Stupid Stop
Discussion in 'Canada' started by Harold McCanick, Oct 6, 2013.
  1. Oct 6, 2013 at 1:06 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Smart Stop won't help you if you mistake the gas for the brake. ;)
    The brake override logic is not intrusive at all. For normal usage (starting on a hill, holding the brakes at a dragstrip while you rev the engine), the brakes are always applied first before you step on the gas.
  2. Oct 6, 2013 at 1:13 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    What's it doing exactly on the boat ramp? I can't understand why you'd need to hold gas and brake? It's never once in 25,000 miles affected me in my normal driving situations. If you're touching the brake and the gas at the same time in an auto, aren't you trying to stop or hold it stopped? Not trying to argue, I just can't figure out why you'd need your feet on both pedals simultaneously.
  3. Oct 6, 2013 at 1:13 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Actually 2, that reason ^^, and if you get in a position where your open diff is making you lose power to the wheel that has most traction and you're just spinning then you can either set the e-brake a little or you can press the brake pedal a little to see if that ail help send the power to the wheel that needs it.
    I don't want a nanny like that on my truck either, it's just stupid.
  4. Oct 6, 2013 at 1:20 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    This is another way to stop the idiots from using more than one floor mat in their car from killing themselves. You've seen the news stories. Throttle gets stuck and person crashes because they couldn't stop the car/turn off the engine (push button vehicles).
    They're too stupid to realize that you put the car in neutral and pull over then stop. Who cares if your engine grenades.
  5. Oct 6, 2013 at 1:21 PM
    KenLyns
    Belly of the Beast
    Toyota already does that automatically. It's called Auto-LSD. ;)
    I tried it off the line on wet pavement once (hit the VSC button once to disable Trac and enable Auto-LSD) - when the Auto-LSD engages, it's like a kick in the back.
  6. Oct 6, 2013 at 1:27 PM
    95 taco
    95 taco Battle Born
    Auto LSD uses the computer and wheel speed sensors to work, so it's complicated, and when i've seen it work (off-road) it's very jerky, when you just use the brake (manually actuated) it's smoother and you have more control over it.
  7. Oct 6, 2013 at 1:37 PM
    KenLyns
    Belly of the Beast
    When you use the brake, you are braking both the slipping wheel and the wheel with traction, where as auto LSD brakes only the slipping wheel.
    Auto LSD doesn't activate in 4lo (at least not from the factory), so where have you seen it work off road?
  8. Oct 6, 2013 at 1:41 PM
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
    I don't drive with two feet but I do race my truck and to gain power I will hit the brake and gas and get the rpms up for a launch.
    Yes boat ramps would be another great example along with hills and off roading.
    Exactly:
    But as someone mentioned it doesn't kick in unless your above 5 mph. Because I have had to spin my tires and I just turn off the traction control, vsc and stuff with the button?
    When im at the boat ramp I don't want to go backwards so I hold the brake and apply throttle to ease my self out without putting to much power, if I use one foot I take the foot of the brake and it will slide back then when you hit the gas your putting power to a truck that getting pulled backwards. Its nice relief to ensure you don't end up at the end of the boat ramp :D
  9. Oct 6, 2013 at 1:50 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I've only ever heard of people doing this with mechanical LSDs which require a little bit of resistance to send power back over to the other side. I'm fairly certain this is how HMMWVs are meant to be drivin using Torsen diffs at each axle.
  10. Oct 6, 2013 at 2:00 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    No the ebrake trick definitely works with open diffs. It pretty much simulates an LSD.
  11. Oct 6, 2013 at 2:05 PM
    KenLyns
    Belly of the Beast
    If you hold the brakes, then apply the throttle, Smart Stop doesn't intrude. So what's the problem?
    Smart Stop's only real function is to allow you to quickly cut the throttle if the gas pedal is stuck. Traditional methods like turning off the ignition or shifting to neutral leave you with no power-assist for the brakes.
  12. Oct 6, 2013 at 2:07 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I do this on my steep driveway when parked. If I want to pull into the garage, I don't want to roll backward & I don't want to goose it forward since the fit it tight in my garage. Right foot on brake, pop into drive, left foot disengages parking brake, left foot on brake, right foot eases onto gas & then left foot off the brake for an easy no-strain drive up the driveway.
    Smart stop wouldn't keep me from doing this.
  13. Oct 6, 2013 at 2:10 PM
    95 taco
    95 taco Battle Born
    Yep, but even though it takes more power to move the truck when you use the brakes instead of traction control it's a smoother application of the braking force, which means that the tire with more grip is less likely to be "snapped" making it lose traction.
    In videos, ARB has a good one that demonstrates the traction control off road.
    EDIT: this video, starting at 2:40 or so.
    http://www.youtube.com/watch?v=YNFacsKnswM
  14. Oct 6, 2013 at 2:15 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I'm wondering if the ABS kill switch mod would disable this so called feature when engaged.
  15. Oct 6, 2013 at 3:03 PM
    #35
    KenLyns
    Belly of the Beast
    The video isn't showing auto LSD, it's showing A-Trac, which is electronically simulating a locker. A-Trac isn't as smooth as a locker, but it will get the vehicle through the obstacle most of the time. Applying brakes manually like you suggested wouldn't have let that Prado past the obstacle.
  16. Oct 7, 2013 at 6:33 AM
    #36
    TripleThreat
    True I did'nt think about power-assist for the brakes good thinking!
    Haha glad im not the only one! it feels more secure when I do it that way cause I won't slide back and hit my trash cans and stuff.
  17. Oct 7, 2013 at 6:40 AM
    #37
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Gotta love the idiots riding down the road w/ their brake lights on
    Guess my poor mans locker trick wont work anymore on new trucks :(
  18. Oct 7, 2013 at 6:44 AM
    #38
    Nickel
    Diego
    2013 T/X TRD
    I'm wondering if it's the traction control thats kicking in, instead of SS.
    When rolling backwards while in forward gear(drive or 4,3,2,1), something kicks in, not sure what. Whatever it is, it pulses brakes like abs, forcefully enough to stall motor.
    Example: when four wheeling, climbing a hill, i didn't quite make it to the top, I released brake pedal, but left in 1st gear(auto), and after traveling five feet backwards, something engaged brakes enough to stall motor and scare the crap out of me.
    I can recreate same effect in my driveway, just by letting truck roll backwards while in forward gear. It's very unnerving, it kicks in so hard that it stalls or nearly stalls motor.
  19. Oct 7, 2013 at 6:57 AM
    #39
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Off road I use brake and gas at the same time a lot. Never had a problem with the nannies turned off.
  20. Oct 7, 2013 at 8:33 AM
    #40
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    I believe that's part of the trans deign. My '06 does it coming back down steep inclines you dont make it up. My truck has none of that crazy TC junk, ABS disabled.
