Subaru Tweeter Replacement for JBL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Matt444444, May 3, 2022.
  1. May 3, 2022 at 8:30 PM
    Matt444444
    Matt444444 [OP] Member
    I cant find any threads that show how to do this. I want to replace the JBL tweeters to something that might sound better, plug and play. Has anyone figured out a way to plug the Subaru tweeters into the JBL harness?
  2. May 3, 2022 at 8:36 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    GOOGLE this... subaru tweeter tacoma tacomaworld.com
    Removed comment... Didn't notice OP needed for JBL.
    t2c likes this.
  3. May 3, 2022 at 8:49 PM
    Matt444444
    I need it for a JBL stereo. The threads that show it only work for non JBL.
  4. May 3, 2022 at 9:25 PM
    NomadicCypress
    NomadicCypress Well-Known Member
    2023 Solar Octane TRD Pro M/T
    Because it does not work with the JBL
    t2c, drizzoh, eurowner and 2 others like this.
  5. May 4, 2022 at 5:49 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Unfortunately the only option for JBL is complete replacement including added amp and new sub. A lot of people recommend a brand called oem audio plus to retain the stock headunit, but it’s over $3k
  6. May 4, 2022 at 9:17 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    You dont need to replace everything for a JBL system.
    Buy a set of JBL club 322f speakers, Several people with JBL systems have swapped out the stock for these. You will need to trim a little bit, but they fit. Then just adapt the wire harness to the new speakers (easy to do) and your all done.
    https://www.tacomaworld.com/threads...ers-and-subwoofer.716167/page-6#post-27072001
  7. May 4, 2022 at 9:19 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I found the Subaru tweeters to be both lower in construction quality and provided negligible sound improvement. Non-JBL system.
    LilTexan22 likes this.
  8. May 4, 2022 at 9:49 AM
    musicisevil
    Alaska
    2019 TRD Sport
    My bad, must have missed those posts
    5nahalf[QUOTED] likes this.
  9. May 4, 2022 at 9:53 AM
    5nahalf
    Erik
    Minnesota
    They are few and far between, but its also a fairly recent thing that people are just swapping out the speakers and leaving everything else. Awhile ago there was no real option, but I started pointing out to people that JBL and Infinity offer 3 ohm speakers that will swap right into the JBL trucks.
    musicisevil[QUOTED] likes this.
  10. May 4, 2022 at 9:57 AM
    musicisevil
    Alaska
    2019 TRD Sport
    Appreciate the info! I’ll find some threads. Do you have personal experience with the replacements by chance?
  11. May 4, 2022 at 10:03 AM
    5nahalf
    Erik
    Minnesota
    Not on a tacoma, but a rav4 with JBL. But I have advised on several JBL builds and the people have been very happy with the results.
    But the JBL system uses 2 ohm speakers, most car speakers are 4 ohms. Putting a 4 ohm speaker into a system designed for 2 ohms gives less than good results. 3 ohms is good enough.
    Then the way JBL did the system in these trucks, you have a 8 channel amp in the back, it sends sound to each individual speaker (4 front, 2 rear, dual voice coil for sub) The amp has built in crossovers to supply the correct range to the factory speakers, the stock dash speakers being a 2 inch can handle mid-high range frequencies, so a 3.5 inch coaxial speaker is the perfect replacement. It can handle the lower freq and has its own crossover to send the high to the built in tweeter.
    Potamus and musicisevil[QUOTED] like this.
  12. May 4, 2022 at 10:17 AM
    musicisevil
    Alaska
    2019 TRD Sport
    Interesting... Definitely excited at the prospect of not having to rip apart the whole truck for the oem+! I have some reading to do. Thanks again!
  13. Jan 20, 2023 at 2:38 PM
    chiefjohn54
    chiefjohn54 Member
    Taco 2023
    Replacing JBL Tweeter/Mid in 3rd gen TACO with JBL system
    Hi all: This is my first serious post. There are many related threads regarding this topic.
    I got my new TACO in November ..love the truck but the so called premium audio system (aka JBL) is worse than terrible. After reading just about every thread, and other sites, this is my story.
    I was not happy with the screeching effect of the tweeters—seemed too loud and I could not control them enuf with the factory mid and tweeter controls in the head unit. I removed the OEM speakers and observed that there was NO Cross-over Capacitor. ( I read somewhere that the capacitor was an integral part of the speaker…seems a bit unorthodox.) This may be the root of the issue, but with this crazy JBL set up who knows.
    I replaced the OEM tweeters with the Kicker tweeters 47KSC2704. They are a 4 ohm speaker and the folks at Crutchfield said that I’d hear a reduction in amplitude using these. This was what I wanted, so good! I installed the speakers using a harness I found at Harness House part number 4499, using the Tacoma end of the harness (connector was grey), making a pigtail. They are about 10 inches long they mated perfectly with the TACO 3rd gen factory JBL harness---obvious benefits. The factory harness is VERY short and trying to splice into it will be a challenge.
    I used the Kicker provided capacitor 150 micro-farads connected to the positive side of the speaker and ensuring that I was connecting to the positive feed from the OEM harness. (I deduced that the positive side of the OEM speaker was on the right) They were an improvement but still too bright for my taste. Interestingly I noticed an improvement in bass response…..hmmm.
    Second try. Even though there was some improvement, I still needed to reduce the tweeter’s amplitude. I added a 2 ohm (non-inductive) resistor in-series with the speaker. In effect making it a 6 ohm device. Since the impedance (resistance) increased; I had to adjusted the crossover capacitor to 80 micro-farads. (ref: https://soundcertified.com/speaker-crossover-calculator ). This is the diagram of the hook up:[​IMG]
    SUCCESS: Much better overall performance--- Tweeter/Mids much better behaved and the Bass is much better. PLUS the rear speakers are now louder … There must be something funky as to how the JBL unit processes the audio signal since the bass is better… an unexpected and welcomed results. This mod may not work for everyone…and will not make your truck should like your home system…but it’s now much improved in my view. Good luck.
  14. Jan 20, 2023 at 2:45 PM
    chiefjohn54
    chiefjohn54 Member
    Taco 2023
    looks
  15. Jan 24, 2023 at 3:48 PM
    chiefjohn54
    chiefjohn54 Member
    Taco 2023
  16. Jan 24, 2023 at 3:50 PM
    chiefjohn54
    chiefjohn54 Member
    Taco 2023
    Check out Harness House part # 4499. Also search "4499" you'll find my post on replacing JBL tweeters
  17. Jun 24, 2023 at 7:28 PM
    ApolloR
    ApolloR Member
    2022 TRD Off-Road Tacoma
    Here’s what I’m planning to get for my jbl Tacoma. Is there anything I should get instead ? I’m just looking to get more overall volume and bass
    jbl gx 302
    Jbl stadium gto620 with baffle kit
    Jbl stadium gto960c with baffle kit
    Rockford P3SD2-8in
  18. Jun 24, 2023 at 8:35 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Looks good to me, let us know how the 620 sounds. Please respond in the thread linked above :thumbsup:
    musicisevil likes this.
