sub turns off randomly
Discussion in 'Audio & Video' started by JoshLV, Feb 14, 2011.
  1. Feb 14, 2011 at 7:00 PM
    JoshLV
    JoshLV [OP] Well-Known Member
    Josh
    Hanford, CA
    2007 Tacoma SR5
    800 rms pioneer champion pro 10" sub, and an 800 rms kenwood amp. Had all this installed about a week and all of a sudden my sub starts turning off randomly. This happens with all genres of music. Ideas??
  2. Feb 14, 2011 at 7:02 PM
    MHS2846bg8
    MHS2846bg8 Experienced Noob
    Nate
    South Coast of Oregon
    21 Tacoma TRD Off-Road Dbl Cab 4x4
    4WP Factory Front Bumper w/Warn VR EVO 10-S Winch, AuxBeam 8-Switch Controller, Redarc Trailer Brake Controller, ARE CX-Evolve Cap, Bedrug Liner, Ditch Pod Lights, Aftermarket LED (OEM) Bed Lights, Console Vault
    The only time when my sub turns off is when I crank it too high and it trips the amp's breaker...you might want to see if your amp or any of the wires are getting grounded out somewhere.
  3. Feb 14, 2011 at 7:22 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Does it happen after an extended playing time when the amp has had time to get hot or does this happen all the time?
  4. Feb 15, 2011 at 4:49 PM
    JDattilio
    JDattilio Well-Known Member
    Jayson
    SR5
    does it happen at louder volumes? You may be clipping your amp, which means that your sub is asking the amp to produce more power then it can actually produce
  5. Feb 16, 2011 at 7:48 AM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Here's my amp
    http://www.sonicelectronix.com/item_11795_Kenwood-KAC-9104D.html
    My sub is a 10" pioneer champion pro. Both the amp and sub are 800rms. I don't know how that amp could be not supplying enough power. Could it potentially be my battery?
    I checked the ground and other wiring, with the exception of remote wire for now due to lighting, and it was all good.
    Was listening to it last night and as I turned my truck on it was hitting, but a few minutes later into a sound that hit hard I turned the volume up and it crapped out. After turning the volume back down low it would hit once or twice then go off and hit again randomly.
  6. Feb 16, 2011 at 6:18 PM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Just noticed that one of the 2 lights on the amp goes out when the subs not hitting. Also I don't think my subs wired like that, I'm using both left terminals if I remember correctly. Thoughts?
  7. Feb 16, 2011 at 6:29 PM
    Daudio
    Daudio Well-Known Member
    North Jersey
    '02 SR5
    avic-d1 sirius tuner Ipod adapter
    Sounds like the amp is going into protection, I would bet you have a voice coil on its way out...Is the amp gain turned all the way up?
  8. Feb 16, 2011 at 6:50 PM
    JDattilio
    Jayson
    SR5
    you are using the two speaker output connections on the left? That means you have both postive connections hooked up to your amp double check that make sure that is not the case, that alone can mess up your amp
  9. Feb 16, 2011 at 6:56 PM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Dno what that means lol. But my settings on my amp aren't even half way.
  10. Feb 16, 2011 at 7:02 PM
    ItalynStylion
    Steven
    DFW, Tx.
    My guess is your sub isn't wired like this....it should be. Make it so and then report back.
  11. Feb 16, 2011 at 7:24 PM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Stupid question- I'm guessing the wire in the middle is a bridge. Since its going from pos to neg, what kind of wire do I use lol? Just a piece of one of the joined pos/neg wire roll? Lol idiotic question.
  12. Feb 16, 2011 at 7:27 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Wire has no actual charge denoted by it's design. The color is just the insulation and is meant as an identifier only so you don't get the wires all mixed up.
    Short form, use any piece of wire you want as long as it's something like 16gauge or thicker.
  13. Feb 16, 2011 at 7:47 PM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Wires all set up correctly now. It will hit for about 15 seconds into the song, then the lights on the amp start to dim and flicker then go out, ending the show.
  14. Feb 16, 2011 at 8:09 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    is the amp overheating?
  15. Feb 16, 2011 at 8:10 PM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Well even when it was doing fine the headlights would dim when it hit. So you think its the alternator? What about the battery?
  16. Feb 16, 2011 at 8:11 PM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    It can't be overheating because when I got it it would be fine playing for over an hour. Now I can turn it on after the whole night and as soon as I up the volume it craps out.
  17. Feb 16, 2011 at 8:13 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    x2. kinda sounds like your amp is overheating
  18. Feb 16, 2011 at 8:13 PM
    JDattilio
    Jayson
    SR5
    could be a voltage issue, if you have a multimeter, when the amp is actually powered up stick your leads on the ground and battery connections see what it reads when the amp kicks off.... if it reads little to no voltage you may need a new fuse on your power wire, have seen that before or it could be a weak ground. Or it could possible be that your amp has an issue inside of it
  19. Feb 16, 2011 at 8:18 PM
    JDattilio
    Jayson
    SR5
    if you still have good voltage (12-14) volts on the input of the amp when it kicks out, unplug the rca and speaker connections and turn it back on and see if it shuts off on you if it does then there is a short inside the amp itself
  20. Feb 16, 2011 at 8:26 PM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Not sure on the alternator considering I got the truck a month ago. I don't have any of those tools either. Would a new alternator be a good idea? Ill prob get a cap too but id rather solve this in the least expensive way possible lol.
