Stutter when start
Discussion in '1st Gen. Tacomas (1995-2004)' started by gray97taco, Jun 7, 2023.
  1. Jun 7, 2023 at 3:59 PM
    gray97taco
    gray97taco [OP] Member
    97 Taco Raptor
    97 tacoma 2.4 raptor lined gray
    i have a 97 tacoma, 250k miles, stutters when i start it but runs great after, also gets not great gas mileage. Is this a problem that can be fixed or is it just because the trucks old?
  2. Jun 8, 2023 at 3:59 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Not great mileage to me that means less then 8 mpg is that your range ?
    With my 3.4/5 speed 10 to 12 mpg was normal unless empty then 15 mpg was average.
    Tire size and the weight you haul around effect things.
    Your MIL is not on?? Have you pulled any codes if it is?
    It might be anything !! When was your last tune up ?
    When were the valves adjusted last ? If ever?
    Do a compression test it very well might be just getting tired.
