Sub making weird noise
Discussion in 'Audio & Video' started by CayucosTacoma, Apr 1, 2012.
  1. Apr 1, 2012 at 3:45 PM
    CayucosTacoma
    CayucosTacoma [OP] Just think outside the Yota
    San Luis Obispo/Santa Barbara CA
    1998 Tacoma, 4x4 5 Speed, V6
    Specs in the Build Thread
    So i have a JVC double din, and a JBL 12 inch sub, a MX3 bass controller, and a 1000 watt amp.
    When i have the car on and have the bass controller know all the way to the right the sub makes a bunch of noise, even if the volume on the head unit is turned all the way down. Sounds like the sub is idleing if that makes sense?
    But idk what it could be i have changed the ground location 3 times! I checked all the RCA connections. so if anyone has any clue what it could be id appreciate the input
  2. Apr 1, 2012 at 3:51 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    sounds like feedback.
    if your RCA cables are not high quality they could have really crappy shielding.
    does it make the noise with the car off? does it change if you rev the engine?
  3. Apr 1, 2012 at 4:00 PM
    CayucosTacoma
    it does not make the noise when the car is off, and i cant recall. if i have he bass controller know near half way on then there is no noise. but ill check next time i head out
  4. Apr 1, 2012 at 6:45 PM
    Yoytoda
    Roland
    completely stock
    it is picking up frequency put out by the alternator. i would try higher quality rca if you dont already have good quality. (no scosche crap)
    the best setup (and still cheap) is to get RCA ends and put them on good coax cable.
  5. Apr 1, 2012 at 6:53 PM
    CayucosTacoma
    Hmmm I have some monster cables and some cheaper schoches ones, I guessI'll try and switch em around
  6. Apr 1, 2012 at 6:57 PM
    Yoytoda
    Roland
    completely stock
    i have $50 monster cables and no hum. The scosche ones i got in a kit, hum like crazy, i cut them up and the shielding was thin foil that was wrapped. braid is much better shielding
    my other vehicles are always rf coax that i get from work. i cut off the BNCs and put RCAs on and they are the best
  7. Apr 1, 2012 at 7:01 PM
    CayucosTacoma
    Ilook try the monsters when I get home
  8. Apr 2, 2012 at 10:36 PM
    Yoytoda
    Roland
    completely stock
    Any luck?
  9. Apr 2, 2012 at 10:43 PM
    CayucosTacoma
    got side tracked with cb whip, and was moving too. im going to try it out first thing tomorrow morning
  10. Apr 3, 2012 at 1:35 PM
    CayucosTacoma
    no luck, still making same noise
  11. Apr 3, 2012 at 3:13 PM
    CayucosTacoma
    got it fixed, but now only like 3 stations of FM radio are working. any ideas why?
  12. Apr 4, 2012 at 8:48 AM
    Yoytoda
    Roland
    completely stock
    Did maybe the antenna come unplugged from the back of the deck?
  13. Apr 4, 2012 at 10:11 AM
    CayucosTacoma
    I checked but I'll double check again today
