sub problem
Discussion in 'Audio & Video' started by pinktaco808, Dec 2, 2010.
  1. Dec 2, 2010 at 3:52 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
  2. Dec 2, 2010 at 3:56 PM
    Taco4Fish
    Taco4Fish Well-Known Member
    j
    cant hear the noise.
    If i had to guess i'd say your amp's tunning is to high. Lower the hz to what ever you boxed is tuned to. Your sub could just be playing high notes.
    Ask the guys on hawaii car audio, i seen you been posting stuff there
  3. Dec 2, 2010 at 4:47 PM
    happyb
    happyb Well-Known Member
    Brandon
    on a beach in hawaii
    to my taste
    making a list
    +1. very useful and informational site plus most of the guys are on oahu if you need help or wanna sample their systems.
  4. Dec 2, 2010 at 10:18 PM
    pinktaco808
    the hz is all the way to the lowest setting
  5. Dec 2, 2010 at 10:18 PM
    pinktaco808
    maybe the subs are underpowered???? i went with a diff amp which is lower power
  6. Dec 3, 2010 at 12:49 AM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    are you running your power to the amp next to the rca , near each other?
  7. Dec 3, 2010 at 6:20 AM
    pinktaco808
    hmmm my amp under the seat and sub are behind the seat the rca running in the middle not crossing or near anything????
  8. Dec 3, 2010 at 11:21 AM
    Anthony250
    Anthony
    San Gabriel Ca
    ok good, running your power cable to the amp, and running the rca near the power makes a noise as what you are describing, seems that maybe its something else.
  9. Dec 3, 2010 at 12:48 PM
    dolbytone
    dolbytone Well-Known Member
    09 TRD Off Road
    The only thing I noticed was that your sub sounds completely out of balance with the rest of your system. Maybe you're just going through that bass-crack-sub-honk phase. Tell us your procedure for setting levels.
  10. Dec 4, 2010 at 2:24 PM
    pinktaco808
    what????
    i guess im wrong with the subs, it coming from the front speakers???? it has a ringing noise from the tweeter and the mid, unwanted noise that not part of the song like in the video. they are connected directly to the deck no amp beside the crossover that came with the mb quartz.
  11. Dec 4, 2010 at 3:38 PM
    dolbytone
    09 TRD Off Road
    What's with all of the question marks? You don't know what you hear? The thread title is "sub problem" and you describe a ringing noise so people are listening to your video for a ringing noise in your sub.
    Now you post this and nobody knows what to think. If you want help, you need to accurately describe the problem you are having to begin with.
    That said, and I'm guessing here, what I think you are saying is that you have alternator whine. There are a BAZILLION alternator whine threads here and even more articles on it that you can find through Google. There are a lot of common causes and it would be easier if you did some legwork and confirmed that this is indeed your problem, and if so, rule some of these common things out as the cause.
  12. Dec 4, 2010 at 4:35 PM
    pinktaco808
    how can be when only the ringing noise comes out from the front speaker when the bass hits
  13. Dec 4, 2010 at 4:41 PM
    Sproulesxrunner
    Sproulesxrunner Well-Known Member
    Canada
    08 Xrunner
    Too much for TW to know
    Could be not a great ground connection on your sub's amp... Hook your sub up to one of your friends set up to see if it has that ring.
  14. Dec 4, 2010 at 5:22 PM
    dolbytone
    09 TRD Off Road
    Then something is rattling?
  15. Dec 5, 2010 at 7:49 PM
    pinktaco808
    nooo, so you saying it the tweeter>>>
  16. Dec 5, 2010 at 7:57 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
  17. Dec 5, 2010 at 8:33 PM
    dolbytone
    09 TRD Off Road
    MRP - I think that's an artifact of the camcorder framerate.
    I'm saying I don't know what you are hearing because you've made a concerted attempt to provide as little information as possible. Nothing abnormal can be heard in your video. See if you can isolate that noise and provide a more helpful explanation of what it sounds like and where it's coming from. If it only happens when the sub hits then it sounds like a vibration that you think is coming from the speakers in front, see if you can reproduce it with no sub.
    If you can, provide you high pass and low pass settings. You might be trying to reproduce frequencies too low for your components. Did you hook this up yourself?
  18. Dec 5, 2010 at 9:51 PM
    pinktaco808
    soo i think maybe i can turn on the hpf or will that make it worse????Also there so many setting i get lost with it. there like 3 setting like F 40 Q F 1k Q F 8k Q i dont know what that
    the hpf is off
    setting is sub for rear.
    ill try post the vid tom of my setup
  19. Dec 5, 2010 at 9:53 PM
    xSpyderguyx
    xSpyderguyx Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    If you are grounded to your seat, change it!
    Get a good metal ground and/or ground directly to your frame
  20. Dec 5, 2010 at 9:54 PM
    pinktaco808
    i did i found a bolt and cleaned it with a wire brush. it showing bare metal
