Subwoofer/Amp Custom Box Build?
Discussion in 'Audio & Video' started by hotrodbanshee, Dec 25, 2011.
  1. Dec 25, 2011 at 7:50 PM
    hotrodbanshee
    hotrodbanshee [OP] Well-Known Member
    Clayton
    El Campo,Tx
    2012 TRD Sport 4X4 Double Cab
    Thinking about building a sub box for my wifes 2012 double cab. It will go behind the passenger side back seat. It will have about .70 cubic ft air space. I am looking at using a JL Audio 500/1V2 500 watt mono amp. As for the sub I am looking at the memphis audio 15-SC12D4 12" shallow 3" mount depth sub or the alpine SWR-T12 12" shallow 3.5" mount depth sub. Ya'll think this would give me some good clean decent bass? I will be removing the 60% plastic storage behind the seat. I want to keep the storage behind the driver side. Is this a good set up and out of the 2 subs which would sound better or should I go with a 10"? I don't want to have to mod the back seat?
  2. Dec 26, 2011 at 6:47 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    I am not at home to look, but IIRC, the 10" Type R think works wonderfully in a .7cf box, where the 12" version looks much better with a bigger box.
    If you already have the amp, use it. If not, you can get a lot of amp in a smaller package - this could give you the extra air space needed for the 12" version, fi you wanted to run that.
    The Type R has a lot of R&D behind it, and looks like a fantastic sub. It would get my nod over the Memphis.
  3. Dec 26, 2011 at 8:56 AM
    hotrodbanshee
    Clayton
    El Campo,Tx
    I don't have a amp or speaker yet, so I am open to suggestions. I do want the smallest amp possible to mount next to the sub and put out 400-500 watts rms.
  4. Dec 26, 2011 at 9:05 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    Whats your budget for the amp and sub? The JL 500/1 is not a very compact amp and in my opinion there are other amps that fit your requirements a little better.
  5. Dec 26, 2011 at 9:11 AM
    hotrodbanshee
    Clayton
    El Campo,Tx
    $500-$700 what are some other options? I kind of like the arc audio KS500.1 mini.
  6. Dec 26, 2011 at 9:30 AM
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    Look at the newer class D amps, Alpine PDX and the JL Audio XD lines come to mind, but there are a lot more with small footprints. Cruise through a website such as Crutchfield or Sonicelectronicx. There are some lines such as Massive Audio that produce longer/thinner amps, only you can know how much space you will have.
  7. Dec 26, 2011 at 9:31 AM
    fishntaco
    Josh
    Mobile Al
    I don't have any experience with the Arc Audio amps but, I can recommend the JL XD 600 or Alpine Pdx M6. Both of those amps have a relatively small footprint. I would also take Matt's suggestion of the alpine type r. I heard one a couple of days ago and was impressed. Even paying retail you would remain within your budget, but search around and you can find some good deals.
    Edit:^^^ Beat me to it. Those were my thoughts exactly.
  8. Dec 26, 2011 at 10:40 AM
    mattg43
    Texas
    08 Prerunner SR5 DC
    A couple things to remember - The Type R thin is only available in Single 4 ohm configuration, so a 2 channel bridged is your best bet (assuming you are not doing a 4 channel for front speakers...)
    At the prices you are looking I would probably hit up Sonic Electronix.
    Get the Type R (10 is $250, 12 is $290)
    then choose the amp.
    I would consider: (power at 4 ohm)
    Polk PA d2000.2 - $250, 500w, 7" x 8"
    JL XD 600/1 - $300, 400w, 8.5" x 7"
    Alpine PDX 1.600/M6,$300, 600w, 10.5 x 8"
    All of those should be around the same price, all a bit less than the 500/1, and all smaller in size.
    For the box, I would make it as big as possible, do a small inset area in the corner for the amp, and run the 12" if you can get over 1 cubic ft, and throw in some polyfil.
    I want to say I remember the 12 looking good around 1.2 cf, but I would have to get home this evening to double check. Or someone else with WinISD can run it. Or Steven may chime in with some info from the software he uses, if he is around.
