sub help
Discussion in 'Audio & Video' started by pinktaco808, Nov 13, 2010.
  1. Nov 13, 2010 at 7:08 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    i, looking for subs that would fit and work in my standard cab pref 2 10 0r 2 12??? any help... i want it to slamm mine is a 2006 tacoma standard cab.. also how many watt suggest to run like amps how big???
  2. Nov 13, 2010 at 8:40 PM
    747 function > form
    1st Gen.
    JL 12W3v3; Zapco or PPI w/minimum 200w (RMS) to each sub.
  3. Nov 13, 2010 at 8:44 PM
    bowhunter11199
    bowhunter11199 Well-Known Member
    i have an extened cab and i have 2 12's and 1200 watt amp. i love it:D. and if your seroius about it also get a capasitator. they make a difference
  4. Nov 14, 2010 at 9:58 PM
    pinktaco808
    looking for subs in a standard cab
  5. Nov 14, 2010 at 10:52 PM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    im running the JL 13TW5. kinda expensive tho. your gonna need to keep the mounting depth pretty shallow, id say at MOST 4"or 5"
  6. Nov 15, 2010 at 5:45 AM
    pinktaco808
    does iy slam and have deep base??? i wanna run 2 subs
  7. Nov 15, 2010 at 9:21 PM
    pinktaco808
  8. Nov 15, 2010 at 10:38 PM
    militaco
    militaco Well-Known Member
    Hawaii
    2009 Double Cab, '99 Regular Cab
    I'm running one JL 10.....ported....it slams pretty good for standard cab.....if money was no object, i'd do what Kelson did.
  9. Nov 16, 2010 at 10:08 PM
    pinktaco808
    that only one though i want 2
  10. Nov 17, 2010 at 12:20 AM
    09638 SCRAPER
    oahu,hawaii
    11 trd sport sr5 prerunner
    2% tint, 20% entire windshield tint, led bulbs, hids, debadged, grey plate covers, shaved antenna, alpine in dash, rockford t2 and amps, rockford highs and mids, 35x12.50x20 toyo mt's, 20x12 fuel octane's deep, 1.5 inch wheel spacers, camburg UCA's, 6" lift w/4" blocks & AAL, 3" body lift, open hood scoop, BHLM, painted emblem, K&N filters, weather tech mats. Next Mod: resevoir rear shocks, Vinyl camo wrap when I'm bored of the grey...
    your truck is a standard cab so that really limits your options because the space for your subs (behind the seat) is so small. you wont be able to fit a really hard hitting sub in there because there isnt enough room for the box. by hard hitting I mean jl w7, kicker solo-x, rockford t2, etc...
    you need to find a sub that sounds good in "truck boxes" (fits behind the seat)
    you might be able to fit a set of 10 inch kicker L5's or L7's but im not sure.
    I suggest you go down to your preffered stereo shop (mine is carstereo express by pearlridge) and ask them what subs will fit. from that they will tell you what size amp you need. I recommend a name brand amp that wont break down or overheat. I like rockford, never gives me problems.
  11. Nov 17, 2010 at 10:23 PM
    pinktaco808
    hmmm will look
  12. Nov 22, 2010 at 9:05 PM
    pinktaco808
    up what the best sub box design
  13. Nov 23, 2010 at 6:33 PM
    Mongy
    Mongy Boost Lover
    Athens, TN
    97 4x4 was 10psi - 04 5lug 5/6 Drop
    KO Racing Turbo Kit. Beefed Taco Drop KYB MONOMAX Shocks Belltech Coils Wheels and Tires 5/6 drop
    HIFI Sound connection has the best, deepest, cheapest, best built box for 95-04 standard cabs. Take it from me. I have 2 standard cab tacomas and both have 2 10's in them. 97 (my first system) hifi SC box, 2 lazar vector 10's 600w Crunch amp. Hit really good mids and highs, but couldnt hit lows to well. 1.) becuase they are 10's and 2.) because they are shallow mount subs. Not to bad on price think the hole setup cost like 300 bucks maybe.
    Now on the 2004. I got the same box, but with a 3/4 spacer, which brings the mount depth to a WOPING 6". Which is ALOT for these regular cabs. I have 2 Eclipse 6010 10's really powerful btw. And a 2000w Mono crunch powerone amp. AMAZING AMP.
    Wired to run 1 ohm. Thing pounds.
  14. Nov 23, 2010 at 9:46 PM
    pinktaco808
  15. Nov 23, 2010 at 9:47 PM
    pinktaco808
  16. Nov 23, 2010 at 9:47 PM
    pinktaco808
  17. Nov 23, 2010 at 9:48 PM
    pinktaco808
    which one
  18. Nov 24, 2010 at 5:41 AM
    pinktaco808
  19. Nov 24, 2010 at 5:42 AM
    pinktaco808
    where did you get your second box link????
  20. Nov 25, 2010 at 12:15 AM
    pinktaco808
    what the dimension i want either 2 10 0r 12
