Stuttering/ lugging in an automatic transmission???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JHIZEN, Jul 23, 2021.
  1. Jul 24, 2021 at 7:09 AM
    Tripod1404
    Tripod1404 Annihilator tripod
    I get 21 MPG using the 6th… it is what it is.
    RedWings44 and zoo truck like this.
  2. Jul 24, 2021 at 7:14 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    My tank average right now is 18.6 mpg. Mostly city driving. I leave the auto on D. I never use ECT and S.
  3. Jul 24, 2021 at 7:15 AM
    Tripod1404
    Image how much higher it would have been if you used overdrive gears.
  4. Jul 24, 2021 at 7:15 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Welcome to TW! This is not a new complaint. Some suggest tunes and some suggest waiting it out as the ECU learns your driving habits. My truck works great. It has a lot to do with the shifting. No it isn't a fuel or spark issue. And running 91 or 92 octane is just you throwing your money away because that's meant for higher compression engines and will not benefit you here.
    I see it was Friday.
  5. Jul 24, 2021 at 9:52 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Take it to the dealer. Trade it in for a Manual (Only after a extensive test drive). No more Auto transmission problems! Viola!
    ian rogers likes this.
  6. Jul 24, 2021 at 10:12 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Drivers are not similar.
  7. Jul 24, 2021 at 1:37 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I get nearly that in the winter and 23-24 mpg now in the summer. Combination of some city and mostly secondary highways while maintaining under 60 mph.
  8. Jul 24, 2021 at 1:56 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Sounds like flex lockup(a.k.a. torque converter clutch) isn't allowing a smooth transition; it can be caused by a multitude of things.
  9. Jul 24, 2021 at 8:32 PM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    I baby my Tacoma, drive her real easy. You'll find me in the right lane driving the speed limit. The Tacoma does not like to go the speed limit with the stock ECU tune. The transmission shifts to 6th gear at way too low of a speed and then the motor will sit in the 1200-1500 RPM range and it will lug noticeably.
    I had a 3rd gen 2wd access cab that did not have any issues at all and the truck was perfect except for a lack of 4x4. My current rig is a TRD OR LB, and she is heavy as compared to the 2wd access cab. My guess is the weight of the truck contributes to the strain on the powertrain at low RPM.
    KDMAX Light-Tip Premium Octane tune solved all my issues and the truck drives how I want it to. I can cruise the speed limit on city roads, and on the highway I have plenty of power to merge into traffic. Dyno tests show an increase of roughly 12HP and 12ft/lb of torque after KDMAX tuning (source linked below).
    https://www.havocspeed.com/3rd-generation-toyota-tacoma-ovtune-dyno-results/
    *Edit: this source is for the 'OVTune' not KDMAX, but I would expect similar results for a KDMAX dyno.
    D. Lengua likes this.
  10. Jul 25, 2021 at 5:35 AM
    zoo truck
    None
    I've got supposedly the latest toyota factory tune in my truck which is all stock except for roughly the same size AT tires. It cruises fine at any speed, no lugging, no anything. 1200 rpm in 6th gear is fine, smooth low end still. Can't quite say the same for a buddies 2019 tacoma, as it will buck if that low rpm. His truck has the same updated tune as i do. Some trucks just run better than others.
  11. Jul 25, 2021 at 5:39 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    at the speeds U mention suburban/around town
    U ARE Lugging the engine ........observe/nottae gear + rpm
    it IS Possible to run an engine toooooo slow
    4th gear is correct
    Mercedes mention last week ( has been known for a while )
    by 2030 they will being fully TOTALLY Electric
    many marques are trotting out ‘ E “ vehicles to test the waters
    ( obtain wear/ tear mileage longevity data real world )
    CARB / EPA standards are getting tighter every year !!!!
  12. Jul 25, 2021 at 5:47 AM
    Clearwater Bill
    Billy
    Largo Florida
    Your fuel choice has nothing to do with it other than wasting your money with higher octane.
    That said, I'd suggest a warranty complaint and run that road out before asking a bunch of strangers on the internet when you only have 1k on the truck.
    As you see, you get a full on fruit salad of answers.
    Suggestion. Next vehicle purchase, take a full test drive following your normal daily driving routine.
    Sungod and RedWings44 like this.
