Stutters on take off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hockeymc3, Aug 10, 2017.
  1. Aug 10, 2017 at 6:35 AM
    Hockeymc3
    Hockeymc3 [OP] Well-Known Member
    Colorado
    2017 Super White Tacoma Off-Road
    I have a 17 off-road with 3000miles. Just started yesterday when I take off from being stopped it stutters a couple times then takes off. Help? It's like the gas gets cut off a couple times then goes. Blah. Thanks.
  2. Aug 10, 2017 at 6:38 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    A/T? Hows the idle? Check the air intake hose--some have noted that it was loose from factory.
  3. Aug 10, 2017 at 6:52 AM
    beverlytaco
    beverlytaco Well-Known Member
    2017 TRD off road double cab
    Happened to my 17 DCOR. It's the restriction of the intake. I swapped it out with a K&N CAI and the acceleration smoothed out.
  4. Aug 10, 2017 at 7:07 AM
    Hockeymc3
    Colorado
    Automatic and I also wanted to add that it only does it when lay on the gas. I wouldn't know where the air intake is. Any pictures?
  5. Aug 10, 2017 at 7:15 AM
    harrycary
    harrycary Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    That is absolutely not true. Putting a CAI on the OP's vehicle has a 0% chance of solving his issue. In fact the factory oil on a K&N filter can coat the MAF element and mess up the fuel metering. You should remove the oil with Tide washing detergent, and rinse.
    rlx02, mateo_roberto and over60 like this.
  6. Aug 10, 2017 at 7:18 AM
    harrycary
    Harry
    If this occurs when you immediately smash the pedal to the floor, then The studded is a result of a safety mechanism, where the code does multiple checks to assure that it was not a failing pedal control and hence will help you avoid an unintended acceleration event. Toyota is careful about this after the fiasco they had before.
  7. Aug 10, 2017 at 7:23 AM
    beverlytaco
    This also might be another issue I'm having. Is it only in first gear? Under firm acceleration? Truck shakes for a few seconds and then goes away?
  8. Aug 10, 2017 at 7:24 AM
    harrycary
    Harry
    Please describe. Is this a driveline vibration you are feeling, or a studder acceleration issue?
  9. Aug 10, 2017 at 8:17 AM
    Hockeymc3
    Colorado
    A studder with the engine when accelerating. Push the gas it goes then immediately it looses power, goes again, looses power and then finally goes. When I say looses power I mean gas power. Not electrical. Or you could use the word cuts out.
  10. Aug 10, 2017 at 8:19 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Common complaint. Mine does the same. Nothing like pulling out into a tight window in traffic, Goosing the accelerator and the engine feels like it's going to die halfway into the intersection. :eek::eek::eek: SUPER aggravating
    Sandycheeks4x4 and LEXICON like this.
  11. Aug 10, 2017 at 8:19 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    are you flooring it? getting into traction control? any lights on the dash when it happens?
  12. Aug 10, 2017 at 8:20 AM
    smitty99
    Scottsdale
    No lights for me. 3/4 throttle maybe. Close to flooring it...but you pretty much have to in order to get this pig running.
  13. Aug 10, 2017 at 8:23 AM
    harrycary
    Harry
    Push the gas, or smash the pedal to the floor, at an almost immediate rate?
    smitty99 likes this.
  14. Aug 10, 2017 at 8:31 AM
    -JDC-
    -JDC- Well-Known Member
    2017 TRD Off Road
    I've had this happen a couple times too, but never when ECT is on. Now I only drive with ECT on and its habit to press both the start button and ECT button when I start up the truck.
  15. Aug 10, 2017 at 8:44 AM
    beverlytaco
    Yup, my 17 DCOR does the same. I almost got smashed the other day pulling out of my street to. I mashed the pedal and got NOTHING! I had to quickly let off and tap the pedal less aggressively. Only had a spoilt second to spare. Awful!!!!
  16. Aug 10, 2017 at 8:49 AM
    Hockeymc3
    Colorado
    3/4 To flooring. No lights, not traction control
  17. Aug 10, 2017 at 8:50 AM
    Hockeymc3
    Colorado
    I have not had this problem before. Frustrating
  18. Aug 10, 2017 at 8:53 AM
    Aussieshed
    Aussieshed Well-Known Member
    Seattle, WA
    2017 White TRD Sport 4x4 w/JBL
    Yep happens with mine too and I have the Sport.
  19. Aug 10, 2017 at 8:53 AM
    bladsville
    bladsville Well-Known Member
    DFW
    2017 TRD Off-Road 4X4 MT
    Could have been the fact that the intake clamps were too loose from factory. There are threads about issue in this forum. Installing the intake (or any intake for that matter) properly is what could have fixed your problem.
  20. Aug 10, 2017 at 9:01 AM
    Hockeymc3
    Colorado
    Do you have a link by chance
