submerged differential
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doctor brevic, May 20, 2012.
  1. May 20, 2012 at 1:01 PM
    doctor brevic
    doctor brevic [OP] Active Member
    Adolf
    blue mountains
    2.7 4x4 tacoma
    Nothing but a K&N filter
    So if I submerge my differentials in water on a 2011 tacoma(stock) need I change my diff oil? Has it got a vent? Any way to avoid this unfortunate shortcoming?
  2. May 20, 2012 at 1:08 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It has a vent. The vent is near the top of the housing.
    You can relocate the vent to the fuel door area.
    There's a "cheap/free mods" sticky that outlines how to do it.
  3. May 20, 2012 at 1:09 PM
    Blackcat10
    Blackcat10 Well-Known Member
    I would change it just to be safe. There is a vent on the differential housing. If you are interested there is a post under the Mod section on how to install remote vent with a hose and a couple of fittings inside the fuel door.
    Gear oil is cheaper than a differential! Go with Synthetic Oil.
  4. May 20, 2012 at 1:09 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    OP , search diff breather relocate or diff breather mod
  5. May 20, 2012 at 1:16 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    May be easier to install one of these, no hoses to route.
  6. May 20, 2012 at 1:20 PM
    OZ-T
    Peter North
    British Columbia
    Is that like a floatswitch for the breather ?
  7. May 20, 2012 at 1:43 PM
    KenLyns
    Belly of the Beast
    No. It's just a bellows that expands and contracts to accommodate air displaced from the diff. Remember the diff doesn't need to "breathe" per se. The air inside the diff simply needs a place to go when the diff fluid expands/contracts with temperature. Click on the picture for more info.
  8. May 20, 2012 at 1:44 PM
    OZ-T
    Peter North
    British Columbia
    That's cool , kinda like an expansion tank concept . So essentially that makes it a closed system ?
  9. May 20, 2012 at 2:01 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Wow, I'm gonna have to make that mod quick. Is this a Gen2 thing? I've had my Gen1 diff submerged many times.
  10. May 20, 2012 at 3:02 PM
    KenLyns
    Belly of the Beast
  11. May 20, 2012 at 3:04 PM
    OZ-T
    Peter North
    British Columbia
  12. May 20, 2012 at 3:05 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I've read bad things about those. I'd stick to re-routing the breather higher up.
  13. May 20, 2012 at 3:05 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I have those on the MonkeyCrawler..you can get em at trail-gear.com
  14. May 20, 2012 at 3:05 PM
    OZ-T
    Peter North
    British Columbia
    Such as ?
  15. May 20, 2012 at 3:06 PM
    MonkeyProof
    SoCal- SGV
    Really!?
  16. May 20, 2012 at 3:06 PM
    doctor brevic
    Adolf
    blue mountains
    2.7 4x4 tacoma
    HA! thats a great thing there, that bellows deal. Thanks for the info I appreciate it alot! I think I'll have to get ahold of one of those
  17. May 20, 2012 at 3:08 PM
    MonkeyProof
    SoCal- SGV
    You can at least take of the fill plug using a 24mm socket and stick your pinky finger inside to check for water intrusion..
  18. May 20, 2012 at 3:14 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The water will drop to the bottom.
    Would need to check immediately after a moderate drive to check for the milky appearance.
    But really... mod the breather and change the juice. $60 for the breather mod and new oil is cheaper than a new rear end.
  19. May 20, 2012 at 3:15 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  20. May 20, 2012 at 3:18 PM
    MonkeyProof
    SoCal- SGV
    Maybe that why I have leaks from the pinion seals
