Stutter while accelerating
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tony-Tacoma-5121, Mar 10, 2023.
  1. May 24, 2025 at 8:03 PM
    #41
    fedup
    fedup Well-Known Member
    Sounds like it to me after I read your op. It's that thump, thump, thump as you step on the gas and no power, hoping to make it home. I replaced the fuel filter at the same time I changed the injector. I was curious if the fuel filter caught much over the years so I back-flushed it before I got rid of it. Man, the amount of gunk in that filter was crazy. I'd change the filter also if you haven't already.
  2. May 25, 2025 at 8:10 AM
    #42
    AndersonK
    AndersonK Member
    1999 Tacoma v6 4x4 Manual
    Ok then I will probably change the injector next and see if it fixes the problem, Thank you all for your help.
  3. May 29, 2025 at 9:24 PM
    #43
    AndersonK
    AndersonK Member
    I changed the cylinder 4 injector today with an aisen oem injector and it was doing fine, it sounded better and had more power but still lacked a little.
    But when i started it up again an hour or two later it’s misfiring really bad again and there’s no cel. It’s shaking really bad at idle and just sounds horrible. I have no idea what to check anymore.
    Also there’s a strong smell of un burnt gas in my exhaust.
