Subwoofer Box Needed
Discussion in 'Buy / Sell / Trade' started by Cajun1, Jun 8, 2011.
  1. Jun 8, 2011 at 8:08 AM
    Cajun1
    Cajun1 [OP] Well-Known Member
    Brooks
    Abbeville, LA
    Brush Gaurd 265 Destinations 5100's @ 1.75 LED Lighting Center console Home made Saatchi DDM 5K HID
    Im in need of a sub box obliviously...but i don't want to take out both compartments in the back of the seat.. just the bigger one so i can have room for an amp mounting space...if any one has one or just knows the dimensions i can build my own. Thanks
  2. Jun 8, 2011 at 8:13 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
  3. Jun 8, 2011 at 8:56 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If you get a double sub box for the double cab from supercrewsounds or soundoffaudio, you can cut one of the sub boxes off of the end and just use the other sub box and attached amp board. I did this and then sold the cut off box to someone else, ended up costing like $80 or so ($120 - $40). You can also get their measurements for the entire box, then subtract off the cut off box, and end up with the measurements needed if you want to build one.
  4. Jun 20, 2011 at 11:35 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
