Subs for 3rd gen tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoluvr7, Mar 10, 2023.
  1. Mar 12, 2023 at 1:38 AM
    Ballz
    Ballz Well-Known Member
    Bfe SF Bay
    2023 Ice Cap Taco TRD Pro
    Check out Taco Tunes or James Randy Taylor of www.tech12volts.com
    James is the god of systems for Yota trucks!
    James has set me up on my last Taco and 2 of my previous Tundras.
  2. Mar 12, 2023 at 3:02 AM
    ironhead181
    ironhead181 Well-Known Member
    2021 Tacoma DBL Cab
    none
    If you don’t mind will you update us on the Sony unit and how hard the installation is? I’ve been thinking about upgrading to this unit with just new speakers all around. I can always add a sub in later if I want to.
  3. Mar 12, 2023 at 3:09 AM
    Ballz
    Bfe SF Bay
    Hope you also bought the adapter pigtail to match up to your Toyota factory wiring harness behind your oe head unit. This will save you a lot of headache in the future in case you ever an electrical issue under the dash of your truck. If you chop the stock harness, they will always blame it on that.
  4. Mar 12, 2023 at 7:27 PM
    MrTreehorn
    MrTreehorn 2016 TRD BUILD IN PROGRESS
    Dan
    SF East Bay
    2016 TRD OR 4x4 MGM
    King 2.5s F/R, Icon RXT Leafs, Camburg UCAs, Wheeler's Offroad Superbumps, AllPro Spindle Gussets, JDFab Double Sheer Steering, RCI Skids, Bay Area Metal Fab Shackles and Hangers, Bay Area Metal Fab Gas Tank skid, RRW RR7H Flow Formed, 34" Mickey Thompson Baja Boss A/Ts , AllPro Sliders, Snug top Camper shell, MESO Customs bits n bobs, Powerbrake BBK, SSO Hybrid Front Bumper, Baja Designs 20" Amber LB, Warn Evo 10s
    So I build gaming PC's so how hard could it be right? Well it was a bit more involved then I anticipated but really you just have to follow the instructions. it is a MUST to get the recommended Maestro adapter and harness kit for your stock equipment and headunit. The Sony AX6000 for me was the easier part, you flash the maestro on the PC with the software then just plug everything in (there are ALOT of connections to make) but it all turned on and worked! The only issue so far is my anytime front/rear camera kit I installed, the switch isn't working but the reverse camera works flawlessly whether activated via the Sony or by going in reverse.
    In hindsight I should've actually called Crutchfield for more one on one support. Over 3 days I was able to successfully install my headunit and the maestro. I've decided to throw in the towel and use a Stereo shop to install my Kicker speakers. Splicing and adding the adapters to use existing stock speaker wiring was a breeze and I'm comfortable running the amp power from the battery but man having to splice the factory wiring from the harness out of the old JBL amp in the rear is a HUGE undertaking I'm not ready for even with a diagram. I also have a 10" kicker hideaway I need to install. Initially my plan was to simply install the amp and sub in the old JBL spot behind the rear seats and put them on a piece of wood or something.
    Having not done car audio before, I've learned alot but I'd say installing the headunit was by far the easiest part but took the longest connecting the correct adapters in the harness with the maestro.
    Ballz likes this.
  5. Mar 12, 2023 at 7:35 PM
    Ballz
    Bfe SF Bay
    Yes! I forgot to mention needing Maestro! Key part for getting the steering wheel controls to work.
    Were you at in east bay? I’m in Palo Alto
    MrTreehorn[QUOTED] likes this.
  6. Mar 13, 2023 at 11:17 AM
    MrTreehorn
    Dan
    SF East Bay
    2016 TRD OR 4x4 MGM
    In Livermore, taking my truck to Pearson's auto this week to get it all buttoned up. They've been around for decades and are personal Toyota truck owners!
    Ballz[QUOTED] likes this.
  7. Mar 27, 2023 at 5:34 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Sorry for the delay. I used the LC7 to convert the speaker output to RCA. The Alpine is bridged, and way more than is really needed. The gains on both my Alpines are about 50%. The floor and roof will vibrate if I push it. Turned down the bass balances out the fronts and gives a full sound.
    https://www.amazon.com/gp/product/B07C5SWMQ3?ie=UTF8
    https://www.crutchfield.com/p_500RUXKNO2/Alpine-RUX-KNOB-2.html
    https://www.crutchfield.com/p_161LC7IB/AudioControl-LC7i-Black.html
    https://www.crutchfield.com/p_500SA60M/Alpine-S-A60M.html?tp=115
  8. Mar 27, 2023 at 8:07 PM
    325red
    325red Active Member
    Mine is the same from my 2nd gen. I attempted to put it in my 3rd gen but the box just barely hits the sliding window motor. I plan on notching it to make it fit though
  9. Mar 27, 2023 at 9:36 PM
    erok81
    erok81 Well-Known Member
    Imposter
    That’s good to know about the JBL setup. Saw one for sale and was tempted. Glad I didn’t. I had my speakers all out for sound deadening this weekend. They are hilarious. I think some of my fridge magnets have bigger magnets than the stock speakers. Any tips on which to replace if you could only choose one? I was debating on the door speakers and maybe the front tweeters.
    Not to mention adding sound deadner to the doors makes them sound like an expensive car when you close them. :rofl:
  10. Mar 27, 2023 at 10:09 PM
    dnguy77
    dnguy77 Well-Known Member
    Duey
    Baton Rouge, LA
    '18 White Tacoma DC TRD Sport, '03 Grey Tundra AC SR5
    Get @Mr Marv to built you a custom box.
    MGMDesertTaco likes this.
  11. Mar 28, 2023 at 8:38 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I think most of us are amused at how small the magnets are on the factory speakers when we first yank them out. After I stopped laughing I have to admit I was impressed that for what they are they sounded decent. I'm not positive, but I believe they're neodymium magnets which allows them to do the job with less mass.
    Going back with what I know now, if you're only going to replace speakers without going down the rabbit hole, I'd swap out the tweeters and maybe find some efficient 6x9's for the front and that's it.
    I knew I was going with one of the smaller efficient amps so I didn't want to "waste" good speakers on it so I went with Infinity References purely because they were half-off during Black Friday. I had Morels in my shopping cart but like I said, I felt like the value wouldn't have been there being powered by a class D amp. It's safe to assume any aftermarket offering being powered by any amp will sound better than the factory setup. Like with anything else in the upgrading game it's up to the individual to determine what they're willing to spend and what they're satisfied with.
