Subfloor Questions
Discussion in 'Garage / Workshop' started by nomad_archer, Jan 16, 2012.
  1. Jan 16, 2012 at 9:01 AM
    nomad_archer
    nomad_archer [OP] Well-Known Member
    Trevor
    Brickerville (Lititz), PA
    08 DC Tacoma V6 SR5
    So I am starting to remove the old floor in my kitchen and after some work I finally got down to the subfloor. It turns out that the subfloor I have is 19/32 plywood which im not sure is enough to lay tile on. So what are my options. I want to have at least 3/4" subfloor for this project and with the space avaliable that would be ideal.
    So what are my options? Can I lay 1/4" ply on top of the existing subfloor and then the 1/4" hardiboard then the 13x13 tiles?
    Or should I remove the subfloor and start over? Im not sure what I should do so any help would be appreciated.
  2. Jan 16, 2012 at 9:07 AM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Does your floor creek or bounce? If not, save your money and put the tile on the 1/2" ply.
  3. Jan 16, 2012 at 9:09 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2014 TRD Off-Road
    TacoAlaMode Custom grill, SCS Gunmetal F5's, Treadwright guard dogs, King extended travel coilovers w/800# springs, OME Dakars. LRUCA's. Allpro off-road plate rear bumper with high clearance hitch, steel breaded extended brake lines front and rear, SOS concepts bolt on rock sliders with top plate, Pelfreybuilt front plate bumper, rci skid plates, Airflow Snorkel, Tom Woods custom one piece drivesahft, Weathertech in channel rain guards, Bushwacker fender flares, custom cab height bedrack, 60" Hi-Lift jack w/Mount, Recon 10,500lb waterproof winch with synthetic line, rear bumper light pods, front bumper light pods and light bar.
    I've been putting in floors for 15 years. If you're current floor is flat, then there is nothing wrong with going over it with another layer of wood, then your backer board, then tile.
    Just remember, that is a good bit of height and the floors that it connects to will likely be lower. You'll have to have to install a transition threshold in the doorways.
    If you have a nice budget to do it, then yank that old stuff up and redo it all. It would look better in the end.
  4. Jan 16, 2012 at 9:09 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    what are your floor joists spaced at? What size are the joists?
  5. Jan 16, 2012 at 9:11 AM
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    Do it right the first time. Put down cement backer board otherwise you risk cracking tiles over time. If you crack one tile its almost easier to replace the entire floor than to get that one up.
  6. Jan 16, 2012 at 9:11 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Lay another layer of 1/2" ply at 90* to the original layer , glued and screwed into the joists .
    If this is not an option due to height restrictions look into Schluter Ditra
    http://www.schluter.com/6_1_ditra.aspx
  7. Jan 16, 2012 at 9:23 AM
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    Hold on I had a tape measure malfunction or operator error. I have 19/32" subfloors
    The joists are about 7 1/8 x 1 1/2" and 16" on center
    The house is about 30 years old.
  8. Jan 16, 2012 at 10:10 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Make sure the existing subfloor material is still sound. (no water damage or soft spots, etc.) You can cut those out and replace if just a small area.
    Locate any squeaks in the existing subfloor and add deck screws to eliminate.
    If subfloor plywood is butted (square edged) then all edges should be supported.
    This means blocking between the joists if your existing subfloor (8' side) is not tongue and groove. We usually apply flat 2x4 blocking between the joists to stiffen and unify the butt joints
    Use construction adhesive with any added blocking. A partner above with a screw gun is helpful when adding this type of blocking.
    Be sure to apply your cement board according to mfr's instructions.
    I like Durock's requirement of using adhesive between the cement board and the wood subfloor. This will not only adhere but will bridge any gaps as well.
    Good luck.
  9. Jan 16, 2012 at 10:21 AM
    OZ-T
    Peter North
    British Columbia
    Schluter Ditra
  10. Jan 16, 2012 at 10:29 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Good info, I've got a tile job coming up and I think this stuff is perfect!
  11. Jan 16, 2012 at 11:03 AM
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    Ok so I did a little more measuring and I could add an additional 3/8" plywood to bring the 19/32" subfloor up to 1" which seams like the ideal number. Thoughts comments? Best way to attach if this is a satisfactory approach. The existing subfloor has butted joints.
    If I went this route then I would thinset and 1/4 hardiboards as reccommended.
  12. Jan 16, 2012 at 11:10 AM
    OZ-T
    Peter North
    British Columbia
    Butted on the long axis ? You sure it's not t+g ? If not block as per jflan's post above .
    I already posted how to laminate another layer of plywood .
    Or Schluter Ditra , seriously .
  13. Jan 16, 2012 at 11:14 AM
    jrdbrn
    jrdbrn Borne Fishing
    Jared
    Louisiana
    '16 Inferno Tacoma TSS
    I have 3/4" plywood and then 1/2" hardyboard then tile.
  14. Jan 16, 2012 at 11:16 AM
    OZ-T
    Peter North
    British Columbia
    I have 3/4" ply , 1 1/2" of concrete , 1/4" Schluter Ditra then tile .
    Do I win ?
  15. Jan 16, 2012 at 11:18 AM
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    the ditra looks like some pretty cool stuff.
    I will get back to you about the t&g after it has been completely removed I have just ripped up a few smaller sections. Do you think adding 3/8" glued and screwed would be sufficient? Also How far apart would you place the screws and what type of screws do you reccomend?
  16. Jan 16, 2012 at 11:20 AM
    dexterdog
    Oly WA
    2012 F150
    I used the Schluter Ditra mat in my Kitchen. Due to height issues I couldn't use the hardi board plus it's a waterproof seal. It's not cheap but effective.
  17. Jan 16, 2012 at 11:26 AM
    OZ-T
    Peter North
    British Columbia
    The main thing is to get screws through both layers and into the joists , this will stiffen up the whole assembly , so in that case 2 1/2" screws are long enough , in between the joists , I would go with shorter screws because you would just be laminating the two sheets together , 1 1/4 - 1 1/2" would work .
    Is the underside of the floor system accessible ?
  18. Jan 16, 2012 at 11:30 AM
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    Yes the underfloor is accessible.
    A side question have you used the schluter ditra over 5/8" plywood. How did it hold up. The ditra looks like it would be pretty easy to install with minimal extra effort.
  19. Jan 16, 2012 at 11:33 AM
    OZ-T
    Peter North
    British Columbia
    I always frame floors with 3/4" ply , but the Ditra is designed for 5/8" ply and up .
    If the underside of the floor is accessible and not receiving a finish ( drywall ) a simple " T " brace or even a 2x4 strap on the flat will stiffen the floor and reduce independent joist movement .
    If the underside of the floor is to be finished a series of blocking is pretty effective too .
  20. Jan 16, 2012 at 11:39 AM
    jflan
    Vancouver, WA
    OP, how large is this area that you want to tile ?
