Sub/Amp shut off after hard hit
Discussion in 'Audio & Video' started by chadderkdawg, May 30, 2012.
  1. May 30, 2012 at 6:24 AM
    chadderkdawg
    chadderkdawg [OP] Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    When my sub hit's too hard, it will quit running, not sure if it's the amp or the sub that stops, but if I turn everything off and back on it will play again. I've got 8 gauge wire running to a 500 watt peak amp, at 1 ohm dual voice coil Alpine 10 inch type R. My assumption is that I need to get 4 gauge wire to fix the issue, agree? Disagree? Thoughts?
  2. May 30, 2012 at 6:28 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    Is the amp stable at 1ohm?
  3. May 30, 2012 at 6:30 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    This was happin with me I forgot what the wire was called but it's hook up to the wire when you turn your key it turn the power on to the amp usually this gets loose and makes your amp not work
  4. May 30, 2012 at 6:33 AM
    berg2065
    berg2065 Well-Known Member
    Phoenix
    11 reg cab 4x4
    5100's set at .85,eibachs, LR uca's, toytec 1.5" aal, ride rite bags, receiver hitch, ARE cap with bedrug, Thule rack, wet-okole cover, ultragauge, kenwood dnx5180 navi/receiver, ss rubi404 running factory doors and JL8
    is hard to say without knowing amp specs and how you have the dual voice coils wired to the amp, but my guess is that the amp is going into protection mode on hard hits and when you turn off and back on, it resets itself. A 1 ohm load is pretty low for the average amp and if it can handle it, then it probably does need 4 gauge running to it.
  5. May 30, 2012 at 6:34 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Agree but make sure the sub is wired correctly first.
  6. May 30, 2012 at 6:44 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
  7. May 30, 2012 at 8:41 AM
    Warhorseforever
    Will
    Sand Lapper
    Take it back to 4 that amp is not 1 ohm stable. If you don't know how to wire it like that I'll post a link up in a minute.
  8. May 30, 2012 at 8:42 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    I'm familiar with how to wire into 4, sucks that I'm going to lose the extra wattage though.
  9. May 30, 2012 at 8:45 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I think the problem is solved in this thread.... however for any that may read this in the future....another possibility can be low battery voltage because many 'smart' amps shut down at a certain voltage. Cranking it up high and shutting off always told me my battery was dying.
  10. May 30, 2012 at 8:53 AM
    berg2065
    Phoenix
    11 reg cab 4x4
    I have never tried this, but have heard of guys only connecting one of the voice coils in a dual sub. One of the downsides I have heard is that it cuts the power handling ability of the sub in half.
  11. May 30, 2012 at 8:58 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Two voice coils running at 350 watts will sound better than one running at 500, but that is an option I haven't thought about yet...
  12. May 30, 2012 at 9:02 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    The above is true.
    I would still wire up both of the coils. You don't need as much power as you think you do.
  13. May 30, 2012 at 9:22 AM
    Warhorseforever
    Will
    Sand Lapper
    Perfect excuse to buy another one. :D
