Subway4X4's New OLD 1946 American Bantam Trailer Build
Discussion in 'Other Builds' started by Subway4X4, Nov 11, 2018.
  1. Jan 28, 2019 at 6:32 PM
    #41
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    You can contact the site and let them know that your Bantam (by serial number) still exists, or maybe the previous owner did and you can update. Mine is also a T3-C but looks earlier...I have tubing supports by the tailgate where it looks like you have sheet metal. It’s also interesting to find the hole for the blackout switch for caravan driving, the place for an axle brake lever, the patched drain hole in the floor, etc. interesting story behind these trailers. I’m up in the air between a desert tan box and navy fenders or possibly the original red or green.
  2. Jan 29, 2019 at 5:40 AM
    #42
    Rexfordian13
    J
    Actually, wrong link...stoopid tiny computer phone. Try this one.
    http://bantamt3c.com/
    I’m # 1723
  3. Jan 29, 2019 at 8:18 AM
    #43
    Subway4X4
    Subway4X4 [OP] Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Wow. Cool!
    I can’t seem to find SN 1723
    1715 is the closest one I could find.
    Link?
  4. Feb 3, 2019 at 11:13 AM
    #44
    Subway4X4
    Lloyd
    NY/NJ
    Trying to figure out the suspension. Based on my research, the leaf spring suspension is supposed to be a carry over from surplus parts from 1945-ish Willys, GPW, MB, CJ-2A and CJ-3A post-WWII military vehicles.
    Apparently, in its 70+ life, human ingenuity has morphed the suspension.
    1945 spec is 10 leaf, 1.75 wide, 35.5” eye-to-eye. The current suspension is not to spec.
    The top two spring packs came off the trailer: 4 leaf, 35.5” eye-to-eye, 2” wide which was ground to a 1.75” taper on both ends to fit in the spring mounts.
    Both spring packs are different/unmatched packs, probably changed at different times. The front spring bolts were also slightly different from each other. The rear shackle bolts were all different, two had square nuts (which I believe is correct for the era) which could not be impacted off the bolt. Breaker bar was the tool of choice. Plus brute strength.
    The bottom is the correctly spec’d leaf pack. Just ordered one to verify fit. I’ll order the second one soon.
    The rear shackles are not correct for my 1946 model year. It is correct for the 1947 model around SN 13661. The correct shackle is the “U” shackle depicted on the bottom of the pic.
    I’ll stay with the double plate shackle, because the shackle frame mount was already modified to fit the standard two plates and it looks sound.
    Had to special order specific brass bushings for the front leaf eyes (3/4” OD x 9/16” ID x 1-3/4” L) and rubber bushings for the rear spring eye (7/8” OD x 7/16” x 1-3/4” inner length x 2-1/4” outer length.)
    Also ordered super hard to find U-bolts: 2-3/8” radius x 7” length x 1/2” bolt diameter. They’re hard to find because my new axle with 6 lug Toyota hub is 2-3/8” diameter. That’s not the standard axle diameter for Jeep era vehicles of the time. I believe the Jeep standard is a minimum 2-1/2” diameter.
    Still have more to do, but it’s getting there.
    Thanks to @Grand dude for the link to the specialty web store. http://www.stengelbros.com/
    Skierrichy and Grand dude like this.
  5. Feb 7, 2019 at 8:00 PM
    #45
    Subway4X4
    Lloyd
    NY/NJ
    Bushings and 7” long x 2-3/8” radius ubolts came in! I screwed up measuring the ID of the rear bushing. I ordered 7/16” inner diameter. I should’ve ordered 3/8” ID. Oh well. Found a nice grade 5 7/16” x 3” Flange bolt at Tractor Supply. Just drilled out the lower shackle hole to 7/16” and voila... back in business.
    Pressing in the rear rubber bushings.
    In goes the front bronze bushings
    Ubolts are the perfect length.
  6. Feb 8, 2019 at 10:17 AM
    #46
    Grand dude
    Grand dude Well-Known Member
    Dave
    lehigh valley, PA.
    2016 trd or dcsb & 2002 trdor exclb
    cool stickers and a baseball card With clothes pin, sounds awesome ! wicked
  7. Feb 8, 2019 at 10:25 AM
    #47
    Subway4X4
    Lloyd
    NY/NJ
  8. Feb 8, 2019 at 10:40 AM
    #48
    Grand dude
    Dave
    lehigh valley, PA.
  9. Feb 8, 2019 at 5:46 PM
    #49
    Subway4X4
    Lloyd
    NY/NJ
    For my reference:
    Skierrichy likes this.
  10. Feb 9, 2019 at 8:40 AM
    #50
    Subway4X4
    Lloyd
    NY/NJ
    Starting to take shape. Need to install the longer tongue and start the wiring.
  11. Feb 10, 2019 at 5:07 PM
    #51
    Subway4X4
    Lloyd
    NY/NJ
  12. Feb 15, 2019 at 11:19 AM
    #52
    Subway4X4
    Lloyd
    NY/NJ
    Plan for this weekend: finish the wiring.
    This is why I hate electrical work
  13. Feb 17, 2019 at 6:29 PM
    #53
    Subway4X4
    Lloyd
    NY/NJ
    All wired up! 7 Pin Standard.
    Junction box:
    Side markers, rear tail, stop, turn and reverse lights.
  14. Feb 18, 2019 at 4:28 PM
    #54
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    To many, but never done
  15. Feb 18, 2019 at 4:29 PM
    #55
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    Holy crap! Thanks for putting it on paper
    Subway4X4[QUOTED][OP] likes this.
  16. Feb 18, 2019 at 4:32 PM
    #56
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    Looks sweet:thumbsup:
    Your beating me:rofl:
  17. Feb 20, 2019 at 10:43 PM
    #57
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Nice.
    Looks just like a modern M1101 trailer.
  18. Mar 18, 2019 at 7:59 PM
    #58
    Rexfordian13
    J
    These are the leafs I’m trying to make work, I still owe you axle dia. measurements...I can almost see them as the snow melts!8D3FED74-6AAC-4B6D-ADC2-C30DC1C27537.jpg62D9FE24-E23F-4C70-9415-0772C7D9504B.jpgAFF30B19-ED31-4A2A-A80B-09EB7A01F72D.jpg
    These are made in India as Jeep replacement parts...think I got the set for $100?
  19. Aug 25, 2019 at 3:49 PM
    #59
    Subway4X4
    Lloyd
    NY/NJ
    Finally welded on the floor pan of my trailer. I just had it laying on the bed. Life got in the way and stalled the project. Needed it welded to support the bed structurally.
    Now does double duty hauling all my DIY crap and fishing kayak.
    Going to town dump:
    Going to kayak bass tournament
  20. Aug 25, 2019 at 3:58 PM
    #60
    Subway4X4
    Lloyd
    NY/NJ
    How’s your trailer project? I’m pretty much done.
