Stupid TPMS Law
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kevinztaco, Nov 2, 2014.
  1. Nov 2, 2014 at 9:05 PM
    Kevinztaco
    Kevinztaco [OP] Well-Known Member
    none yet
  2. Nov 2, 2014 at 9:08 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    What are you trying to do
  3. Nov 2, 2014 at 9:15 PM
    LBCdan
    LBCdan TACO --> TUNDRA
    Dan
    Long Beach , CA
    2018 Tundra CM 4x4
    Toytec Coilovers, TotalChaos UCA, Icon w/ Resi, Toytec Lift Shackle, Methods w/ 285/75/18 Tires.
    What Law?
  4. Nov 3, 2014 at 1:01 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    X2???
    The truck has to have a TPMS System when delivered from the mfg. After you receive it ( At least in states that do not have an inspection ) you can do whatever you want. Rip it out, or bypass it etc.
  5. Nov 3, 2014 at 1:33 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    This has been a federal law on new vehicles since 2005.
    Some states, very few, are just now having their DMV's require it for inspection.
    Hawaii, Rhode Island, Vermont, and West Virginia are some.
  6. Nov 3, 2014 at 2:04 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I agree the TMPS law is a PITA as implemented by the auto manufactures. It was passed as a "solution" to a number of grisly rollover mishaps on Ford Explorers due to a combination of two factors, a low tire pressure for suspension requirements (26 psi), and overloaded vehicles, the payload at 26 psi was around 800lbs. Folks would fill the Explorer up with large, extended families, run down the highway at 75 mph on a summer day, on a underinflated back tire, the tire would fail, Exploder would roll, and throw bodies out for hundreds of feet, once the initial roll would break all the windows.
    The TPMS requirement was passed instead of Ford having to pay billions in settlement payments. Also, Ford blamed FIRESTONE for the mishaps and ended a 100 year old business relationship.
    If the lawmakers had only included a requirement for universal replacement valve stems easily programmed to the vehicle:) Right now my TPMS is showing fault...my snowtires are on and sensors are on the OTHER wheels and tires.
  7. Nov 3, 2014 at 4:12 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You don't know how valuable the TPMS is until you actually have to use it.
    It warned me in enough time to get off the highway and in a parking lot before my tire was completely flat.
  8. Nov 3, 2014 at 6:37 AM
    Kala
    Kala Well-Known Member
    BigIsland
    05 PreRunner SR5
    It isn't too bad driving with rear tires at 10-15psi after going wheeling. on taller tires you should be able to feel the difference before its too low, lower profile tires not as much.
    On my dads truck its always going off for being too low. I don't have it and it won't bother me. most people I know have already tripped it.
    and its true, your vehicle is unsafe if that light is on. if the pmvi(safety inspectors) think its unsafe at an inspection, they can ground your car and not let it drive off…either make you fix it there or have you tow it off the premises. Now the paper work is all electronic and they take pictures of your vehicle from several different angles. if one station fails you, you're red flagged and another station knows why you failed at the other station.
  9. Nov 3, 2014 at 7:05 AM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    It would be nice if all TPMS sensors were standardized so they could be interchanged from wheel to wheel. But no. Let's have a million different types like we do oil filters.
  10. Nov 3, 2014 at 7:07 AM
    Kala
    BigIsland
    05 PreRunner SR5
    except the oil filter I use on my tacoma fits on my oder toyota trucks with 22r's, 3.0s and 3.4s. do valve stems interchange between factory aluminum rims?
  11. Nov 3, 2014 at 7:12 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    My '13 is the first vehicle I've had with TPMS and I gotta say I love it. I had a nail in my tire I would have never noticed. Even when you lose a bunch of pressure on big, O/R tires it can be hard to see by eye. That TPMS could have been a life saver.
  12. Nov 3, 2014 at 7:12 AM
    Rainmaker
    Rainmaker Well-Known Member
    North California
    2019 Access Cab 4x4
    How sensitive are the sensors? The light has been on for a week, but every time I check the tires they are not low. Does it really light up if they only drop a couple psi, plus it doesnt tell me what tire.
  13. Nov 3, 2014 at 7:13 AM
    OZ-T
    Peter North
    British Columbia
    Reset the system
  14. Nov 3, 2014 at 7:18 AM
    jpachard
    jpachard Well-Known Member
    2006 4WD 4.0L Tacoma 6spd TRD
    Check your spare! Those have a sensor too which I'm glad about!, it's nice to know if your spare is low so when you really need it all is okay.
  15. Nov 3, 2014 at 8:29 AM
    arock
    arock Well-Known Member
    MD
    2020 Cement TRD Off-Road
    I wish the Tacos TPMS system was like the one in my 2011 GTI.... Those use wheel speed sensors in the wheel hubs rather than an actual sensor in the wheel. Didnt matter what wheel/tire combo you had on the car, you just had to reset it when you changed them and you were good to go.
  16. Nov 3, 2014 at 8:31 AM
    PcBuilder14
    Brent
    Nor Cal
    How does that measure tire pressure? :confused:
  17. Nov 3, 2014 at 8:44 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    The TPMS on my Tacoma seems to do the job. However, the light on SWMBO's Honda comes on when the tire pressures are ok. Resetting seems to work for a day or so, then we go through the same routine. I think it is unnecessary for those of us who maintain our vehicles properly.
  18. Nov 3, 2014 at 8:47 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    yes part of our inspection here in VT.
    Our tire centers no longer will install wheels/tires without sensors anymore.
    Some smaller garages will though, small off the beaten path types. :)
    My winter wheel/tire set doesn't have sensors so a friend helps me swap them out.
    I waited for my inspection sticker to roll into Spring & the dealer actually inspected it :confused: without the sensors.
    No light was on for the dealer is right down the street from my house.
    As for the system, it did go off once for me on the highway.
    It came on & within a few seconds my tire was completely flat.
    The light helped :rolleyes:
  19. Nov 3, 2014 at 8:50 AM
    PcBuilder14
    Brent
    Nor Cal
    I can think of multiple accounts where a friend or I added air to a tire just because it was overly sensitive and came on because the front tire was 2psi lower than the other tires :rolleyes:
  20. Nov 3, 2014 at 8:52 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    The idea behind that system is that the lower pressure tire will technically have a smaller diameter as the tire begins to flatten out, then it will have to spin faster to maintain the same overall speed. It then sets off the light. That system won't tell you exact pressure tho obviously. It just knows when one is low.
