sub ohm question
Discussion in 'Audio & Video' started by 97T, Jun 12, 2011.
  1. Jun 12, 2011 at 12:20 AM
    97T
    97T [OP] Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    so my old setup was a solobaric l5 15" sub DUAL 2 OHM with a 600.1 jbl amp ... this was stolen and i think i had it wired series 4ohm cause i heard if you put a super low ohm load on a weaker amp than the speaker could take this wasnt good
    new setup is a 15" CVX DUAL 4 OHM with a 1200.1 toxik amp .... and i wired this one 2 ohm pararell ... and it sucks i got no low end bass response ...... and it doesnt hit for shit
    my plan is to wire it paralell, but this is suprising the hell out of me because i figured a lower ohm load would deliver better bass .. any input from you guys ... im very suprised since like i said the old sub my amp wasnt anywhere near the power it could handle and it hit hard
  2. Jun 12, 2011 at 5:49 AM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Two things.
    1. Power ratings are frequently inflated. You have to compare RMS watts at the same distortion rating with the same Ohm loading. It might well be the JBL amp produced more power.
    2. The amount of bass produced is a direct result of the amount of air moved. Assuming each sub is working at it's limit there are two factors at play: 1) the surface area of the cone, and 2) the distance the cone moves (typically reported as xmax). To find the value take the cone surface area and multiply by the distance moved
  3. Jun 12, 2011 at 7:01 AM
    dolbytone
    dolbytone Well-Known Member
    09 TRD Off Road
    I think you are hearing the difference between a JL amp and a Toxik amp.
  4. Jun 13, 2011 at 8:43 AM
    97T
    Melt
    Littleton, CO
    thanks for the insight guys ... im gonna try and rewire it and see if that helps ... but am very suprised the jbl was doing better than this amp is cause toxik amps are supposedly a rare breed and highly sought after
    I guess the solobaric l5 (square) also has slightly more surface area ... but am still suprised at the weak performance of the cvx so far seeing as they are supposed to be the round version of an l7
  5. Jun 13, 2011 at 5:30 PM
    97T
    Melt
    Littleton, CO
  6. Jun 14, 2011 at 8:24 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Always working on the stereo, painted the front skid plate black to match the truck, debadged , toy tech ultimate lift kit, light racing UCAs, ARB bumper Looking into a supercharger and new exhaust.
    Also, check to make sure the amp is wired correctly. Test and make sure that you have both (+)'s connected to the same lead and both (-) connected. It is rare, but I have seen incorrectly marked poles on a sub before. Just use a AA battery and to test how the cone moves when connected.
  7. Jun 14, 2011 at 10:10 PM
    97T
    Melt
    Littleton, CO
    theres another idea .... i rewired the sub again for a 2 ohm load, and think i almost have it right, also adjusted the xover for front / rear / sub on my deck and its decent now but still nowhere near as good as it was with the dvc 2ohm l5 i had before ... plan to live with it for now .... amps on craigs for a trade for an l5 then maybe i can get a better amp and decide what sub i want to keep ... the l5 fit in the back better the box for the cvx is huge
    side note: nice sig im horrible at math and i figured it out
  8. Jun 21, 2011 at 9:56 PM
    Durdum
    Durdum Member
    Travis
    Dfw
    09 double cab
    Audio!
    The box is the most important part of the system, idk if u still have that jbl amp but that is a good amp, vie never heard of that other brand. If you put that kicker in the right box it'll shake ur eyeballs!