  13. Jul 25, 2021 at 6:27 AM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    I had it on my 2019 for a while under the right driving conditions. Its not something you can catch on video. Mine usually will do it when under 1500rpm and steady throttle. I added the shudderfix transmission additive to mine a couple months ago but didnt cure the issue. Ive learned after running 93 octane about half the time, since it seemed to help, that its not the higher octane but better quality fuel that makes a difference. I would recommend top tier fuel whichever gas stations that have it in your area. Here in PA Ive been using BP/Amoco since the truck seems to prefer the better gas.
    I also just had the KDMaxx tune done a week ago and while the truck drives and performs better overall I can still feel a hint of the shuddering under the right driving conditions.
    BRUIN8124 likes this.
  14. Jul 25, 2021 at 7:01 AM
    RockLinc
    RockLinc Member
    2021 Tacoma
    I have had my 2021 for little over a month, 500 miles on it. I have noticed my engine stuttering at low idle almost like its going to die if I don't give it some gas but it has never died on me. Also, when I'm driving a higher gear (5 or 6) and truck needs to downshift it seems to stutter also until it downshifts. Using ECT or running in S mode helps. Gear 4 is good at about 45 mph and runs at 2000 RPM but I wish the auto tranny would just do its job better, downshift sooner, and not make engine stutter. I'm not much of a techy but I notice the stuttering. I'm trying to ignore it because I don't think it is really a problem.
  15. Jul 25, 2021 at 7:07 AM
    #35
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You can manually downshift an automatic too. Put the truck in a lower gear if you need to do so. Unless you're doing 60+ mph it has no business above 4th gear anyway. Learn how to drive the truck instead of letting the truck drive you.
  16. Jul 25, 2021 at 3:11 PM
    #36
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    I feel the same thing like a slight miss or stutter while driving on surface streets 40-50mph. I blame Toyota for upshift so early and the motor lugging along.
    I’m at 4900 miles and after the 5k I plan on getting it tuned. Hopefully it will address this small annoyance.
  17. Jul 25, 2021 at 9:05 PM
    #37
    trdxtacoma
    trdxtacoma Well-Known Member
    18 Tacoma SR AC
    Mine does the same thing. I am almost certain it's bad TCU programming on Toyota's part. But I'm not gonna go bitch n moan to a Toyota SA that doesn't care. So I just hope if it blows, it'll blow before my powertrain warranty is up. Actually my 6AT worked smooth up until recently. The only cause I can think of is the trans being overheated from hauling alot of weight(4000lb trailer + 2000lb payload). But I have my doubts because it was a short distance and I made sure to take it easy. It worked fine after the load. Only started seeing it a few days later. Might be worth paying for a trans drain & refill to see if it helps.
    I think I saw somewhere that Toyota fills all of the transmissions with the same amount of ATF regardless if it has a trans cooler or not. The difference is marginal(1 quart?)
    3rd gen quality is hit or miss. I have a neighbor with a 16 TRD OR thats runs flawless with 70k miles but here I am with my 18 SR 17k miles - peeling door panel - broke tailgate - shuddering transmission - broke power window switch. Probably has something to do with Toyota corporate trying to push for higher efficiency on the assembly line.
    BWorned and zoo truck like this.
  18. Jul 26, 2021 at 2:47 AM
    #38
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    That's a great idea and maybe I misunderstood your meaning, but I don't know of any dealership who would let you test drive a brand new vehicle long enough to simulate your daily driving routine. I had about a 7-10 mile test drive in my truck which included a road where you could go 50-60 as well as some suburban streets. I did notice the shifting, but also noticed a bit more right foot pressure helped considerably. It's also gotten better after 1,500 miles and I imagine it will keep improving.
  19. Jul 26, 2021 at 3:32 AM
    #39
    jamestown
    jamestown Well-Known Member
    NB, Canada
    2017 DCLB TRD Sport 4x4 AT Silver Sky M
    Off road wheels Factory HT tri fold tonneau
    Adjust your seat forward a click or two. Gives you a heavier foot.
  20. Jul 26, 2021 at 4:39 AM
    #40
    TonyG2
    TonyG2 Active Member
    2020 Tacoma SX
    Heavier foot is the key, my truck definitely drives better when you dont baby the gas peddle
    myn75 and cropduster78 like this.
