Sub install. what am i missing?
Discussion in 'Audio & Video' started by CUtigerfan, Dec 29, 2010.
  1. Dec 29, 2010 at 6:43 PM
    CUtigerfan
    CUtigerfan [OP] Well-Known Member
    South Carolina
    04 Base
    Daystar 1.5" coil spacers, bedlined bumpers, clear corners, aftermarket stereo, 20% tint, half debadged
    My brother decided he wanted a sub in his truck for Christmas (just got a 98 ext. cab) and since I put the headunit and speakers in my truck I told him I would order everything and install it for him. Well I'm sitting in the floor with everything and I think I'm missing a few little things.
    First off I bought a headunit, a harness to plug it into the factory wiring, a 12" sub, an amp, amp install kit, and a box.
    I know I can install the headunit and wire the amp to the battery b/c I've done that before. This whole sub box has got me a little stumped. I've got the box, the sub, a gasket, and wire. I don't have screws or anything that will connect to the terminals on the side of the box. Can somebody explain to me how the terminals in the little cup thing work? I don't have a soldering iron and really don't want to try to do that so if theres a way around that I would prefer to go that route. And it seems kind of stupid to ask but what kind of screws should i use?
  2. Dec 29, 2010 at 6:52 PM
    KAWAIANIANI
    KAWAIANIANI Well-Known Member
    TRD BLACKED OUT
    Weather tech stone deflector, Craven speed stubby antennae,DTLT and rear O2 Sims, URD Y pipe, 40 series flowmaster w/ 3" piping. Urd maf calibrator, TRD supercharger, TRD CAI.
    Got any pics of the "cup". Most have a red and black type knob that you unscrew and it exposes a hole to put the end of the wire in after removing the insulation, there are other types that you pull on to expose the whole, it all depends on what type you have.
  3. Dec 29, 2010 at 6:55 PM
    c.coulby
    c.coulby Well-Known Member
    Cameron
    Summerville, Georgia
    2009 TRD Sport
    do you have pics of the terminals inside and out i can possibly help you out with that problem.. I have installed a couple systems in various cars of mine...
  4. Dec 29, 2010 at 6:56 PM
    CUtigerfan
    South Carolina
    04 Base
    I don't have a pic but it sounds like the 1st one you said. its got 2 gold pieces that i thought were plugins (seems kinda dumb now) they unscrew and theres a hole in a center piece. I know for the inside there are some slide on connector things but is there a piece i need to buy for the outside part or can the wire just be slid through the hole and tightened down
  5. Dec 29, 2010 at 7:02 PM
    KAWAIANIANI
    TRD BLACKED OUT
    Just slide the wire after removing the insulation into the holes and tighten down and your good to go. Remember when installing wiring to mind polarity becuase it does effect performance even though most people dont pay attention to it. positive to positive and neg. to neg.
