Sub Crackling!! HELP!
Discussion in 'Audio & Video' started by sir1123, Sep 9, 2013.
  1. Sep 9, 2013 at 2:32 PM
    sir1123
    sir1123 [OP] Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    So recently my sub woofer has been crackling and popping when music is on and when music is off. It is driving me insane and I am about to shoot it. I will have the volume all the way down and all I hear is that damn thing cracking and popping. I have checked the connections and it is all tight. What do I do? Keep in mind it is a cheap Sony Explode 12" and I think it is about to explode!
  2. Sep 9, 2013 at 2:33 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
  3. Sep 9, 2013 at 2:45 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Crackling while no music is playing means that its still getting some kind of signal from your amp. That means either the amp is bad and sending false signals or the radio is bad and and sending a bad signal. Or could even be pinched or defective RCAs. Or it could be noise interference. Or it could be dirty power going to your amp. Or heck it could even be as simple as a blown sub. That's the easiest to check though. Disconnect sub and use a multi meter on the voice coil to check the ohm load. If the ohms are correct then sub isn't blown. Next step would be to measure voltage at the RCAs
  4. Sep 9, 2013 at 2:45 PM
    sir1123
    Charleston
    Really? it still plays bass and sounds decent besides the fact that is makes that noise.
  5. Sep 9, 2013 at 3:49 PM
    sir1123
    Charleston
    I have already disconnected the audio from the stereo to the amp and it still does it.
  6. Sep 9, 2013 at 4:20 PM
    sir1123
    Charleston
    it also doesn't happen all the time just every now and again
  7. Sep 9, 2013 at 4:27 PM
    ProForce
    Anthony
    Alaska
    With that said I'm gonna guess its the amp going bad. Or a pinched/grounded speaker line between the amp and sub. Easiest way to eliminate one or the other is to disconnect the sub and measure ohms at the voice coil. If it doesnt match up then its a blown sub. If the sub tests fine, then its and amp or cable.
  8. Sep 9, 2013 at 4:39 PM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    Sounds like you pinched a RCA. Check all your wiring if your sub is still reading correct impedance. Unplug RCAs from amp.....does it still make the noise? Smell the back of sub and smell the amp if you lack a voltmeter. If either smells like burnt electrical then you found your problem. Could also be bad connection internally in the amps RCAs .
  9. Sep 9, 2013 at 5:01 PM
    ProForce
    Anthony
    Alaska
    Yep
  10. Sep 9, 2013 at 5:09 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    When you checked the wiring, did you pull the speaker out and check the wiring inside the box? Most forget to and I've found that to be the problem before
  11. Sep 18, 2013 at 11:50 AM
    sir1123
    Charleston
    So I got rid of the whole setup. Getting a pioneer slim fit 10".
