Subaru "rumble" for our truck?
Discussion in '4 Cylinder' started by MrRegularCab, Feb 15, 2021.
  1. Feb 15, 2021 at 8:50 PM
    MrRegularCab
    MrRegularCab [OP] Member
    2009 Regular Cab, 2.7, 5 speed, 4x4
    I came across this video of a Civic that had an Unequal Length (UEL) header installed on a regular 4cyl, and BOOM, subaru "rumble" exhaust note!
    I'm well aware that the UEL header design is NOT as efficient as an equal length header.
    THE MAIN REASON FOR THIS POST: Has any manufacturer made an UEL header for our Tacomas equipped with a 4cyl? They sound so good!
    https://www.youtube.com/watch?v=Cgz3cnB8vv4&feature=emb_title
  2. Feb 16, 2021 at 12:42 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Not that I'm aware of. But I will say the exhaust note of my 2tr on decel with whatever the P/O put on here... it's got the rumble. Made me cock my head first time it did it for sure. It's the factory header, but I'll have to try and get under the truck sometime to figure out what's actually under it for exhaust. So it is possible to be sure.
  3. Feb 16, 2021 at 2:03 AM
    AssQuake
    AssQuake Unknown Member
    A.J.
    Washington
    4runner
    Made in Japan
    Y tho? Sounds like Chewbacca
    ExplorHer, DGXR and stevesnj like this.
  4. Feb 16, 2021 at 2:05 AM
    BananaMan
    Because he likes the sound and wants to know if it's possible? Good enough reason in my book
  5. Feb 16, 2021 at 2:56 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I mean you could make one just for the unique noise but also realize that it hurts performance and economy some by reducing scavenging and would be a total crap shoot trying to get the lengthens unequal enough. Also you may have to do alternating cycls depending on the 2TR vs the subie boxer firing order.
    Lastly a I4 obviously just isn't the same as an H4 so you would probably have a hard time replicating the iconic sound.
    For what it's worth newer subies and those whom upgrade to high performance and turbos go to equal lengthens to improve overall performance and turbo response.
    Your cats and cat back, primarily your muffler, and you tune will have the biggest impact on engine note.
  6. Feb 16, 2021 at 3:38 PM
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Before I went turbo, I had the stock header and a Magnaflow 2.5" to 3" exhaust, and on decel and idle it had the WRX rumble to it. I had gotten plenty of comments from my friends with Subarus that it sounded oddly like one.
    Then I went turbo and that was out the window :burnrubber:
  7. Feb 16, 2021 at 3:40 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Get a custom exhaust shop to make one for you.
  8. Feb 16, 2021 at 3:48 PM
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
  9. Feb 18, 2021 at 7:52 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Sure it's possible. With enough time and resources, you can make your truck sound like anything you like.
    Everybody wants to mess with their trucks and then gets upset when things don't work out. Fix it after it breaks, not before :D
  10. Feb 19, 2021 at 10:03 PM
    DaveB.inVa
    DaveB.inVa Well-Known Member
    SWVa
    2015 AC SR5 4x4 V6 AT MGM
    Oil Catch Can, OIl Pressure and Temp Gauges, Falken Wildpeak A/T3W 265/70R16
    My brother has an 01 Civic hatch he swapped one of the JDM B18C engines into. He found one of the UEL's on ebay for under $200 and bought it. It was cute for a few days but he went back to his 4-2-1 header. That little car is a lot of fun though, he just uses it for autocross though. It's started as an HX and had no AC, PS, came without a radio and had a gutless engine but got 44mpg.
    Anyway, the header isn't anything special, cylinders 1 and 2 are wyed together right off the head then run through a big circular loop that joins into cylinders 3 and 4 right after they're wyed together. With the firing order it ends up being just like the UEL from a Subaru. You could get a cheap used header on ebay and loop 1 and 2 around the same way since I'm pretty sure both have the same firing order.
  11. Feb 27, 2021 at 4:14 AM
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    i have the 19275 magnaflow catback 3" back system on my truck, paired with a K&N CAI. I think it has the subaru braap to it, which is what i was after. It sounds best when you are into the throttle in the snow
    TacoYoter27 likes this.
