sub box question. hope someone can help
Discussion in 'Audio & Video' started by 2011BlackTaco, Feb 13, 2012.
  1. Feb 13, 2012 at 7:40 PM
    2011BlackTaco
    2011BlackTaco [OP] Well-Known Member
    Josh
    Tennessee
    11 Prerunner
    6 inch Pro Comp lift kit, 18" XD Monster rims, 285/65/18 Nitto Trail Grapplers, Smittybilt black step bars
    I am looking for a sub box that will fit behind the driver side rear seat or one that will fit on the passenger side of the DC.
    The specs on a box would be great i think i can make my own that will fit without removing the factory bins and child restraint bracket. Im looking for about .55 cubic feet of space in the box, if this is not possible can someone help me out before i go wasting my time trying to build one. The box will be for the IDQ 10" sub it seems practical and possible on paper but i dont know about it for sure.
    Any help or input would be good, i can seem to find anyone who has been able to do this without removing the brackets and bins. The search always pulls up the people who have done this on the passenger side of the rear seat which might end up being my only option.
  2. Feb 13, 2012 at 7:46 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    So we've scratched the 13TW5 option and are moving on to an IDQ 10"? Are we still using the mysterious 600w amp from the previous thread?
  3. Feb 13, 2012 at 8:06 PM
    2011BlackTaco
    Josh
    Tennessee
    11 Prerunner
    haha well im a bit indecisive about what i want but id like to keep it stock and i think .55 is a little more practical for what im trying to do. .8 for the 13TW5 is def not gonna fit. Yeh the 600 watt amp because its the JL XD model which can fit almost anywhere
  4. Feb 13, 2012 at 8:19 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
  5. Feb 13, 2012 at 8:24 PM
    2011BlackTaco
    Josh
    Tennessee
    11 Prerunner
    I did not realize until just now that you had been a tremendous help on my previous thread, i never got the notification for the postings that have been made. i have not ruled out that setup but im trying to keep my options open and come up with something a little different than the normal.
  6. Feb 13, 2012 at 8:25 PM
    Warhorseforever
    Will
    Sand Lapper
  7. Feb 13, 2012 at 8:28 PM
    2011BlackTaco
    Josh
    Tennessee
    11 Prerunner
    I have heard that the stealthbox doesnt deliver a loud bass system but that it is more of a small amount of added bass, to be honest i have heard all mixed opinions of it and for 700 bucks id like to know it is AMAZINGLY GOOD. This statement has me wondering tho. Requires permanent modifications to the plastic trim panels behind the rear seat. i have the wet okole seat covers over my rear seats will that effect the sound????
    Yes that is the amp that i have
  8. Feb 13, 2012 at 8:29 PM
    2011BlackTaco
    Josh
    Tennessee
    11 Prerunner
  9. Feb 13, 2012 at 8:30 PM
    Warhorseforever
    Will
    Sand Lapper
    It may affect the sound a little bit but it really isn't much to me. I have subs behind my rear seat but no wet okole covers so I couldn't tell you for sure.
  10. Feb 13, 2012 at 8:56 PM
    jbrooks
    jbrooks Active Member
    Tucson, AZ
    Prerunner SR5
  11. Feb 14, 2012 at 3:00 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    You will not fit an IDQ (or .55 ^ft2) without modifying the plastic bin.
    The Alpine Type R thin would be where I would be looking if I were trying to get something in without modifying plastic. Probably on the passenger side, and I would shoot for around half a cube. A bit smaller will be OK.
  12. Feb 14, 2012 at 6:37 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Curious as to why you want to keep the plastic in there? Once a sub box is in place the storage area is gone.
    I don't have picsright now, but I modified a SoundOffAudio double sub box for a double cab by cutting off one sub box, and placing the remianing sub box/amp board behind the passenger side seat. That box gives .65cuft and an amp board. The plastic does need to come out, but the seat anchors stay and no other back wall mods are required. I have the seatback plastic removed, but, depending on the sub, this might not be necessary.
  13. Feb 14, 2012 at 10:56 AM
    TurboGT
    Gabe
    Portland
    I've got this crazy idea (that when I go to cut out my plastic) of throwing a dremel-type cutting disc into the router on the router table to make a really clean, straight cut close to the front of the plastic (maybe 1/8" to 1/4" deep) that will let me reuse the plastic as a front cover to whatever sub box I build - you guys with the exposed metal under the window and side panels that just stop are crazy to me - and that I can somehow reattach the bins later on should I decide to buy a newer Taco.
    That make any sense??
  14. Feb 14, 2012 at 11:56 AM
    NOCENTS
    NOCENTS Well-Known Member
    Arm pit of Cali
    08 TRD DC needin some lovin
    loooooong list of mods coming as soon as I finish the audio/video system
    Why cut the bins at all............ I also cant stand the look of the un finished top so I made a filler cap for the top. That was way easier then trying to cut the bins. pull them out and put them in the garage. Build a box and an amp rack to meet your needs and cover the back. Or make a box and amp rack on the passenger side and have it meet up with the bin on the drivers side if your doing a single 10 or TW5.
  15. Feb 14, 2012 at 12:01 PM
    NOCENTS
    Arm pit of Cali
    or look on CL or here to find some ones old bins cut those and save your for when you up grade. Use that as the face of your TW5 or TW3 box on the passenger side and then cover it so will look factory and still be able to keep the bin on the left.
  16. Feb 14, 2012 at 12:06 PM
    TurboGT
    Gabe
    Portland
    Yours is definately one of the more finished ones that I've seen, but I can still see the gap between the board you made and the factory panel (in the second pic)....
    Just knowing it's there would drive me insane
  17. Feb 14, 2012 at 12:18 PM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Ahh, that is different and makes sense. I thought your intent was to keep the stock plastic totally unmodified and in place. Problem with cutting the plastic at all is that once you do so it will never meet up exactly as stock again since the cutoff wheel takes material away.
    If that's your intent, do as was mentioned earlier and find a replacement plastic to cut up. I'd like to do the same, but haven't found a reasonably priced "cutter". Price + shipping is too high for me as all I want to use is the top 6" or so.
    BTW, I originally had a single sub behind the drivers side rear seat and had cut the plastic to fit around the box. Like you, wanted a nice finished look. After I upgraded to the passenger side box, I had to find a replacement plastic to fill in the driver's side again since I cut it up.
  18. Feb 14, 2012 at 12:34 PM
    NOCENTS
    Arm pit of Cali
    I agree where the outer edges of the bins connect to are still visable, This was only my first attempt. This is not my finished set up. I plan on gettin the 13TW5v2 2ohm and will then do somthing more polished that will cover or clip in to those spaces. But it will take me a bit to get the sub, its not even released yet
  19. Feb 14, 2012 at 6:36 PM
    2011BlackTaco
    Josh
    Tennessee
    11 Prerunner
    Well it seems my hopes of keep plastic in there is gone which i guess is fine. i will pro have to get Mr. Marv to build me a good custom box and do the best i can with keeping the stock look. The only thing i have seen is a box by mr marv for the passenger side that only requires cutting the bottom and part of the back of the plastic bins out. Appreciate all the help you guys have given me !!!
  20. Feb 16, 2012 at 10:05 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    @&$! The plastic bins
