knob, Red Tow Hook (painted)
    If I put it in S mode, I can see the gears down in the lower left hand of the display, but in D it just shows "D".
    Any ideas?
  2. May 26, 2017 at 5:07 PM
    AF_Gunner
    AF_Gunner Well-Known Member
    South Jersey
    Debadged 2017 Super White Double Cab/Off-Road/Short Bed
    5100'S/ OME 887 Coils/ Headstrong Progressive AAL/ SPC Light Racing UCA's/ Clamshell bushing upgrade/ 30" Rough Country LED light bar
    Throw it in sport mode and look at the dash display
  3. May 26, 2017 at 5:08 PM
    PEIyota
    Jeff
    yea, but then i'm doing the shifting. I want to know what gear it's in while it's in drive.
  4. May 26, 2017 at 5:10 PM
    AF_Gunner
    South Jersey
    Yeah I know what you want. Don't shift, it'll tell you what gear you're in once you put it in sport mode
  5. May 26, 2017 at 5:11 PM
    PEIyota
    Jeff
    If I remember correctly, putting it in sport mode automatically puts it into 4th gear?
    9TRDTCO and uhplifted like this.
  6. May 26, 2017 at 5:13 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    This.
    Hank Heel, 9TRDTCO and uhplifted like this.
  7. May 26, 2017 at 5:15 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Count your gear shifts? I don't think there's any other way. I generally know which gear I'm in while it's in D
    HutchJ and tcjacado like this.
  8. May 26, 2017 at 5:17 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    It's stupid that sport mode doesn't keep current gear.
    bensonxj and blackrifle76 like this.
  9. May 26, 2017 at 5:19 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    That really true?? Aside from counting your shifts maybe scangauge will tell you. Just leave connected while driving?
  10. May 26, 2017 at 5:22 PM
    tcjacado
    tcjacado Well-Known Member
    Nope it only limits how high the computer can make it shift. Called a limiter not a shifter. If you want to shift yourself then shift between 3000 and 5000 rpms, auto shifts it at around 2000
    jsinnard and uhplifted like this.
  11. May 26, 2017 at 5:25 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    This, I believe shifts limiter limits the highest gear, S4 limits the trans to 4th gear, no higher.
    Also curious but probably a function of speed vs. rpm's is the only way to tell what gear the trans is in.
  12. May 26, 2017 at 5:30 PM
    tcjacado
    The truck will typically not hold gear the second you lift off the gas. The computer tells it to shift to the highest gear possible related to speed and possible current rpm's
    At 40 it will shift into 4th once gas pedal is released and approximately 47 to 50th will shift into 5th. That's what when you get back into the gas it feels sluggish. It just wants to try to maintain appoximate current speed, hence the huge down shift to gain significant speed again.
  13. May 26, 2017 at 5:41 PM
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    It does right at first put you into 4th gear. Just bump it up twice to get it into 6th gear. Then it will shift to any gear needed, both up and down just like in D. When you stop, it will downshift into 1st. When you take off, it will go through all the gears just like it does in drive or D.
    Also, once you first put in in S and it shifts into 4th gear, it will shift automatically from 1st to 4th as needed. When you first put in it S and let's say you drop it to 3rd gear, it will shift as needed though 1st to 3rd. It won't go out of 3rd unless you bump it into a higher gear. But once you in the next higher gear it will now shift through all gears as needed from first to whatever gear you bumped it to when you first put it in S. Hope that makes sense.
    over60 likes this.
  14. May 26, 2017 at 5:53 PM
    Taco16LB
    Taco16LB Well-Known Member
    For me it is VERY hard to tell what gear it is in in D. This is because there is 4th , 4th with locked convertor / 5th / 5th with locked convertor , and 6th , and 6th with locked convertor. All have different RPMs, and may overlap .
    Edit , at least this is the way I understand it .
  15. May 26, 2017 at 6:13 PM
    protaxidermist
    protaxidermist Well-Known Member
    North Carolina
    My auto is so smooth its kinda hard to tell when its in drive. I try to count them by listenig to the engine.
  16. May 26, 2017 at 6:20 PM
    PEIyota
    Jeff
    :jerkoff:
  17. May 26, 2017 at 6:25 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Saw "D" and had to see what's going on in hur
    uhplifted and HutchJ like this.
  18. May 26, 2017 at 6:39 PM
    T-Rex266
    Elon
  19. May 26, 2017 at 6:51 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    The "D" stands for "DOH"...apparently you have the Homer Simpson Edition....!! Only even seen one other one..!! RARE..
    :thumbsup:
  20. May 26, 2017 at 7:04 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    That's not what I meant. I meant if I'm in 5th it should hold 5th not auto to 4th
