Stupid Question of the day
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chimfratch, Apr 26, 2021.
  1. May 3, 2021 at 9:29 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Im surprised at all these arm chair engineers freaking out, i dont see any reason it wouldnt work other than needing a longer center pin and u bolts, if it sucks, remove the added leaf...
  2. May 4, 2021 at 4:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If one were to weld leaf springs to the C-channels of the frame, would it give it extra spring back for flexing off road? Asking for a friend.
    Chimfratch[OP] likes this.
  3. May 4, 2021 at 8:07 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Don’t know, but I could see where it would give more vibration due to you eliminating a flexible joint.
  4. May 4, 2021 at 8:14 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Don't. This is a recipe for failure.
    Leaf springs are arched. As they compress, the distance between mounts expands. The purpose of the shackle linkage is to allow the "growth".
    If you weld the leaf spring onto the frame, then the mount distance is fixed. Something will break, just a matter of time.
  5. May 4, 2021 at 8:38 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    But if the Greeks and Romans used arches, then these should make the frame stronger right? Might have to cut them into smaller arches to make it fit. But that means more arches, so even stronger. Or am I off base on that?
  6. May 4, 2021 at 8:50 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Totally. To keep with the neo-classical theme, I suggest building the arches out of marble.
  7. May 4, 2021 at 9:17 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    noah built a big ass ark with wood that he "arched".. make em out of wood.. mix of metal and wood. very Industrial and Shaker style. much cool.
  8. May 4, 2021 at 9:47 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You gents are brilliant! Time to get to work.
  9. May 5, 2021 at 9:27 AM
    Chimfratch
    Chimfratch [OP] Well-Known Member
    2008 tacoma Crew cab 4x4 longbed
    All Im sayin is that wagons used to be made of wood, ocean worthy vessels taking on 80 foot waves were made of wood.
    XPOTRPR[QUOTED] likes this.
  10. May 5, 2021 at 10:03 AM
    spitdog
    That was appropriate for the time.
  11. May 5, 2021 at 1:45 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    That's cause they didn't have metal technology, they would have had metal wagons and metal 80 vessels. Like we do today. So we don't see wood wagons and wooden vessels taking 80 foot waves.
    Plus with the cost of wood these days, metal would be way cheaper.
  12. May 5, 2021 at 2:00 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    What am I reading? Spring rate calculations are extensive, taking into account metal fatigue, elasticity recovery rate, but yeah, a couple of leaves from used spring pack should work fine......
  13. May 5, 2021 at 2:40 PM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    hook, line, & sinker...
    Gearheadesw likes this.
