Stupid Stop
Discussion in 'Canada' started by Harold McCanick, Oct 6, 2013.
  1. Oct 6, 2013 at 8:44 AM
    Harold McCanick
    Harold McCanick [OP] Active Member
    Harold
    Goat Hill MD
    '12 Old Man Truck
    Skid Plate
    I ride motorcycles and use both feet to do it. I ride Jetskis and use both feet.I fly airplanes,this takes both hands,both feet,your mouth,both ears and a whole lot of thought.Now Toyota and probably the federal government has decided I can't drive with both feet.Get out of my truck,BOTH of you!Smart Stop is stupid.Please tell me how to disable this worthless feature.
  2. Oct 6, 2013 at 8:46 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    what is smart stop? Is it the thing that prevents brake stand burnouts?
  3. Oct 6, 2013 at 8:51 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    X2 idk what it is.
  4. Oct 6, 2013 at 8:54 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  5. Oct 6, 2013 at 8:55 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    You can drive with both feet, but they should not be used at the same time.
    Do you have a habit of riding the brake on previous vehicles?
  6. Oct 6, 2013 at 8:55 AM
    PBR Streetgang
    PBR Streetgang Well-Known Member
    Andrew
    Medford, OR
    2013 AC 4x4 TRD
    Icon stage 4 kit, Deaver J66 leaf springs, Firestone ride-rite airbags, Warn 9.5 XPS winch
    The way to disable it is to stop driving with one foot on the brake and one foot on the gas. There is absolutely no reason to drive like that.
  7. Oct 6, 2013 at 8:56 AM
    Harold McCanick
    Harold
    Goat Hill MD
    '12 Old Man Truck
    Skid Plate
    It is the silly safety feature that kills the power if you drive with two feet.The unintended consequence is it makes slippery boat ramps impossible.
  8. Oct 6, 2013 at 9:00 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    there is one reason
    :D
  9. Oct 6, 2013 at 9:03 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    I have never had a problem or a need to use 2 feet on boat ramps. just move your foot faster.
  10. Oct 6, 2013 at 9:06 AM
    Harold McCanick
    Harold
    Goat Hill MD
    '12 Old Man Truck
    Skid Plate
    Hey Andrew,We can compare driving records and maintenance records if you like,the point remains I don't need you or Toyota telling me how to drive.
  11. Oct 6, 2013 at 9:09 AM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Awe the fun with new vehicles. Find the relay and rip it out.
  12. Oct 6, 2013 at 9:11 AM
    ONALL4
    ONALL4 Well-Known Member
    Frank
    Toronto Canada
    2004 V6 4X4
    You wanted to launch the truck or somethin
  13. Oct 6, 2013 at 9:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! I don't think there is anyway to disable that feature.
  14. Oct 6, 2013 at 9:19 AM
    Harold McCanick
    Harold
    Goat Hill MD
    '12 Old Man Truck
    Skid Plate
    I wish it were that easy.Apparently it is programmed into the software.I would gladly pay to have it deprogrammed.
  15. Oct 6, 2013 at 9:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    http://www.youtube.com/watch?v=4W5q1tOLoR8
  16. Oct 6, 2013 at 9:27 AM
    Harold McCanick
    Harold
    Goat Hill MD
    '12 Old Man Truck
    Skid Plate
    Dear Chris,I am told by a Toyota Tech it can be done but Toyota will know about it and they will void the warranty.My offer stands.
  17. Oct 6, 2013 at 9:29 AM
    File IFR
    Central MA
    ... Throttle activation first and it only operates at above 5 MPH and/or 1/3 throttle opening.
    Good find Chris.
  18. Oct 6, 2013 at 9:36 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    "Smart Stop" is simply a marketing spin on the brake override ECM logic Toyota added in 2011.
    If you press the brakes first, then hit the gas, the override doesn't kick in:
    http://www.tacomaworld.com/forum/at...er-ride-system-toyota_brakeoverridesystem.pdf
    It's in the ECM logic. If you got the pedal chop recall, the dealer would have flashed the ECM with it, too.
  19. Oct 6, 2013 at 9:54 AM
    ImplicitlyAlberta
    David
    edmonton
    I would loose it.
    There is no way I will buy a vehicle that does this.
  20. Oct 6, 2013 at 10:05 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    This is what the disclosure says.
    Smart Stop Technology operates only in the event of certain simultaneous brake and accelerator pedal applications. When engaged, the system will reduce power to help the brakes bring the vehicle to a stop. Factors including speed, road conditions and driver input can all impact stopping distance. Smart Stop Technology is not a substitute for safe and attentive driving and does not guarantee instant stopping. Please see your Owner's Manual for further details.
    Not to start anything but haven't you seen the news cast 72 year old has mistaken the gas for the break.
    If I remember correctly it used to be common place to use the left and right foot to drive. But if you dislike that feature on your new pick-up truck trade it in and buy an older model.
    My driving record is spotless, I drive for a living ,ride motorcycles , and I am licensed to drive anything on the road.
