Sub-Zero Equal Length Y pipe.
Discussion in 'Performance and Tuning' started by 906taco, Jul 6, 2024.
  1. Jul 26, 2024 at 10:13 AM
    #181
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    The important difference are the cat-less headers. He doesn’t have any cats or resonators in the exhaust whereas you said your truck has the stock exhaust manifolds with primary cats
    stickyTaco likes this.
  2. Jul 26, 2024 at 11:51 AM
    #182
    906taco
    906taco [OP] Well-Known Member
    Cory
    08 Taco
    Just want to keep everyone in the loop with what is going on.
    Currently in the process of getting everything kosher on the tax/IRS side of things. Things get a bit different with online sales etc.
    Also setting up an online quickbooks for ease of invoicing/paying.
    Bear with me please! This is still happening!
    A massive order of stainless is also being placed shortly. The goal is getting things to the point where I always have material on hand to build a couple, or even having a couple pre built and ready to ship!
    This whole thing happened way quicker than I assumed.
    I will take zero money until it’s actual game time!
  3. Jul 26, 2024 at 11:55 AM
    #183
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Deleting the secondarys really unleashes the v6 fury. :transformer:
    TWTaco and jamesepoop like this.
  4. Jul 26, 2024 at 12:06 PM
    #184
    906taco
    Cory
    08 Taco
    If I stick with the 1GR, headers will be a next up deal. But in my stupid little world, I have this “idea” of a big turbo 2j being pretty dang cool.
  5. Jul 26, 2024 at 3:39 PM
    #185
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    2j go stustustustu...
  6. Aug 7, 2024 at 6:55 PM
    #186
    gil_S
    gil_S Well-Known Member
    Seattle, WA
    What exhaust would you recommend pairing with this? I had a reroute done around my transfer case and don't think my OEM one bolts in in the right place anymore.
  7. Aug 8, 2024 at 1:22 PM
    #187
    906taco
    Cory
    08 Taco
    The oem was cut I assume? The quietest option is hands down going to be a factory TRD exhaust. If you went with this Y I could make you a custom length mid pipe to adapt to your factory exhaust.
  8. Aug 8, 2024 at 1:30 PM
    #188
    906taco
    Cory
    08 Taco
    Also update. It’s been a minute and I apologize for this.
    Things are dragging longer than I had hoped to get things rolling. Seemingly the way things always go.
    Either way. We’re very close now. All billing will be done via quickbooks. All major cards accepted, Venmo, PayPal, Apple Pay, wire transfers.
    I apologize for this delay and can’t wait to start burning stainless again instead of sitting behind this dang computer.
  9. Aug 8, 2024 at 2:06 PM
    #189
    gil_S
    Seattle, WA
    Yeah, it was cut. Thinking about factory TRD or Magnaflow Overland. High clearance rear and don't want to lose any clearance. I think both are 2.5. Would I lose some benefit using a 2.5 vs 3.0? Then not sure if it was mentioned, but do I need to worry about CEL codes or anything like that triggering with this Y-pipe?
  10. Aug 8, 2024 at 2:09 PM
    #190
    906taco
    Cory
    08 Taco
    I think either exhaust is a solid choice. Then paired with the Y pipe to 2.5” mid pipe. No worry at all of CEL. The one hiccup that did occur was a gasket issue that has been rectified
    TWTaco, gil_S[QUOTED] and nudavinci64 like this.
  11. Aug 8, 2024 at 2:14 PM
    #191
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    yah as long as you still have the sensors in their you are good to go. This would be perfect timing too as my bi annual smog is coming up. Fresh 2 years to play
    jamesepoop, 1slow4.0, TWTaco and 3 others like this.
  12. Aug 9, 2024 at 8:28 AM
    #192
    Rsatch
    Rsatch Well-Known Member
    21 Army Green TRD OR 6MT
    I’d definitely be interested in a 3rd gen if you decide to do them and it would fit a MT truck.
    TWTaco likes this.
  13. Aug 9, 2024 at 10:00 AM
    #193
    906taco
    Cory
    08 Taco
    3rd is still happening. Everything is being built around auto 4x4’s so will work with 2wd, auto and manual.
  14. Aug 9, 2024 at 10:07 AM
    #194
    TWTaco
    TWTaco Well-Known Member
    Dave
    :cheers:
  15. Aug 12, 2024 at 9:42 PM
    #195
    eljedi68
    eljedi68 Well-Known Member
    David
    Kalaheo, HI
    2010 Tacoma Ext Cab 4x4
    complete Long Travel Suspension built by DMZ: 3+ Control Arms by TC, Bed Cage, Denver Under Springs, Fox all around (Coilover & Bypass up Frt, 3.0 Bypass Rr). Full Glass front fenders and bedsides. Engine so far: TRD CAI, DT Headers, URD Y Pipe, Gibson Muffler. And a Sprint Booster. Sits on Toyo OC 35x12.5 on 17’s. Nitro Rear end and re-geared for 35’s (4.56). Goals: Flowed Heads, Cams, and Boost (SC) ! So far, so good
    Oh man, just when I thought I was free of the Taco build rabbit hole … you came BACK !!!
    and dang, yes for sure I’m gonna want
    (My buddy and partner in crime has one of your original’s and I’ve been trying for years to make him part ways with it). With no luck of course
    my quick Q’s to you… I’m staying NA , and I’ve got as many mods as one can on that simple NA and she go… my “Q?” would be to stay true to my 2.5 Gibson exhaust or re invent the wheel? I’m running Equal Length Headers, Cat-less URD Y pipe and into a Cat-back GIBSON 2.5 super Flow system
    Performance wise, for me, the most important bolt on would not make me loose bottom end grunt (dirt beast) …
    So, do I stay 2.5 and have some built in back pressure or go big, and build 3.0 exhaust ???
    *Note: besides CAI, Light Pulleys and Tune… I have that “1 inch” Intake manifold Spacer (great Torque mod btw)
    hit me back and lmk your thoughts
    Mahalos ahead of time and sending ah ton of Aloha
    906taco[OP] likes this.
  16. Aug 12, 2024 at 10:09 PM
    #196
    nudavinci64
    Robert
    I would stick with 2.5. In the Boosted threads, the common feedback was 2.5 N/A or 3 if S/C, or if you do a dual setup with X pipes, etc, some guys have done 2.5".
    eljedi68[QUOTED] likes this.
  17. Aug 13, 2024 at 5:18 AM
    #197
    906taco
    Cory
    08 Taco
    NA is going to do better with 2.5 for the Y back!
  18. Aug 13, 2024 at 5:31 AM
    #198
    Rsatch
    I was wondering myself if after the Y stepping up to 3” for the rest of the exhaust and muffler would make it smoother sounding. My thought was 3” would slow the velocity of the moving air and make it deeper sounding. I’ve never built an exhaust for a V6 so not really sure how 3” vs 2.5” effects overall volume.
  19. Aug 13, 2024 at 5:42 AM
    #199
    906taco
    Cory
    08 Taco
    Slowing velocity is going to hurt performance. Yes it will be a deeper tone.
    The reality is, 2.5” will support upwards of 500hp. Though after the 400 or so range with forced induction 3” should be a consideration. These figures are based on power at the crank. Not wheels.
    Revelations likes this.
  20. Aug 13, 2024 at 8:50 PM
    #200
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    906…. Are you in the UP?
