Subs pop
Discussion in 'Audio & Video' started by js_iron, Oct 7, 2008.
  1. Oct 7, 2008 at 6:25 AM
    js_iron
    js_iron [OP] Member
    04 TRD PreRunner
    I installed my system yesterday & I am concerned over something. I have two 10" Punch's with a 500 watt amp & Kenwood deck. I've had the same system in my past several vehicles, so I know its a good system. My concern is that when I turn the truck off the subwoofers make a popping sound & jump. I noticed that when you play with the RCA jacks it will do the same thing. Never had the problem before. Any help?
  2. Oct 7, 2008 at 3:32 PM
    2004Taco
    2004Taco Well-Known Member
    Long Beach,CA
    04 PreRunner SR5 Trd
    Proformance: Magnaflow K&N CAI Billet grille Suspension: Fox 2.5 Coil-overs with DSC Total Chaos UCA Deaver j59 Leaf Springs Bilstein 5100 0"-2" Rear Shocks
    Blowin out sub?
  3. Oct 7, 2008 at 3:49 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I think my subs did that when i had the RCA's plugged into the wrong output in the back of the deck once..
  4. Oct 7, 2008 at 3:50 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Check you wiring...
    Make sure the AMP has a good ground. Their should not be a pop. You may have an issue with part your unit now...
  5. Oct 8, 2008 at 4:07 AM
    craigFLA
    craigFLA Well-Known Member
    Ft. Lauderdale, Florida
    Tacoma TRD Sport Pkg.#1, XSP Package
    Leather, 20" rims, Borla cat-back exhaust, running boards, back up camera/3" screen in rear view mirror, carbon fiber interior trim. Tow Package. MODS: URD intake BHLM. Tinted tails & 3rd brake light Fog Light mod. 5pc Grill Craft (High Gloss Black powder-coat) T-Rex eye-lids AVS Wind Deflectors 3M Window Tint 15 front/30 rear OBX Sports Pedals Viper 5901 / remote start Pioneer AVIC F90BT-NAV Hybrid L8's in doors, L4's and Dynaudio MD102 tweets in custom kicks, morel rear-fill, JL TW5-13" sub, JBL MS-8, 2@Tru B475, Tru 4.65, PPI a600.2, PPI 456 X-over, Raamat BX2 and ensolite. relocated rear seats 3/4" Retrax cover electric dual "dead-bolt-lock" electric tailgate lock. electric Dynalock for Retrax Cover/custom fabricated case. kinetik second battery/power-gate isolation. Powerslot Cryogenic rotors, Hawks HPS Pads, SS lines,painted calipers&drums FULL trans flush mod OE Denso plugs
    How do you have our amp remote wired? Is it direct to the deck?
    Sometimes, "popping" when you first turn on the deck is caused by the sudden power surge to the amp remote lead.
    Im not sure if this is the problem your having, but there are options available to correct the issue. Stinger and other manufacturers make a device that wires inline between the amp and deck, which simply delays the remote power for a second. This will usually correct popping issues.
    -----------------------------------EDIT-----------------------------
    Sorry, just re-read, your problem is when you turn OFF the truck. I agree with others, and would recommend checking your amp grounds. Make sure they are as short as possible. Try to run the ground to actual frame of truck, and always wire brush or grind the area bare for best contact.
    Let us know if this solves your problems.
    Good Luck.
  6. Oct 8, 2008 at 11:07 AM
    js_iron
    js_iron [OP] Member
    04 TRD PreRunner
    I tried messing with the RCA jacks & I reversed them going into the amp. That solved the pop/thump when I turn the truck off, but it still does it while I'm driving or when I touch the RCA jacks. The ground is about 8" long & directly to the body. Like I said, same system & setup I've had in the past several vehicles & never had a problem. Thanks for the replies
  7. Oct 8, 2008 at 11:10 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Did you check the back of your head unit to make sure you have the RCA's plugged into the right output? My old deck had multiple outputs and i recall plugging them into the wrong one and my subs popped like that - didnt get any sound at all out of the subs, just the popping. dont know if you're getting any sound or not?
  8. Oct 8, 2008 at 3:36 PM
    js_iron
    js_iron [OP] Member
    04 TRD PreRunner
    Think I fixed the problem. Pulled my dash apart again & checked RCA's. One was not plugged in all the way & was rubbing against a bracket. I have checked it out & its not doing it anymore, so hopefully its fixed.
  9. Oct 8, 2008 at 4:17 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    its always the simple things that get you
  10. Oct 9, 2008 at 8:46 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    +1
    I had been installing my own stereos since ive been driving, and on other peoples cars and when i figured out i plugged the RCA's into the wrong output... DOH. Must have been the beer.. :cool:
