Sub Mounting Depth?
Discussion in 'Audio & Video' started by bowhuntingaddict, Feb 24, 2011.
  1. Feb 24, 2011 at 3:06 PM
    bowhuntingaddict
    bowhuntingaddict [OP] Well-Known Member
    I was wondering how deep of a sub everyone is fitting in there double cabs. If you could list the sub, mounting depth, and what box you have, that would be great.
  2. Feb 24, 2011 at 3:30 PM
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    King Remote Resi Suspension - Total Chaos UCAs - Full Katzkin Leather - Leer Camper Shell - Custom Projector Halo Headlights - HID Fogs - Eagle Eye LED tail lights - Rigid Industries LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Dakar Progressive Leafs - Fuel Beast Wheels wrapped in Hankook Dynapro ATMs - 4 Tie Down Mod - Pop N Lock - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    JL 13TW5 with a depth of 2.54" in a custom box made by me. Depending on thickness of MDF, sub excursion, and removing the seat back panel, around 6"-6.5" is right at the absolute limit. Might be able to squeeze another 1/2" if you use a fiber glass back. Do some digging the answers are out there.
  3. Feb 24, 2011 at 3:36 PM
    bowhuntingaddict
    Thanks, yeh thats what I been doing, but sometimes I get a little tired of "surfing" and tend to be one of those guys that puts posts up that are already out there.
  4. Feb 24, 2011 at 4:01 PM
    mrmumbels
    mrmumbels Well-Known Member
    Land O Lakes, fl
    09 prerunner
    none
    2 IDQ12s
    5.8" deep
    audio enhancers box
  5. Feb 24, 2011 at 4:08 PM
    Yota_dvl
    Yota_dvl Well-Known Member
    Jesse
    Central Utah
    03' Ext cab 4x4
    SAS KIT - trail-gear 5" lift alcan springs greasable shackels gears front 410 rear 411 Kicker subs 3,000 mile drive to Alaska, 3,000 back "Mod" rear diff breather
    kicker cvx - i did 14 inches the bigger the louder :D
    -though a buddy of mine told me that installs them "for what ever size sub divide by 2 then + 2 = total what should be good
    Example 12" sub / 2 = 6 + 2 = 8 inches of mounting depth minimum
    .... checkup on http://www.rockfordfosgate.com/rftech/box_wizard.asp they can help you figure volume so you can know how big you want it with it the subs limit to sound good
  6. Feb 25, 2011 at 12:21 AM
    DevL
    DevL Well-Known Member
    2 IDQ v3 10" subs... not enough airspace for 12" versions and I'm actually a little short on airspace since my amp is on my sub box.
  7. Feb 25, 2011 at 6:20 AM
    tommelleo22
    tommelleo22 Well-Known Member
    Joe
    New Castle, PA
    07 trd sport off road
    Yellow Fogs kicker cvr 10's alpine ivaw205 head unit, leveling kit
    audio enhancers box mounting depth is 5-7/8" and i just traded in my fosgate p2's for JBL gto10's which are far better imho. they slam but are acoustical woofers so they sound "good" not just rattle your truck apart.
