Stupid Question: How to ensure truck is completely level for fluid changes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ImmortalTaco, Apr 6, 2020.
  1. Apr 6, 2020 at 1:31 PM
    ImmortalTaco
    ImmortalTaco [OP] Member
    Brian
    Riverside, CA
    2014 SR5 Double Cab
    I'm preparing to do my 30k maintenance, changing oil in diffs, engine, etc. and I want to make sure my truck is completely level when I do it.
    2 Questions:
    1. My truck has an Icon suspension lift, but I also have a lot of extra weight in the bed (shell, drawer/bedslide, RTT), so there is some sag in the back. If my truck was parked on 100% level ground, is the engine 100% level as well, or is it impacted by the lift/sag?
    2. I don't have a place that is 100% level in my yard, so my thought was to pull the truck up on my travel trailer leveling blocks and measure from ground to differential at each wheel, would that suffice?
    Thanks guys and sorry for the stupid questions.
  2. Apr 6, 2020 at 1:34 PM
    ericvega
    ericvega Well-Known Member
    Eric
    2019 MT TRD OR DCSB
    Magnusson Supercharger Kit RCI Skids C4Fab Sliders CBI BedRack Bilstein Bypass Shocks Icon RXT Leaf Pack
    As long as the truck is mostly level you will be fine. One to two inches height difference from front to rear will only be a degree or two of tilt. If you're on level ground, you'll be good so long as you don't have some absurd amount of tilt from uneven lift.
    Chew, whatstcp and Big tall dave like this.
  3. Apr 6, 2020 at 1:36 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Level is not that critical. Visually level is fine.
    Otherwise, you could drop a little level in to the cupholder to check.
  4. Apr 6, 2020 at 1:36 PM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Don’t worry about it. The dipstick difference is small as determined by weight distribution. Being parked on a hill creates a difference much greater then loading the car or truck.
    Even checking oil on a hill can tell you how much your oil level changes .....if you park on the same hill and in the same incline everytime you check.
    Chew likes this.
  5. Apr 7, 2020 at 4:59 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    I think most people just eye-ball it, it’s not so critical that it needs to be perfectly level.
    If you’re really OCD about it, you could always put a small carpenters level against the frame, crossmember or axle and jack up each corner until it’s perfect.....
    Dagosa and Chew like this.
  6. Apr 7, 2020 at 5:03 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If you don’t trust your eyeballs use a carpenter’s bubble level or a fishing weight on a string.
    Big tall dave, Dagosa and whatstcp like this.