  9. Dec 26, 2011 at 6:33 PM
    hotrodbanshee
    Clayton
    El Campo,Tx
    I looked at the alpine pdx1.600 and really like the looks and size of it and it puts out 600watts @ 2ohm or 4ohm.
  10. Dec 26, 2011 at 8:17 PM
    mattg43
    Texas
    08 Prerunner SR5 DC
    The type R thin 12 looks pretty good in 1 cf or higher. I really would prefer 1.25 or so, which should be do-able on that side.
  11. Dec 27, 2011 at 2:29 AM
    Mexicutioner
    Mexicutioner Well-Known Member
    Joel
    Chula Vista, CA
    '10 4x4 TRD DCSB Off Road
    FRONT: Total Chaos 3.5 4x4 kit, Fox 2.5 x 8" coilovers REAR: Defined Engineering SUA kit, Fox 2.5 x 14" smooth bodies, Fox 2.0 x 4.0" bumps, American Motorsports bolt in bedcage MISC Mcneil Racing Inc Glass all around, Afe stage II cai, weathertech floormats, flowmaster 40, rigid led 30" combo, rigid dually reverse cargo lights, Bamf sliders, 1.25" spidertrax, 20% tint - front, 50% tint - rears AUDIO Alpine w910 headunit, Alpine 6.5" type r components in front, Alpine 6.5" type r coaxials in rear, 2 Alpine 10" type r shallow mount subs w/ custom box, JL Audio 900w 5 channel HD amp, steering controls & reverse camera integrated, Stinger Roadkill matted on entire interior
    i have the alpine 10" type r shallow mount with a jl 900 watt 5 channel (400/4 500/1) hd amp and works perfect more than decent amount of sound i would say. sub fits perfect behind the seats and amp under the seat. this thing hits pretty hard for a flapjack
  12. Dec 27, 2011 at 7:22 AM
    hotrodbanshee
    Clayton
    El Campo,Tx
    Do you have any pics of your system?
  13. Dec 28, 2011 at 1:25 AM
    Mexicutioner
    Joel
    Chula Vista, CA
    no but ill make sure to get some tomorrow in the day light and ill post em
  14. Dec 28, 2011 at 1:44 AM
    Pnicholas1019
    Pnicholas1019 Well-Known Member
    Parker
    surprise
    '92 toyota tacoma
    6" lift, front bumper, Oil cooler, HID lights, toyo m/t 33's.
    one 12 with a 1000watt amp would sound good, Kicker makes a clean pro comp 12. and the amp you could go rockford fostgate or 500d memphis amp. Are you looking to run your speakers through the amp?
  15. Dec 28, 2011 at 6:03 AM
    hotrodbanshee
    Clayton
    El Campo,Tx
    No I will get a small 4 channel to go under seat for door speakers.
  16. Dec 29, 2011 at 12:35 AM
    Mexicutioner
    Joel
    Chula Vista, CA
    the headunit is the shiz....i only got one type r 10" this little sub has gots some juice in it!! and the little amp powers 500w to the sub and 100w to each door speaker. ideally yeah 2 subs will hit harder but 1 will hit deeper. this box is specifically made for 1 type r shallow mount but i guess if u want 2 u could always get a bigger box to go all the way up to the top of the seat headrest.
  17. Dec 29, 2011 at 5:29 AM
    hotrodbanshee
    Clayton
    El Campo,Tx
    What are the diminsions of your box? Did you build it yourself?
  18. Dec 29, 2011 at 8:48 PM
    Mexicutioner
    Joel
    Chula Vista, CA
    honestly idk the dimensions. my boy has a local shop here and he gets down.
  19. Dec 29, 2011 at 9:00 PM
    HighRise
    HighRise Active Member
    Fritz
    Portland,Oregon
    10 sport super white
    6 inch Pro comp stage 2
    What model is that amp?
  20. Dec 29, 2011 at 9:22 PM
    Mexicutioner
    Joel
    Chula Vista, CA
