Sub not working. need help
Discussion in 'Audio & Video' started by donovan6241, Mar 13, 2012.
  1. Mar 13, 2012 at 10:37 PM
    donovan6241
    donovan6241 [OP] Well-Known Member
    Donovan
    San Diego
    2017 TRD Sport Double Cab Long Bed
    I have had my sub for more than a year now and its was working perfect until yesterday. Out of nowhere my sub went off. I dont think it popped because I don't have the bass up that much and it came back on for like 10 minutes and it sounded normal then it went off again and has not came back on sense. I checked all the wiring and I put my sub in my friends car and it did not work. I also put his sub in my car and it worked so i know its not the amp. Any ideas why the sub might be doing this? All of the wires and connections are 100% tight.
  2. Mar 13, 2012 at 11:19 PM
    livel0veryde
    livel0veryde Well-Known Member
    josh
    missouri
    04 tacoma double cab
    all of them
    this is happening with mine right now, and has been going on for like a week. one of my friends told me that it was the voice coil going out, i have no idea what that means.
  3. Mar 13, 2012 at 11:31 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Do you have a multi meter? If so put it on the amp and set it to ohms it should read 0 when you have it in whatever channels you normally have it in and do the same for the sub it should read whatever ohm's the sub is. Did you check your wiring inside the box? One of the wires may have been a little bit loose and come off. Turn your truck on and test the amp to make sure it's getting at least 12v and do a continuity test on the ground wire, set to ohm's and put it on the end of the wire that is in the sub and the other end on a piece of bare metal or the 12v input to the sub.
  4. Mar 14, 2012 at 6:57 AM
    iDrew
    iDrew I spend too much on vehicles...
    Andrew
    Edmond, OK
    '16 TRD Off-Road DCSB
    STOCK AF
    Sounds to me like the voice coil has been fried. Subwoofers aren't necessarily meant to last forever. My friend got 2 off brand subwoofers and 1 didn't work and the other had loose connections, internally that is. My point being, some things won't last forever. Pioneer makes some quality car audio, I've had my 10" for about 2 years; had it in 3 cars, and it still works as good as the day I got it. Take this as an opportunity to upgrade. Just my .02.
  5. Mar 14, 2012 at 7:09 AM
    Alanwn09
    Alanwn09 Well-Known Member
    Alan
    Martinsville, VA
    07 Tacoma 4X4 V6
    Pioneer Head Unit, 1 JL Audio 10'' Sub, Nerf Bars, Tinted Windows, Vent Shades, Bug Deflector, Flowmaster 40 Series, Cobra Cb w/ 4ft K40, 2 KC Hi Lites Behind Homertaco Satoshi Grille, Debadged and Deflapped, Low Profile Toolbox,16 inch M/T Classic II on 265/75/16 BFG All-Terrain TA KO, Scan Gauge II, Fog Lights SOLD AS OF 6-13-2014
    Yeah that sounds fried happened to mine a few months back...
  6. Mar 14, 2012 at 8:48 PM
    donovan6241
    Donovan
    San Diego
    Im gonna take the sub box apart to see if possibly something came lose inside. the only problem is the whole box is glued together and I might break it while im taking it apart. Whats the best way to open it without breaking or damaging it?
  7. Mar 14, 2012 at 11:57 PM
    Warhorseforever
    Will
    Sand Lapper
    Screw the sub out from the mounting hole, it shouldn't be glued in.
  8. Mar 15, 2012 at 12:33 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Yeah, no need to take apart the box. Just unscrew the sub from the box and pull it out and check the wiring.
  9. Mar 15, 2012 at 7:46 AM
    adammikolon
    adammikolon Well-Known Member
    Adam
    Doylestown, PA
    03 PreRunner 3.4L V6
    K&N Fuel Injection Performance Kit, JBA cat-back exhaust
    this is all the advice you need :D
